Structural Imperfection Loss
How do core diameter fluctuations or bubbles cause optical signal scattering?
Core diameter fluctuations and bubbles within an optical fiber cause optical signal scattering due to changes in the refractive index and physical geometry that disrupt the smooth propagation of light.
  1. Core Diameter Fluctuations: When the fiber core diameter varies along its length, the waveguide structure changes. Light propagating through the fiber experiences these variations as microscopic imperfections. This leads to Rayleigh scattering, where the light interacts with these small, randomly distributed inhomogeneities (on a scale smaller than the wavelength of light). As light encounters regions of different refractive indices (due to the varying core diameter), a portion of it is scattered in all directions, leading to signal loss. The efficiency of light guiding is compromised, and some light can escape the core or be backscattered.
  2. Bubbles (Voids): Bubbles within the fiber material represent discrete, larger inhomogeneities where the refractive index changes abruptly from that of the glass to that of air (or vacuum). When light encounters a bubble, it undergoes Mie scattering. Mie scattering occurs when the size of the scattering particles (in this case, bubbles) is comparable to or larger than the wavelength of light. These bubbles act as strong scattering centers, diverting a significant portion of the optical signal out of the intended path, thereby attenuating the signal. Total internal reflection can also be disrupted at the bubble interface.
Both phenomena result in the loss of optical power, reducing the signal strength and potentially increasing noise, which is detrimental to the performance of fiber optic systems.
OFSCN® Polyacrylate Fiber Bragg Gratings / Fiber Bragg Grating Strings (bare) are manufactured using high-quality optical fibers to minimize such structural imperfections and ensure reliable optical performance.
