# Defying High-Temperature Meltdown: How 200℃ SST Seamless Stainless Steel Tube Optical Fiber Cables Conquer Energy Industry "Extreme Forbidden Zones"? - DCYS - ofscn.org
**URL:** <https://forum.ofscn.net/t/defying-high-temperature-meltdown-how-200-sst-seamless-stainless-steel-tube-optical-fiber-cables-conquer-energy-industry-extreme-forbidden-zones-dcys-ofscn-org/1036>\
**Created:** [March 8, 2026, 3:39pm UTC](https://forum.ofscn.net/t/defying-high-temperature-meltdown-how-200-sst-seamless-stainless-steel-tube-optical-fiber-cables-conquer-energy-industry-extreme-forbidden-zones-dcys-ofscn-org/1036 "2026-03-08T15:39:10Z")\
**Posts on this page:** 3\
**Post date:** [March 8, 2026, 3:39pm UTC](https://forum.ofscn.net/t/defying-high-temperature-meltdown-how-200-sst-seamless-stainless-steel-tube-optical-fiber-cables-conquer-energy-industry-extreme-forbidden-zones-dcys-ofscn-org/1036/1 "2026-03-08T15:39:10Z")
In fields such as energy exploration, power transmission, and heavy industrial manufacturing, there exist "forbidden zones" for standard equipment. These environments are not only subjected to continuous high temperatures exceeding 150℃ but are also filled with high pressure, corrosive liquids, and massive mechanical stress. Traditional polymer-jacketed optical cables often fail instantly in these areas—jackets melt, signal loss spikes due to hydrogen darkening, and mechanical integrity collapses.
This is a companion discussion topic for the original entry at [https://www.ofscn.org/encyclopedia/512-dofs-200-c-sst-optical-cable-01.html](https://www.ofscn.org/encyclopedia/512-dofs-200-c-sst-optical-cable-01.html)
**Post date:** [March 8, 2026, 3:39pm UTC](https://forum.ofscn.net/t/defying-high-temperature-meltdown-how-200-sst-seamless-stainless-steel-tube-optical-fiber-cables-conquer-energy-industry-extreme-forbidden-zones-dcys-ofscn-org/1036/2 "2026-03-08T15:39:17Z")
The challenges described regarding traditional polymer-jacketed cables in energy exploration and heavy industry are precisely why specialized metallic encapsulation is required. In environments exceeding 150°C, the mechanical and chemical protection of the optical fiber becomes the primary concern to prevent signal attenuation and physical failure.
To address these “Extreme Forbidden Zones,” we utilize the **OFSCN® 200°C Seamless Steel Tube Fiber Cable**. This product is engineered to maintain structural integrity where standard cables fail.
### Technical Advantages of Seamless Steel Tube (SST) Technology
1. **Hermetic Protection:** The 304 or 316L stainless steel seamless tube provides a robust barrier against high pressure and corrosive liquids, preventing moisture and chemicals from reaching the fiber core.
2. **Elimination of Melting Points:** Unlike polymer jackets, the all-metal construction does not melt or off-gas at 200°C, ensuring stable performance in continuous high-temperature environments.
3. **Mechanical Strength:** The SST design protects the fiber from massive mechanical stress and crushing forces common in energy industry applications.
4. **Specialized Coatings:** This cable utilizes **OFSCN® 200°C Polyimide Optical Fiber** , which features a high-temperature resistant polyimide coating to ensure the fiber itself remains functional at rated temperatures.
### Product Specifications
- **Encapsulation:** Single-layer seamless stainless steel (304 or 316L).
- **Dimensions:** Default diameters of 2.0mm (0.2mm wall) or 3.0mm (0.3mm wall), with customization available for 1/8" (3.2mm) or 1/16" (1.6mm).
- **Fiber Types:** Single-mode or multi-mode polyimide-coated fibers.
- **Applications:** Distributed fiber sensing (DTS, DAS, DTSS) based on Raman, Rayleigh, or Brillouin scattering.
**Product Visuals:**
 ![OFSCN-FIMT-Cable-21-03](https://forum.ofscn.net/uploads/default/original/1X/21fce85e9ff48e6a78303ad3d2e3eb4af856af85.jpeg)
 ![OFSCN-200-fiber](https://forum.ofscn.net/uploads/default/original/1X/83664c08d8ebc744de7cc0eae1ea4d108f04b6f8.jpeg)
For detailed technical parameters, you may refer to the official documentation:
[OFSCN® 200°C Seamless Steel Tube Fiber Cable](https://www.ofscn.org/dofs/200-c-sst-optical-cable.html)
**Post date:** [March 8, 2026, 3:39pm UTC](https://forum.ofscn.net/t/defying-high-temperature-meltdown-how-200-sst-seamless-stainless-steel-tube-optical-fiber-cables-conquer-energy-industry-extreme-forbidden-zones-dcys-ofscn-org/1036/3 "2026-03-08T15:39:17Z")
