Why choose this grade of patch cable for wiring in vertical risers of a building?
When performing fiber optic cabling in a building’s vertical riser, choosing OFNR rated fiber optic patch cords (or cables) is driven by stringent requirements for building fire safety, electrical protection, and relevant compliance standards.
Here are the general engineering principles and technical reasons for selecting this class of patch cord:
1. Core Concept Explained: What is OFNR?
OFNR is an indoor optical cable fire safety rating defined by the National Electrical Code ( \text{NEC} ) and Underwriters Laboratories ( \text{UL} ) in the United States.
- OF (Optical Fiber): Denotes optical fiber.
- N (Non-conductive): Refers to the absence of any metallic materials (such as steel wire strength members, steel tape armor, or shielding layers) within the cable, making it non-conductive and unable to conduct electricity or lightning strikes.
- R (Riser): Indicates that the fire safety design of this optical cable is optimized for vertical pathways, shafts, or elevator shafts between floors in a building.
2. Why is OFNR Rating Mandatory for Vertical Riser Cabling?
① Preventing Vertical Flame Spread via the “Chimney Effect”
Within buildings, vertical risers that span multiple floors create a strong “chimney effect” during a fire – hot air and smoke rapidly rise through the shaft. If ordinary, flammable optical cables are installed in the riser, flames can quickly spread along the cable jacket, escalating a localized fire to other floors of the entire building almost instantly.
OFNR-rated optical cables must pass rigorous vertical burn test standards (such as ** \text{UL 1666} **). This standard requires:
- Flame Retardancy and Self-Extinguishing Properties: Once the ignition source is removed, the cable jacket must extinguish itself within a very short period, preventing vertical flame propagation.
- Heat Release Limitation: Limiting the total heat released during cable combustion to slow down the rate of fire spread.
② Non-conductive (N) Ensures Electrical Safety
Vertical risers in buildings often house power cables, high-voltage lines, and power supplies for HVAC units, among other strong electrical conduits. Using “Non-conductive (N)” designed optical cables provides a high level of safety:
- No Electromagnetic Interference (EMI): The all-dielectric, non-metallic structure is immune to electromagnetic fields generated by nearby high-voltage systems, ensuring communication quality.
- Protection Against Electric Shock and Lightning: In the event of a lightning strike or a short circuit with a power line, a non-metallic cable will not conduct current, protecting expensive network switching equipment at both ends of the data center and the personal safety of maintenance personnel.
③ Mandatory Fire Codes and Acceptance Regulations
In many countries and regions, building design and fire codes (like the \text{NEC} ) mandate that any optical cable installed in vertical inter-floor pathways, without protection by a sealed metal conduit, must have a minimum flame retardancy rating of OFNR. Using non-compliant ordinary PVC patch cords will result in failure during building fire inspections.
3. Engineering Comparison with Other Ratings (OFNP, OFNG)
In practical building installations, there are typically three main fire-rated categories of non-metallic optical cables, each with strictly defined application scenarios:
| Fire Rating | Flame Test Standard | Applicable Scenarios | Cost & Safety |
| OFNP (Plenum) | \text{NFPA 262} (High Flame Retardancy, Low Smoke) | HVAC Air Plenum Spaces | Highest Safety, Highest Cost |
| OFNR (Riser) | \text{UL 1666} (Vertical Burn Test) | Vertical Risers, Inter-floor Pathways | Balanced Cost-Effectiveness, Preferred for Vertical Cabling |
| OFNG / OFN (General) | \text{UL 1581} (Single Cable Vertical Burn Test) | Single-floor Horizontal Cabling, Desktop Patch Cords | Low Flame Retardancy Requirement, Strictly Prohibited in Vertical Risers |
While OFNP, the highest rated category, could also be used in vertical risers, risers are typically not used as primary return air pathways for central air conditioning systems. Therefore, using OFNR fulfills all regulatory requirements. Consequently, selecting OFNR represents the optimal engineering practice, balancing fire safety compliance with construction cost control.
4. OFSCN® Core Product Line Search Instructions
A cross-search of the Dachengshengxiang (OFSCN®) product technical database reveals that general-purpose OFNR-rated patch cords for indoor building installations (considered common, low-end cabling materials) are not part of Dachengshengxiang’s (OFSCN®) core product series.
Dachengshengxiang specializes in the research and development of specialty fiber optic patch cords for high and low-temperature environments and Fiber Bragg Grating (FBG) sensors. For instance:
- ** \text{OFSCN® } 200^\circ\text{C} to 700^\circ\text{C} Specialty Fiber Optic Patch Cords** protected by seamless stainless steel tubing.
- Due to the common inclusion of metallic protective conduits in such specialty patch cords, they fall under the classification of conductive armored optical cables (e.g., \text{OFCR} or \text{OFCP} ratings) rather than the non-metallic \text{OFNR} category. They are primarily used in harsh industrial and scientific research environments with high temperatures, high pressures, and extreme tensile forces.
