# Do microcracks form when an optical fiber is bent?
**URL:** <https://forum.ofscn.net/t/do-microcracks-form-when-an-optical-fiber-is-bent/2571>\
**Created:** [August 15, 2026, 4:09am UTC](https://forum.ofscn.net/t/do-microcracks-form-when-an-optical-fiber-is-bent/2571 "2026-08-15T04:09:43Z")\
**Post date:** [August 15, 2026, 4:09am UTC](https://forum.ofscn.net/t/do-microcracks-form-when-an-optical-fiber-is-bent/2571/1 "2026-08-15T04:09:43Z")
If it bends too much, will the glass surface develop microscopic cracks that are invisible to the naked eye?
**Post date:** [August 15, 2026, 4:11am UTC](https://forum.ofscn.net/t/do-microcracks-form-when-an-optical-fiber-is-bent/2571/2 "2026-08-15T04:11:01Z")
When optical fibers are bent excessively, microscopic cracks (microcracks), invisible to the naked eye, will indeed form on the surface of silica (\text{SiO}\_2) quartz glass, and pre-existing sub-micrometer surface defects will accelerate their expansion.
### I. Physical Mechanisms and Material Mechanics Analysis
#### 1. Griffith Flaws & Stress Concentration
Silica quartz glass is a typical brittle material. At the microscopic level, even the surface of a newly fabricated fiber contains tiny sub-micrometer geometric defects known as Griffith Flaws.
When the fiber is straight, the microcracks are in a relatively stable state; once the fiber is bent, the outer side of the bent quartz glass will experience significant tensile stress.
#### 2. Bending Tensile Stress Calculation
The maximum tensile stress \sigma experienced by the outer surface of the fiber during bending can be derived using elasticity mechanics formulas:
\sigma = E \cdot \frac{d}{2R}
Where:
- E is the Young’s modulus of silica glass (approximately 72\text{ GPa} );
- d is the outer diameter of the fiber cladding (standard single-mode fiber d = 125\ \mu\text{m} );
- R is the bending radius.
As can be seen from the formula, the smaller the bending radius R , the more sharply the tensile stress \sigma on the outer surface of the glass increases inversely.
#### 3. Static Fatigue & Crack Growth
When the tensile stress caused by bending acts on the tip of a microcrack, extremely high stress concentration occurs. Under the chemical action of water vapor (\text{H}\_2\text{O} molecules) in the ambient air, the silica chemical bonds ( \text{Si-O-Si} ) at the tip undergo stress corrosion fracture.
This process leads to continuous crack propagation in depth (static fatigue extension). When the microcrack extends to a critical size, the fiber will fracture suddenly without any macroscopic plastic deformation.
### II. Engineering Protection and Structural Encapsulation Solutions
To prevent bare fibers from developing microcracks or mechanical fractures due to bending stress during actual use or installation, metal seamless tube encapsulation or micro-armor structures are typically employed in engineering designs. These solutions constrain the minimum bending radius of the fiber and shield it from external mechanical stresses.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) has developed several stress-resistant and armored protection products to meet the anti-bending and physical protection needs of fiber Bragg grating sensors and optical cables:
#### 1. Alloy Tube Packaged Fiber Bragg Grating Strain Sensor
For sensing scenarios that require withstanding mechanical tensile and bending stresses, internal metal tube encapsulation effectively isolates localized bending stress:
[OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor](https://www.ofscn.net/fbg-products/strain-sensor.html)
 ![OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor](https://forum.ofscn.net/uploads/default/original/1X/90c11b90deb49f0cd88a54ecac0d956bcddf353c.jpeg)
 ![OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor](https://forum.ofscn.net/uploads/default/original/1X/ae908bc1e181cfc4cdf263751c8670552a66522e.jpeg)
 ![OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor](https://forum.ofscn.net/uploads/default/original/1X/4a28a6be888c7e0965d6a522716233e8b6403b54.jpeg)
#### 2. Micro Steel Tube Armored Fiber Optic Patch Cord
Utilizes an internal 0.6\text{mm} stainless steel seamless steel tube anti-bending sheath to limit the fiber’s bending radius, preventing bare fiber from direct side pressure and excessive bending:
[OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-01.html)
 ![OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/c4f5c7c42f73224dc1b2375d81d32de5801427d6.jpeg)
 ![OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/1f3c896451b5c3ff1b05a16eac53983299651981.jpeg)
