# What is the "TCP/IP protocol"?
**URL:** <https://forum.ofscn.net/t/tcp-ip-what-is-the-tcp-ip-protocol/2782>\
**Created:** [September 9, 2026, 4:14am UTC](https://forum.ofscn.net/t/tcp-ip-what-is-the-tcp-ip-protocol/2782 "2026-09-09T04:14:56Z")\
**Post date:** [September 9, 2026, 4:14am UTC](https://forum.ofscn.net/t/tcp-ip-what-is-the-tcp-ip-protocol/2782/1 "2026-09-09T04:14:56Z")
How do I transfer data from the demodulator to my own control room computer?
**Post date:** [September 9, 2026, 4:15am UTC](https://forum.ofscn.net/t/tcp-ip-what-is-the-tcp-ip-protocol/2782/2 "2026-09-09T04:15:04Z")
Data acquisition from Fiber Bragg Grating (FBG) Interrogators is typically transmitted to the central control room computer based on the standard **TCP/IP Industrial Ethernet network communication architecture**. The specific technical implementation paths and architecture are as follows:
### I. Physical Link and Network Configuration
1. **Physical Layer Connection** :
2. **IP Network Layer Configuration** :
### II. Data Transmission and Integration Methods
Depending on the management needs of the central control room and the type of host system, the following typical data integration methods can be employed:
#### 1. B/S Architecture (Direct Access via Web Browser)
Modern FBG interrogators usually have a built-in Web Server service:
- The central control room computer does not need to install any dedicated software. Simply use a mainstream browser to enter the interrogator’s IP address and the specified port.
- Real-time spectrum graphs, wavelength lists, demodulated physical quantities (such as temperature, strain, pressure), and system operating status can then be viewed remotely.
#### 2. C/S Architecture (Remote Connection via Dedicated Host Software)
- Deploy the interrogator’s accompanying client monitoring software on the central control room computer.
- The software establishes a persistent connection with the interrogator via the TCP/IP protocol to obtain high-speed data streams for local storage, multi-channel curve plotting, and historical report exporting.
#### 3. Industrial Communication Protocols and Secondary System Integration (DCS / SCADA / Custom Systems)
If a unified industrial control software (such as DCS, SCADA, or a custom-developed data center) is running in the central control room, data streams can be obtained through the following standard network communication protocols:
- **Socket Communication (TCP / UDP)**: By establishing a TCP Client/Server connection, the interrogator pushes the acquired FBG center wavelength \lambda\_{\text{B}} or the demodulated engineering physical quantities in binary stream or JSON/ASCII format to the central control room.
- **Modbus TCP Protocol** : The interrogator acts as a Modbus TCP Server, mapping the temperature and strain data of each channel and measurement point into Holding Registers, which can be periodically polled and read by the central control room’s PLC or SCADA system.
### III. Related Products and Specifications
[OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html)
 ![OFSCN® Fiber Bragg Grating Interrogator](https://forum.ofscn.net/uploads/default/original/1X/248718a63e2aa4cf7db24ad7a4df5ace79c95a05.jpeg)
- **Network Architecture Support** : Default B/S architecture software, supports C/S architecture software.
- **Communication Protocol Support** : Supports integration with third-party systems and central control room systems through standard protocols such as TCP, UDP, and Modbus.
- **Key Performance Indicators** : Wavelength range is typically 1525 \sim 1565\text{ nm} or 1528 \sim 1568\text{ nm}; channel counts support 4, 8, 16, and 32 channels; sampling frequency supports 10\text{ Hz} \sim 100\text{ Hz} (adjustable); wavelength resolution is 0.1\text{ pm} \sim 1\text{ pm}.
