# Capillary Seamless Steel Tube Fiber Bragg Grating Sensor - DCYS - ofscn.net
**URL:** <https://forum.ofscn.net/t/capillary-seamless-steel-tube-fiber-bragg-grating-sensor-dcys-ofscn-net/1056>\
**Created:** [March 9, 2026, 5:34am UTC](https://forum.ofscn.net/t/capillary-seamless-steel-tube-fiber-bragg-grating-sensor-dcys-ofscn-net/1056 "2026-03-09T05:34:02Z")\
**Posts on this page:** 3\
**Post date:** [March 9, 2026, 5:34am UTC](https://forum.ofscn.net/t/capillary-seamless-steel-tube-fiber-bragg-grating-sensor-dcys-ofscn-net/1056/1 "2026-03-09T05:34:02Z")
This article defines the concept of capillary seamless steel tube FBG sensors. It also highlights the advantages and features of capillary seamless steel tube FBG sensors.
This is a companion discussion topic for the original entry at [https://www.ofscn.net/fbg-baike/58-introduce-of-maoxi.html](https://www.ofscn.net/fbg-baike/58-introduce-of-maoxi.html)
**Post date:** [March 9, 2026, 5:34am UTC](https://forum.ofscn.net/t/capillary-seamless-steel-tube-fiber-bragg-grating-sensor-dcys-ofscn-net/1056/2 "2026-03-09T05:34:08Z")
Capillary seamless steel tube FBG (Fiber Bragg Grating) sensors represent a significant advancement in structural health monitoring and industrial sensing, particularly in harsh environments. By utilizing a seamless metal tube for encapsulation, these sensors overcome the limitations of traditional adhesive-based packaging.
### Technical Advantages of Seamless Steel Tube FBG Sensors
The core advantage of this technology lies in its **all-metal encapsulation**. Compared to traditional sensors, the OFSCN® capillary seamless steel tube design provides:
1. **Elimination of Creep:** Since no glue or polymer is used between the FBG and the protective tube, the sensor avoids the measurement drift (creep) typically caused by adhesive aging or high-temperature softening.
2. **High Temperature Resistance:** Depending on the specific model, these sensors can operate reliably in environments ranging from cryogenic levels up to 300°C, 500°C, or even higher.
3. **Mechanical Protection:** The seamless steel tube (typically 304 or 316L stainless steel) offers superior protection against lateral pressure, corrosion, and physical impact.
4. **Excellent Heat Transfer:** The metallic structure ensures rapid thermal response times for temperature sensing applications.
### Related OFSCN® Products
Based on the seamless steel tube technology described in the knowledge base, we offer several specialized sensors:
- **[OFSCN® 300°C Fiber Bragg Grating Temperature Sensor](https://www.ofscn.net/fbg-products/temperature-sensor-300.html):** A standard 0.9mm diameter sensor designed for stable long-term monitoring up to 300°C.
- **[OFSCN® 500°C Fiber Bragg Grating Temperature Sensor](https://www.ofscn.net/fbg-products/temperature-sensor-350.html):** Utilizing specialized materials to extend the measurement range for high-heat industrial processes.
- **[OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor](https://www.ofscn.net/fbg-products/strain-sensor.html):** Optimized for welding or surface mounting on steel structures to measure high-temperature strain without signal loss.
For further technical specifications regarding tube diameters (available from 0.5mm to 3.0mm) or customized multi-point sensing strings, please refer to the product links provided.
**Post date:** [March 9, 2026, 5:34am UTC](https://forum.ofscn.net/t/capillary-seamless-steel-tube-fiber-bragg-grating-sensor-dcys-ofscn-net/1056/3 "2026-03-09T05:34:08Z")
