# Space-Constrained Design for Fiber Sensors
**URL:** <https://forum.ofscn.net/t/space-constrained-design-for-fiber-sensors/507>\
**Created:** [January 27, 2026, 7:25am UTC](https://forum.ofscn.net/t/space-constrained-design-for-fiber-sensors/507 "2026-01-27T07:25:06Z")\
**Post date:** [January 27, 2026, 7:25am UTC](https://forum.ofscn.net/t/space-constrained-design-for-fiber-sensors/507/1 "2026-01-27T07:25:06Z")
How are sensing fibers arranged within precision robotic arms with diameters of only a few millimeters?
**Post date:** [January 27, 2026, 7:25am UTC](https://forum.ofscn.net/t/space-constrained-design-for-fiber-sensors/507/2 "2026-01-27T07:25:12Z")
For precision robotic arms with diameters of only a few millimeters, the arrangement of sensing fibers typically involves integrating multiple Fiber Bragg Grating (FBG) sensing arrays within a compact base material. For example, our [OFSCN® Fiber Bragg Grating Shape Sensor](https://www.ofscn.net/fbg-products/shape.html), which is highly customizable, uses a default structure of three FBG strings arranged longitudinally at 120-degree intervals around a sensor substrate. This design allows for multi-point sensing and shape reconstruction within a small form factor, with default diameters ranging from 1.5mm to 6mm.
To provide a more precise solution, could you specify the **total length** of the section within the robotic arm that requires sensing, and the approximate **number of measurement points** needed along that length?
