# Are optical fibers affected by static electricity?
**URL:** <https://forum.ofscn.net/t/are-optical-fibers-affected-by-static-electricity/2736>\
**Created:** [September 5, 2026, 1:56pm UTC](https://forum.ofscn.net/t/are-optical-fibers-affected-by-static-electricity/2736 "2026-09-05T13:56:09Z")\
**Post date:** [September 5, 2026, 1:56pm UTC](https://forum.ofscn.net/t/are-optical-fibers-affected-by-static-electricity/2736/1 "2026-09-05T13:56:09Z")
In high-voltage electrostatic precipitators, would optical fibers adsorb dust due to electrification?
**Post date:** [September 5, 2026, 1:57pm UTC](https://forum.ofscn.net/t/are-optical-fibers-affected-by-static-electricity/2736/2 "2026-09-05T13:57:01Z")
From the perspective of dielectric physics and optical engineering, this issue can be analyzed from three dimensions: **intrinsic material properties** , **adsorption mechanisms in strong electrostatic fields** , and **impacts on optical signals/sensing and engineering countermeasures** :
### 1. Charging and Adsorption Mechanisms of Optical Fibers in Strong Electrostatic Fields
The base material of optical fibers is high-purity silica glass (\text{SiO}\_2), typically coated with polymers such as polyacrylate or polyimide on the outer layer. These materials are all **excellent electrical insulators (dielectrics)**, with resistivity usually higher than 10^{12}\ \Omega\cdot\text{cm}.
In the extreme electric field environment of electrostatic precipitators (ESPs), which typically operate at voltages from 40\ \text{kV} \sim 80\ \text{kV} or even higher:
1. **Dielectric Polarization Effect:** When the insulating optical fiber is placed in a strong electric field, dielectric polarization occurs within the fiber material and its coating layer, inducing bound charges on the surface.
2. **Space Charge Adsorption and Collision:** Corona discharge inside the ESP generates a large ion flow, causing suspended dust particles to become charged. The optical fiber surface, bombarded by charged ions and subjected to dielectrophoretic forces, is prone to accumulating electrostatic charges.
3. **Electrostatic Adsorption Phenomenon:** Charged dust particles, under the influence of Coulomb forces and polarization electric field forces, **do indeed adsorb and deposit on the surface of bare optical fibers or polymer coatings**.
### 2. Assessment of the Impact of Surface Adsorbed Dust on Optical Fibers
- **Impact on Optical Signal Transmission (Optical Essence): No Impact**
The light waves within an optical fiber are strictly confined between the core and the cladding, propagating through total internal reflection (TIR). External electrostatic fields, accumulated surface charges, and adsorbed dry dust **do not couple into the core and do not cause electromagnetic interference (EMI) to the transmitted optical signal**.
- **Impact on Fiber Optic Sensing Performance (Engineering Thermal and Mechanical Characteristics): Potential Secondary Effects**
  - **Thermal Response Delay:** If the optical fiber is used for temperature monitoring (e.g., FBG fiber Bragg grating thermometry), a thick layer of dust adsorbed on the surface can form additional thermal resistance, slowing down the response time (time constant \tau) of the sensor to rapid changes in ambient gas temperature.
  - **Risk of Surface Discharge:** In environments with high concentrations of conductive dust (such as carbonaceous fly ash), severe dust accumulation on the surface may reduce the creepage distance, potentially leading to partial discharge.
### 3. Engineering Protection Recommendations
In industrial environments like electrostatic precipitators, characterized by strong electric fields and high dust impingement, **direct exposure of bare optical fibers or those with only polymer coatings is generally not recommended** :
- **Metallic Armoring/Grounded Encapsulation:** In industrial applications, optical fibers or fiber optic sensors are typically encapsulated in micro-seamless stainless steel tubes. Metallic armoring, when properly grounded, provides equipotential shielding, eliminates surface electrostatic charge accumulation, prevents electrostatic adsorption, and resists mechanical wear from high-velocity flue gases.
