# How long of a patch cord should I buy?
**URL:** <https://forum.ofscn.net/t/how-do-i-choose-the-right-length-for-a-patch-cord/2557>\
**Created:** [August 15, 2026, 4:00am UTC](https://forum.ofscn.net/t/how-do-i-choose-the-right-length-for-a-patch-cord/2557 "2026-08-15T04:00:59Z")\
**Post date:** [August 15, 2026, 4:00am UTC](https://forum.ofscn.net/t/how-do-i-choose-the-right-length-for-a-patch-cord/2557/1 "2026-08-15T04:00:59Z")
Can jumper wires be cut and reconnected like electrical wires? What if they are too long?
**Post date:** [August 15, 2026, 4:01am UTC](https://forum.ofscn.net/t/how-do-i-choose-the-right-length-for-a-patch-cord/2557/2 "2026-08-15T04:01:56Z")
**Fiber optic patch cords must never be cut and manually twisted together like copper wires.**
Here is a systematic analysis from the perspectives of physical transmission mechanisms, splicing methods, and engineering handling of excessively long patch cords:
### I. Physical Mechanism: Why Can’t Fiber Optic Cables Be Cut and Twisted Arbitrarily Like Electrical Wires?
1. **Fundamental Differences in Transmission Medium and Mechanism**
2. **Destruction of Optical Properties by Cutting**
### II. If a Fiber Optic Patch Cord is Broken or Must Be Spliced, How Should It Be Handled?
If a fiber optic patch cord suffers physical damage or needs to be cut and re-spliced, professional optical engineering equipment must be used for precision handling:
1. **Fusion Splicing** : Use stripping tools to remove protective jackets and coatings, clean the fiber with high-purity anhydrous alcohol, use a precision fiber cleaver to create a flat 90^\circ perpendicular end face, then place it in a fiber fusion splicer. After micron-level optical alignment, apply an electric arc discharge to fuse the two quartz glass ends together, and cover with a heat-shrink protective sleeve.
2. **Re-fabricating Connectors/Splicing Pigtails** : Since fiber optic patch cords are equipped with precision ceramic ferrule connectors (e.g., FC/APC, LC/PC) at both ends, if a connector is damaged, it is usually necessary to cut it and splice in a pigtail with a factory-grade polished end face, or use an on-site mechanical splice (cold connector).
### III. Standard Engineering Methods for Handling Overly Long Fiber Optic Patch Cords
In actual cabling and experimental setups, if a patch cord is longer than the actual required distance, the following standard procedures should be followed:
1. **Proper Cable Coiling (Winding)**
2. **Customizing Standard Lengths as Needed**
In the Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) product line, fiber optic patch cords support complete length customization services from 10\text{cm} to several hundred meters, effectively avoiding issues with redundant or overly long patch cords causing coiling difficulties at the source. For example, the [OFSCN® Standard Fiber Patch Cord](https://www.ofscn.org/patch-cords/standard-fiber-patch-cord.html) uses standard PC/APC precision polished ferrules and robust protective jackets, suitable for optical connections in laboratories and industrial field sites. More patch cord specifications can be found in the [OFSCN® Fiber Patch Cords Products](https://www.ofscn.org/patch-cords.html).
 ![OFSCN® Standard Fiber Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/29a3314a988d84e6fa5fddb8d5feb15cb3766256.jpeg)
