Fiber Bragg Grating 3D Force Sensor - Solid Surface Pressure Sensor - Pen force sensor - Medical puncture force sensor - Picture parameter customization-manufacturer brand price - DCYS - ofscn.net
The product is a FBG 3D Force Sensor encapsulated in a seamless steel tube, also known as: FBG stress sensor, pen-style force sensor, pen-type dynamometer, fiber Bragg grating force pen, Solid surface pressure sensor, Fiber Bragg Grating 3-Axis Load Cell, Pen-style FBG Sensor, Fiber Optic Force Transducer, FBG Multi-axis Sensor, Hard Alloy Force Sensor.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/pressure-sensor.html
Welcome to the OFSCN® Technical Inquiry forum.
The OFSCN® Fiber Bragg Grating 3D Force Sensor described above is a high-precision instrument designed for multi-directional pressure measurement on solid surfaces or medical puncture force analysis.
Key Technical Characteristics:
  • Multi-Axis Measurement: The sensing unit consists of a hard alloy base with three Fiber Bragg Gratings (FBGs) arranged longitudinally at 120-degree intervals. This allows for the decoupling of forces in multiple directions.
  • Versatile Form Factors: It is available in a standard industrial version and a handheld “pen-style” version (default 4.0 mm diameter) for ergonomic use.
  • Customizable Tips: The sensing end can be configured as a flat head for surface pressure or sharpened for medical puncture applications.
  • Dimensions: Common outer diameters include 1.5 mm, 2 mm, 4 mm, and 6 mm, with further customization available.
  • Calibration: Each unit is factory-calibrated for vertical force vs. wavelength shift, provided with a linear calibration formula (N/pm).
Product Visuals:
Technical Specifications & Links:
  • Temperature Range: Standard operation from -20°C to +55°C. For applications requiring high precision under varying temperatures, we recommend integrating an external OFSCN® Fiber Bragg Grating Temperature Sensor for temperature compensation.
  • Connectors: Default FC/APC; ST, LC, and SC (PC/APC) are available upon request.
For detailed technical parameters and customization options, please visit the official product page:
OFSCN® Fiber Bragg Grating 3D Force Sensor Detailed Specifications
If you have specific requirements regarding the force range or spatial constraints of your application, feel free to provide the technical details for further consultation.
