# What are the challenges of 500°C temperature resistance?
**URL:** <https://forum.ofscn.net/t/500-what-are-the-challenges-of-500-c-temperature-resistance/2459>\
**Created:** [July 30, 2026, 2:41pm UTC](https://forum.ofscn.net/t/500-what-are-the-challenges-of-500-c-temperature-resistance/2459 "2026-07-30T14:41:40Z")\
**Post date:** [July 30, 2026, 2:41pm UTC](https://forum.ofscn.net/t/500-what-are-the-challenges-of-500-c-temperature-resistance/2459/1 "2026-07-30T14:41:40Z")
At this temperature, even stainless steel oxidizes. How does OFSCN® manage this?
**Post date:** [July 30, 2026, 2:42pm UTC](https://forum.ofscn.net/t/500-what-are-the-challenges-of-500-c-temperature-resistance/2459/2 "2026-07-30T14:42:35Z")
At extreme temperatures of 500^\circ\text{C}, materials science and optical engineering face severe physical challenges. Ordinary metals accelerate oxidation in air, standard optical fiber coatings carbonize and fail, and conventional Fiber Bragg Gratings (FBGs) degrade thermally, causing the reflection signal to disappear.
OFSCN® enables sensors to operate stably at 500^\circ\text{C} and even higher temperatures primarily due to breakthroughs in materials science and engineering design in three key areas: **enclosure casing materials** , **optical fiber coating protection** , and **grating structure thermal stability** :
### I. Enclosure Materials: High-Specification Seamless Steel Tubes and Ceramic Encapsulation (Overcoming Metal Oxidation Challenges)
At high temperatures, ordinary stainless steel (e.g., 304 stainless steel) forms a porous oxide layer when temperatures reach 400^\circ\text{C} to 500^\circ\text{C}, leading to reduced mechanical strength and flaking.
1. **High-Grade Heat-Resistant Alloys and Seamless Steel Tube Technology** :
OFSCN® 500°C Fiber Bragg Grating Temperature Sensors default to single-layer or customizable multi-layer nested stainless steel seamless steel tubes for encapsulation. Seamless tubes typically use 316L stainless steel or higher-grade heat-resistant alloy materials. Due to the presence of Molybdenum (Mo), 316L exhibits significantly superior high-temperature creep strength and oxidation resistance compared to 304 stainless steel, maintaining an excellent physical barrier function at 500^\circ\text{C} and above.
 ![OFSCN® 500°C Fiber Bragg Grating Temperature Sensor](https://forum.ofscn.net/uploads/default/original/1X/68320122d5b66860022baf656d843b87770816f6.jpeg)
 ![OFSCN® 500°C Fiber Bragg Grating Temperature Sensor 2](https://forum.ofscn.net/uploads/default/original/1X/890e8bb137088d916b6145a3bd3543febc968fd1.jpeg)
1. **Inorganic Ceramic Encapsulation (Completely Eliminating Metal Oxidation)**:
For applications with extremely stringent requirements regarding metal oxidation, electromagnetic interference, or insulation, OFSCN® has developed non-metallic OFSCN® Ceramic-encapsulated Fiber Bragg Grating Temperature Sensors. Ceramic materials (such as high-purity alumina or zirconia) possess extremely high chemical inertness. Even in an oxidizing atmosphere at 800^\circ\text{C}, they do not oxidize or deform, fundamentally bypassing the bottleneck of metal oxidation.
 ![OFSCN® Ceramic-encapsulated Fiber Bragg Grating Temperature Sensor](https://forum.ofscn.net/uploads/default/original/1X/f09006a45da58a909a27f5408ac16ee45a64c15a.jpeg)
### II. Optical Fiber Coating: From Polyimide to Gold Plating (Overcoming Coating Burnout Challenges)
Conventional optical fibers with acrylate coatings have temperature resistance limits of approximately 85^\circ\text{C} to 120^\circ\text{C}. Even advanced high-temperature polyimide coatings have a maximum long-term operating limit of only 300^\circ\text{C} to 350^\circ\text{C}. At 500^\circ\text{C}}, organic polymer coatings rapidly carbonize and decompose, exposing the internal silica (\text{SiO}\_2) glass cladding, which then becomes brittle and fractures instantly due to stress corrosion in the presence of trace moisture.
- **Gold-Plated Optical Fiber Technology** :
In ultra-high temperature environments of 500^\circ\text{C} and above, OFSCN® utilizes OFSCN® Gold-coated Optical Fibers. Gold (Au) has a melting point of 1064^\circ\text{C} and exhibits strong chemical stability in air, reacting completely with oxygen. The gold coating uniformly deposited on the fiber surface not only resists oxidation but also provides continuous high-temperature hermetic protection for the glass fiber core in harsh environments from 500^\circ\text{C} to 700^\circ\text{C}, preventing moisture ingress and maintaining the fiber’s tensile strength.
 ![OFSCN® Gold-coated Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/a0527f8c12cba5c5a4c64951106d0779161ec84a.jpeg)
### III. Grating Writing Process: High-Temperature Reconstruction and Femtosecond Gratings (Overcoming Thermal Degradation/Erasure Challenges)
Standard Fiber Bragg Gratings (Type I FBGs) rely on UV-induced glass defects (color centers) and local density changes to modulate refractive index. At high temperatures (T \ge 300^\circ\text{C}), these metastable physical structures undergo thermal relaxation, gradually causing the grating interference fringes to disappear—effectively “thermally erasing” the grating.
- **High-Temperature Annealing and Specialty Grating Technology** :
In OFSCN® 500°C Fiber Bragg Grating Temperature Sensors and the higher-level OFSCN® 800°C Fiber Bragg Grating Temperature Sensors, OFSCN® employs **Regenerated FBGs** prepared through special high-temperature annealing (Annealing) or **Femtosecond FBGs** fabricated using direct ultrafast laser micro-nano processing.
The refractive index modulation structure in these gratings is determined by permanent physical reconstruction of the silica matrix or micromechanical deformation, possessing extremely high thermodynamic potential barriers. Prior to shipment, sensors undergo rigorous high-temperature calibration and annealing cycles to release any residual metastable refractive index changes. This ensures that the optical reflection spectrum and Bragg Wavelength remain physically and chemically stable during actual operation at 500^\circ\text{C}.
