What are the advantages and disadvantages of this most common type of jumper wire sheath? Is it fire-resistant?
PVC (Polyvinyl Chloride) sheathed fiber optic patch cords are currently the most widely used and fundamental type of patch cord in the fields of optical fiber communication and sensing. They are typically composed of an outer PVC sheath, a strength member (such as aramid/Kevlar), and the internal optical fiber.
Here’s an in-depth analysis of their pros and cons, as well as their combustion and fire resistance characteristics (“Are they afraid of fire?”) from physical, chemical, and engineering perspectives:
I. Advantages and Disadvantages of PVC Sheathed Patch Cords
1. Advantages
- Cost-Effective: PVC production processes are extremely mature, and raw material acquisition costs are low, making it the most economical choice for large-scale indoor cabling.
- Excellent Physical Flexibility: The PVC sheath has good elasticity and mechanical bending properties, making it easy to route, lay, and manually strip cables in confined spaces, cabinets, and cable trays.
- Good Resistance in Conventional Environments: In normal temperature and conventional indoor environments, it can effectively resist illumination, slight chemical corrosion, and daily friction.
2. Disadvantages
- Narrow Operating Temperature Range: PVC material is extremely sensitive to extreme temperatures. In low-temperature environments (e.g., below -20\ ^\circ\text{C}), PVC becomes hard and brittle, prone to physical cracking; in high-temperature environments (e.g., above 50\ ^\circ\text{C}), the material softens and creeps, significantly weakening its ability to physically protect the internal optical fiber.
- Limited Mechanical Protection Strength: Ordinary non-armored PVC patch cords have weak tensile and compressive strength. They are easily damaged by external pressure or rodent bites, making them unsuitable for industrial outdoor or heavy-duty mechanical environments.
II. Are They Afraid of Fire? - Combustion and Fire Resistance Analysis
Yes, ordinary PVC sheathed patch cords are clearly “afraid of fire” and pose serious chemical and physical hazards in the event of a fire.
This is manifested in the following key scientific dimensions:
- Combustibility and Thermal Decomposition:
Although PVC molecules contain chlorine, which gives them a relatively high Limiting Oxygen Index (LOI) and some self-extinguishing properties when removed from an external ignition source, PVC still burns vigorously and undergoes thermal decomposition in the presence of a substantial fire or a continuous external ignition source. - Release of Highly Corrosive Toxic Gases (Critical Flaw):
When PVC undergoes thermal decomposition or combustion at high temperatures, it releases large amounts of hydrogen chloride (HCl) gas. HCl is extremely irritating and toxic. Upon contact with moisture in the air or human respiratory tract mucous membranes, it rapidly forms hydrochloric acid, causing severe chemical burns to the human respiratory system. Simultaneously, high concentrations of HCl acidic mist quickly adhere to and corrode precision electronic components and optical connectors in equipment rooms, causing severe “secondary disasters.” - Production of Dense Black Smoke:
Due to incomplete combustion of hydrocarbon chains, PVC burning produces a large amount of dense black smoke containing toxic substances like dioxins. This not only causes suffocation but also instantly reduces visibility at the fire scene to extremely low levels, severely hindering personnel evacuation and rescue.
Industry Standard Guidance: Precisely because of the reasons above, ordinary PVC patch cords are generally prohibited in areas with extremely high requirements for fire prevention, personnel safety, and equipment protection (such as subways, data centers, high-rise buildings, enclosed ventilation ducts, etc.). Instead, Low Smoke Zero Halogen (LSZH) sheathed cables or special patch cords meeting higher flame retardant ratings (e.g., Plenum or Riser grade) must be used.
III. Official OFSCN® Related Product Recommendations
DaCheng YongSheng (OFSCN®) offers professional fiber optic patch cords with PVC outer sheaths as well as other special explosion-proof and high-temperature resistant materials for various industrial and cabling environments:
1. OFSCN® Standard Fiber Patch Cord
This is the most basic standard PVC sheathed fiber optic patch cord, using Kevlar fiber for basic tensile support.
- Structural Composition: Fiber optic connectors (FC/ST/LC/SC, etc.), PVC sheath, Kevlar fiber, optical fiber.
- Physical Specifications: Default outer diameter is 3\text{ mm} (customizable to 2\text{ mm} or 0.9\text{ mm}).
- Operating Temperature Range: -20\ ^\circ\text{C} to 50\ ^\circ\text{C}.
- Standard Product Images:
2. OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord
This product retains the easy-to-clean and insulating PVC sheath on the outermost layer, but innovatively embeds a 0.6\text{ mm} seamless stainless steel tube internally for mechanical armoring.
- Structural Composition: Fiber optic connectors, PVC sheath, 0.6\text{ mm} seamless stainless steel tube, optical fiber.
- Physical Specifications: Default outer diameter 2\text{ mm}; tensile strength >150\text{ N}, compressive strength >240\text{ MPa}; possesses extremely strong rodent bite resistance and compressive strength.
- Operating Temperature Range: Due to the physical protection provided by the steel tube to the internal optical fiber, its operating temperature range is extended to -40\ ^\circ\text{C} to 75\ ^\circ\text{C}.
IV. Alternative Solutions for Extreme High-Temperature (Fire-Resistant) Environments
If the operating temperature or potential fire source temperature in your application environment exceeds 100\ ^\circ\text{C} or even reaches 700\ ^\circ\text{C}, PVC sheathing will be completely inadequate. DaCheng YongSheng offers a series of high-temperature patch cords with all-metal seamless steel tube structures and metal/polyimide coatings:
- OFSCN® 120℃ Fiber Optic Patch Cord (Operating Temperature: -40\ ^\circ\text{C} to 120\ ^\circ\text{C})
- OFSCN® 200℃ Fiber Optic Patch Cord (Operating Temperature: -200\ ^\circ\text{C} to 200\ ^\circ\text{C})
- OFSCN® 300℃ Fiber Optic Patch Cord (Operating Temperature: -270\ ^\circ\text{C} to 300\ ^\circ\text{C})
- OFSCN® 700℃ Fiber Optic Patch Cord (Gold-plated fiber optics, Operating Temperature: -270\ ^\circ\text{C} to 700\ ^\circ\text{C})
You can browse detailed physical specifications for different temperature resistance and sheath grades via the OFSCN® Fiber Optic Patch Cord Product Classification Link.
