# 光纤能承受多高的电压？ | How much voltage can an optical fiber withstand?
**URL:** <https://forum.ofscn.net/t/how-much-voltage-can-an-optical-fiber-withstand/2743>\
**Created:** [September 5, 2026, 2:03pm UTC](https://forum.ofscn.net/t/how-much-voltage-can-an-optical-fiber-withstand/2743 "2026-09-05T14:03:43Z")\
**Post date:** [September 5, 2026, 2:03pm UTC](https://forum.ofscn.net/t/how-much-voltage-can-an-optical-fiber-withstand/2743/1 "2026-09-05T14:03:43Z")
It is an insulator, so can it withstand 100,000 volts of high voltage?
**Post date:** [September 5, 2026, 2:04pm UTC](https://forum.ofscn.net/t/how-much-voltage-can-an-optical-fiber-withstand/2743/2 "2026-09-05T14:04:00Z")
From the perspectives of physical principles and high-voltage insulation engineering, **all-dielectric quartz optical fibers can completely withstand high voltages of 100 kV axially**. This is one of the core reasons why fiber optic sensing and communication are widely used in UHV substations, inside transformer windings, and on transmission lines (such as ADSS all-dielectric optical cables, optical voltage/current transformers).
However, in practical high-voltage engineering applications, the ability to withstand 100\ \text{kV} high voltage depends on the following physical boundaries and insulation conditions:
### 1. Dielectric Strength of Silicon Dioxide and Polymer Coating (Bulk Breakdown)
- **Quartz Glass (\text{SiO}\_2)**: The bulk dielectric strength of high-purity silica is extremely high, with a breakdown field strength typically ranging from 15 \sim 30\ \text{kV/mm} (even higher in microscopic thin-film forms) and a volume resistivity greater than 10^{14}\ \Omega\cdot\text{cm}, making it an excellent solid insulating medium.
- **Coating Material** : Standard UV-cured Acrylate or high-temperature Polyimide coatings are also highly resistive insulating polymers and are not conductive.
### 2. Key Engineering Factors Determining Voltage Withstand Capability
Although the intrinsic material insulation performance is excellent, when a 100\ \text{kV} potential difference is applied, insulation failure is usually not caused by breakdown within the fiber itself. Instead, it depends on the external electric field distribution and insulation distance:
1. **Axial Effective Insulation Length and Surface Flashover**
  - The breakdown field strength of air is approximately 3\ \text{kV/mm} (at standard atmospheric pressure and dry air). If the optical fiber spans a potential difference of 100\ \text{kV}, the **axial physical length and creepage distance of the fiber must be sufficiently long**.
  - If 100\ \text{kV} high voltage is applied across only a few centimeters or even millimeters of the fiber ends, an arc will flash over and discharge directly along the outer surface of the fiber or by breaking down the air. In high-voltage power equipment, isolating potential levels of 110\ \text{kV} typically requires effective insulation distances of several meters, along with insulating bushings or petticoat designs at wall/line entry points.
2. **Radial Withstand Voltage Limit**
  - The outer diameter of a standard single-mode fiber cladding is 125\ \mu\text{m}, and the outer diameter of the coating is 250\ \mu\text{m} (insulating wall thickness is only tens of micrometers). It is strictly prohibited to apply 100\ \text{kV} high voltage directly across the **radial cross-section** of the fiber (e.g., between the fiber core and a conductive material directly touching the fiber jacket), as the extremely high electric field gradient will instantaneously break down the radial insulation layer, which is only tens of micrometers thick.
3. **Fiber Packaging Structure (Must be All-Dielectric)**
  - In a high-voltage strong electric field environment, **any fiber product containing metal components is strictly prohibited** (e.g., stainless steel seamless armored patch cords, optical cables with metallic strength members, or metal-coated fibers), as metallic structures will distort the electric field and cause high-voltage arcing and short circuits.
  - **All-dielectric** non-metallic structures must be used (e.g., pure glass fiber, PEEK/PTFE/PFA insulating sheaths, and non-metallic strength members).
4. **Surface Cleanliness and Humidity**
  - If the fiber surface is contaminated with moisture, dust, or salt spray in a high-voltage environment, it will significantly reduce the surface insulation resistance and induce partial discharge or even carbonized breakdown along the surface. When used inside high-voltage power equipment, it must be kept in a dry, clean environment or immersed in insulating media such as transformer oil.
### Summary
Under conditions of **sufficient axial insulation distance** , **clean and dry surfaces** , and the **absence of metallic structures** , it is entirely feasible and a mature technology for pure quartz and all-dielectric encapsulated optical fibers to withstand electrical insulation isolation at 100\ \text{kV} and even higher voltage levels.
