# Is optical fiber coating concentricity important?
**URL:** <https://forum.ofscn.net/t/is-the-concentricity-of-the-optical-fiber-coating-important/2424>\
**Created:** [July 29, 2026, 12:03pm UTC](https://forum.ofscn.net/t/is-the-concentricity-of-the-optical-fiber-coating-important/2424 "2026-07-29T12:03:04Z")\
**Post date:** [July 29, 2026, 12:03pm UTC](https://forum.ofscn.net/t/is-the-concentricity-of-the-optical-fiber-coating-important/2424/1 "2026-07-29T12:03:04Z")
If the connector is misaligned, causing the fiber core to be off-center, what are the consequences?
**Post date:** [July 29, 2026, 12:03pm UTC](https://forum.ofscn.net/t/is-the-concentricity-of-the-optical-fiber-coating-important/2424/2 "2026-07-29T12:03:44Z")
In the fields of optical communication and optical fiber sensing, the “shifted sheath, off-center core” you mentioned actually corresponds to two different physical quantities: **Core-to-Cladding Concentricity Error** and **Coating-to-Cladding Concentricity Error**. Deviations in either of these can lead to very serious negative consequences for fiber transmission performance, mechanical lifespan, and subsequent sensor fabrication.
Below is an analysis of the specific physical consequences from an academic and engineering perspective:
### I. Core-to-Cladding Concentricity Error
This refers to the deviation of the optical **core** of the fiber from the geometric center of the **silica cladding**.
#### 1. Drastically Increased Splice Loss
In fiber optic engineering, fusion splicers are divided into “cladding alignment” and “core alignment” types. If the core-to-cladding concentricity is poor, even if the outer diameter of the cladding is perfectly aligned, there will be a lateral offset between the two cores, leading to significant optical power coupling loss.
The additional loss caused by lateral offset in single-mode fibers can be approximately estimated by the following formula:
\eta = \exp\left( - \frac{d^2}{w^2} \right)
Where d is the lateral offset between the axes of the two cores, and w is the mode field radius. Since the mode field diameter of a single-mode fiber is only about 9\ \mu\text{m}, even a 1\ \mu\text{m} concentricity deviation can introduce non-negligible additional insertion loss.
#### 2. Active Connector (Adapter) Misalignment
In active fiber optic connectors such as FC/APC and LC, the connector ferrule relies on the outer diameter of the glass fiber (125\ \mu\text{m}) for physical positioning. If the core is eccentric, regardless of the mechanical precision of the connector ferrule, the core cannot be properly centered during alignment, resulting in poor connection loss (Insertion Loss) and return loss.
### II. Coating-to-Cladding Concentricity Error
This refers to the deviation of the outer **polymer protective coating** from the inner **silica cladding**. This is the most typical case of a “shifted sheath.”
#### 1. Reduced Mechanical Fatigue Life and Fracture Risk (Mechanical Reliability)
The primary function of the coating (e.g., polyacrylate or polyimide) is to provide mechanical protection and isolate external moisture from the air. If the coating is significantly eccentric, the thinner side is highly susceptible to external stress, micro-abrasion, or chemical attack. Moisture penetrating the silica surface accelerates subcritical crack growth in the glass (Micro-cracks), leading to brittle fracture of the fiber on the thin side when bent or subjected to tensile stress.
#### 2. Difficulty in Stripping and Surface Scoring (Stripping Damage)
When using standard stripping tools (like Miller pliers) to remove the coating, the circular cut made by the blade is designed based on the standard cladding diameter (125\ \mu\text{m}) and concentricity of the outer diameter. If the coating is eccentric, the thinner side of the stripping blade can easily come into direct contact with and score the surface of the silica cladding, leaving critical microscopic scratches.
#### 3. Temperature-Induced Additional Loss and Asymmetric Thermal Stress (Microbending Loss)
The thermal expansion coefficients (CTE) of the polymer coating and the silica glass differ by one to two orders of magnitude. When the ambient temperature fluctuates significantly, the radial thermal contraction force exerted by the eccentric coating on the glass becomes asymmetrically distributed, leading to uneven stress within the fiber and causing microbending. This results in additional loss that varies with temperature (temperature-induced loss).
### III. Additional Impact on Fiber Bragg Gratings (FBG) and Sensing Applications
Concentricity errors are a major taboo in the fabrication of high-precision fiber Bragg grating sensors:
1. **Birefringence from Asymmetric Recoating**
When writing FBGs, the original coating is typically stripped, and the fiber is recoated after writing. If the recoating mold is misaligned, resulting in poor coating concentricity, the asymmetrical lateral stress applied to the fiber during coating solidification and shrinkage will induce unintentional birefringence. This causes the grating spectrum to split, increases polarization-dependent loss (PDL), and prevents Fiber Bragg Grating interrogators from accurately extracting the wavelength.
2. **Degraded Coaxial Alignment in Sensor Packaging**
When packaging optical fibers into miniature metal protective tubes (such as seamless steel tubes), if the coating is eccentric, the fiber will also be off-center within the steel tube. After the adhesive is cured, the shear force distribution from temperature and strain transfer becomes uneven, reducing the sensor’s measurement linearity and fatigue life.
### OFSCN® High-Precision Fiber and Grating Related Products：
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) strictly controls the precision of preforms and drawing dies to ensure that its fiber products possess industry-leading concentricity indicators, thereby avoiding the aforementioned engineering hazards:
- **OFSCN® G.652D Optical Fiber**
Standard single-mode optical fiber with core-to-cladding concentricity deviation controlled within \le 0.5\ \mu\text{m}, ensuring extremely low splice loss and high mechanical strength.
[Accurate Product Name](https://www.ofscn.org/optical-fibers/g-652-d.html)
 ![OFSCN® G.652D Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/b9e7425657de6a7b2f925b3028f3e886b0414767.jpeg)
- **OFSCN® Polyacrylate Fiber Bragg Gratings / FBG Strings (Bare)**
Recoated with high-quality polyacrylate material using precision process control, ensuring good concentricity in the recoated grating section to avoid asymmetric polarization-dependent characteristics.
[Accurate Product Name](https://www.ofscn.net/fbg-products/smf28e-fbg.html)
 ![OFSCN® Polyacrylate Fiber Bragg Gratings](https://forum.ofscn.net/uploads/default/original/1X/e7542065306866bef8a514e5646eb2a720c4aeb9.jpeg)
- **OFSCN® 300℃ SM Polyimide Optical Fiber**
High-precision, high-temperature resistant single-mode optical fiber with polyimide coating. The coating outer diameter is a compact 155\ \mu\text{m}. The extremely high concentricity ensures that it remains unaffected by microbending loss even under extreme temperature fluctuations of 300^\circ\text{C}.
[Accurate Product Name](https://www.ofscn.org/optical-fibers/polyimide-coated-sm-300.html)
 ![OFSCN® 300℃ SM Polyimide Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/ce90be3e4b9bb517d521f23c595dfb4d1985b218.jpeg)
