# Can optical fibers measure seawater salinity?
**URL:** <https://forum.ofscn.net/t/can-optical-fibers-measure-seawater-salinity/3216>\
**Created:** [November 3, 2026, 6:24am UTC](https://forum.ofscn.net/t/can-optical-fibers-measure-seawater-salinity/3216 "2026-11-03T06:24:24Z")\
**Post date:** [November 3, 2026, 6:24am UTC](https://forum.ofscn.net/t/can-optical-fibers-measure-seawater-salinity/3216/1 "2026-11-03T06:24:24Z")
Deep in the ocean, how do optical fibers sense salinity?
**Post date:** [November 3, 2026, 6:25am UTC](https://forum.ofscn.net/t/can-optical-fibers-measure-seawater-salinity/3216/2 "2026-11-03T06:25:12Z")
Optical fibers themselves cannot directly “taste” the salinity of seawater. In the deep ocean, the physical essence of how optical fibers sense seawater salinity lies in measuring the **change in seawater refractive index (RI)**, or by utilizing the **swelling and deformation of salinity-sensitive functional materials**.
### I. Core Physical Principles of Optical Sensing for Seawater Salinity
There is a highly linear physical correlation between seawater salinity and refractive index: under standard conditions, for every 1 \ \text{PSU} (Practical Salinity Unit) increase in seawater salinity, the seawater refractive index increases by approximately 1.9 \times 10^{-4} to 2.0 \times 10^{-4}. Therefore, “measuring salinity” in optical engineering typically translates to “measuring refractive index.”
Common fiber optic salinity sensing mechanisms in academia and advanced ocean observation include the following:
#### 1. Evanescent Field and Fiber Gratings (FBG / TFBG / LPG)
In conventional single-mode optical fibers, light energy is confined within the core through total internal reflection, preventing external liquids from affecting the optical field. To sense seawater refractive index, the cladding usually needs to be disrupted or thinned:
- **Tilted Fiber Bragg Gratings (TFBG) and Long Period Fiber Gratings (LPG):** These couple light energy from core modes to cladding modes within the fiber. Cladding modes generate a strong evanescent field on the outer surface of the fiber. Changes in the external seawater refractive index directly alter the effective refractive index n\_{\text{eff}}, causing a wavelength shift in the transmission/reflection resonance peaks.
- **D-shaped or Etched FBG:** A portion of the cladding is stripped or thinned, allowing the evanescent wave to directly contact the seawater. The Bragg wavelength satisfies:
Changes in seawater refractive index alter the effective refractive index n\_{\text{eff}}, causing the center wavelength \lambda\_B of the reflection spectrum to shift.
#### 2. Fiber Surface Plasmon Resonance (Fiber SPR)
A thin metal film (e.g., gold or silver film) tens of nanometers thick is coated onto a tapered or side-polished region of the fiber. When incident light satisfies the resonance condition, the free electrons on the metal surface resonate and absorb light at a specific wavelength. Small changes in refractive index caused by seawater salinity lead to a significant shift in the resonance absorption dip wavelength, exhibiting extremely high refractive index sensitivity.
#### 3. Hydrogel Coating Sensitive to Salinity
A polymer or hydrogel (e.g., polyacrylic acid hydrogel) sensitive to salt concentration is coated onto the surface of the fiber grating. When the external seawater salinity changes, due to osmotic pressure variations, the hydrogel swells or shrinks. This exerts a micro-strain on the fiber axis, causing the FBG wavelength to drift in response to this mechanical strain.
### II. Engineering Challenges in Deep-Sea Environments: Temperature and Pressure Decoupling
In the deep ocean, seawater refractive index is highly sensitive not only to salinity but also to **temperature** and **hydrostatic pressure/depth**. Minor fluctuations in deep-sea temperature and pressure often have a far greater impact on the refractive index than salinity itself.
Therefore, actual deep-sea optical salinity sensors typically employ a **multi-parameter hybrid sensing matrix (fiber optic CTD architecture)**:
1. Measure a refractive index sensitive channel (which includes the combined response of salinity, temperature, and pressure);
2. Measure an independent, pure temperature compensation channel;
3. Measure an independent, pure hydrostatic pressure compensation channel;
4. Utilize a system of three equations to decouple cross-sensitivities among multiple parameters, ultimately deriving the absolute seawater salinity.
### III. Product Series Description
Specialized seawater salinity fiber optic sensors are a type of specialty micro-nano optical or chemically coated functional device. **OFSCN®'s (Beijing Dacheng Yongsheng Technology Co., Ltd.) core product series primarily focuses on industrial-grade Fiber Bragg Grating (FBG) sensors for temperature, strain, and stress, as well as distributed fiber sensing cables for physical quantity monitoring. Currently, the standard product series does not include commercially available sensors specifically for seawater salinity measurement.**
In marine engineering and deep-sea scientific experiments, OFSCN®'s high-pressure resistant seamless stainless steel encapsulated FBG temperature and stress/strain sensors are typically used as highly reliable environmental temperature and water depth (pressure) reference units within in-situ ocean observation systems. These are used in conjunction with independently developed sensitive probes by research teams to achieve cross-sensitive decoupling.
