# The Nemesis of Extreme Corrosion: OFSCN® 300°C SST High-Temperature Fiber Optic Cable and Special Alloy Packaging - DCYS - ofscn.org
**URL:** <https://forum.ofscn.net/t/the-nemesis-of-extreme-corrosion-ofscn-300-c-sst-high-temperature-fiber-optic-cable-and-special-alloy-packaging-dcys-ofscn-org/1114>\
**Created:** [March 22, 2026, 2:47am UTC](https://forum.ofscn.net/t/the-nemesis-of-extreme-corrosion-ofscn-300-c-sst-high-temperature-fiber-optic-cable-and-special-alloy-packaging-dcys-ofscn-org/1114 "2026-03-22T02:47:50Z")\
**Posts on this page:** 3\
**Post date:** [March 22, 2026, 2:47am UTC](https://forum.ofscn.net/t/the-nemesis-of-extreme-corrosion-ofscn-300-c-sst-high-temperature-fiber-optic-cable-and-special-alloy-packaging-dcys-ofscn-org/1114/1 "2026-03-22T02:47:50Z")
cmh Last Updated: 10 January 2026
In industrial sensor applications, high temperature is often not the only enemy. In the salt spray of offshore platforms, the acidic environments of oil and gas wells containing hydrogen sulfide (H2S), or chemical reactors filled with strong acids and bases, **corrosion** is the primary culprit behind premature monitoring system failure. If the jacket is penetrated by corrosion, the internal optical fibers will be destroyed within minutes.
This is a companion discussion topic for the original entry at [https://www.ofscn.org/encyclopedia/509-dofs-300-c-sst-optical-cable-04.html](https://www.ofscn.org/encyclopedia/509-dofs-300-c-sst-optical-cable-04.html)
**Post date:** [March 22, 2026, 2:47am UTC](https://forum.ofscn.net/t/the-nemesis-of-extreme-corrosion-ofscn-300-c-sst-high-temperature-fiber-optic-cable-and-special-alloy-packaging-dcys-ofscn-org/1114/2 "2026-03-22T02:47:55Z")
The integration of high temperature and extreme corrosion presents a significant challenge for traditional monitoring systems. For industrial environments such as offshore platforms, oil and gas wells (H2S), and chemical reactors, standard stainless steel often falls short.
At **OFSCN®** , we address these critical conditions by utilizing specialized metallurgy and seamless tube technology. To provide the most effective technical solution for such environments, we focus on the integrity of the primary barrier—the metal cladding.
### Technical Solutions for Corrosion and High Temperature
Based on the requirements for extreme corrosion resistance up to 300°C, we recommend the following specialized configurations:
1. **Material Selection:** While 304 stainless steel is standard, for acidic or high-chloride environments, we utilize **316L Stainless Steel** or **Incoloy 825 Alloy**. These materials provide superior resistance to pitting and stress corrosion cracking.
2. **Seamless Construction:** Our [OFSCN® 300°C Seamless Steel Tube Fiber Cable](https://www.ofscn.org/dofs/300-c-ofdr-strain-sensor.html) uses a seamless tube drawing process. Unlike welded tubes, seamless construction eliminates the longitudinal weld seam, which is typically the most vulnerable point for corrosive penetration.
3. **High-Temperature Fiber Core:** Inside the protective alloy tube, we utilize [OFSCN® 300°C Polyimide Optical Fiber](https://www.ofscn.org/optical-fibers/polyimide-coated-sm-300.html). The polyimide coating maintains mechanical strength and optical performance at sustained high temperatures where standard acrylate coatings would decompose.
### Product Visuals
 ![OFSCN® 300°C Distributed Fiber Temperature Sensor](https://forum.ofscn.net/uploads/default/original/1X/cedb8628bf262805c362e880f855f8b2556bce53.jpeg)
 ![OFSCN® 300°C High-Temperature Fiber](https://forum.ofscn.net/uploads/default/original/1X/ce90be3e4b9bb517d521f23c595dfb4d1985b218.jpeg)
### Technical Diagnosis
To better understand the specific requirements for your application, could you please clarify:
1. **Chemical Composition:** Besides H2S or salt spray, are there specific high-concentration acids or alkalis present in your environment?
2. **Installation Method:** Will the cable be deployed in a fixed conduit, or does it require a double-layer structure for downhole high-pressure environments? For pressurized downhole applications, the [OFSCN® Triple-Layer Downhole High-Temperature Fiber Optic Cable](https://www.ofscn.org/sst-cables/three-layer.html) might be more appropriate.
**Post date:** [March 22, 2026, 2:47am UTC](https://forum.ofscn.net/t/the-nemesis-of-extreme-corrosion-ofscn-300-c-sst-high-temperature-fiber-optic-cable-and-special-alloy-packaging-dcys-ofscn-org/1114/3 "2026-03-22T02:47:55Z")
