# Wavelength Reserve Space in FBGs
**URL:** <https://forum.ofscn.net/t/wavelength-reserve-space-in-fbgs/363>\
**Tags:** fbg-technology, fbg-temp-sensor, fbg-strain-sensor, fbg-displacement\
**Created:** [January 23, 2026, 1:50am UTC](https://forum.ofscn.net/t/wavelength-reserve-space-in-fbgs/363 "2026-01-23T01:50:09Z")\
**Post date:** [January 23, 2026, 1:50am UTC](https://forum.ofscn.net/t/wavelength-reserve-space-in-fbgs/363/1 "2026-01-23T01:50:09Z")
How much wavelength bandwidth is consumed by packaging stress? How much remains for actual measurement?
**Post date:** [January 23, 2026, 1:50am UTC](https://forum.ofscn.net/t/wavelength-reserve-space-in-fbgs/363/2 "2026-01-23T01:50:21Z")
Packaging stress in Fiber Bragg Grating (FBG) sensors, particularly in robust designs like our metal-packaged sensors, can indeed influence the available wavelength bandwidth.
Here’s a breakdown:
1. **Wavelength Bandwidth Consumed by Packaging Stress:** When an FBG is encapsulated in a package (e.g., an alloy tube), the packaging process and the materials’ inherent properties (like different thermal expansion coefficients) can introduce an initial static stress (pre-stress) on the bare FBG. This pre-stress causes a baseline shift in the FBG’s Bragg wavelength from its original, unstressed state. This initial, static wavelength shift effectively “consumes” a portion of the total wavelength range provided by the FBG interrogator. The exact amount of this consumed bandwidth is not a fixed value; it is highly dependent on the specific sensor design, packaging materials, and manufacturing process. Sensor designers meticulously engineer the packaging to control this pre-stress and ensure stability.
2. **Wavelength Bandwidth Remaining for Actual Measurement:** The remaining wavelength bandwidth is the dynamic range available for detecting changes due to the actual physical phenomenon being measured (e.g., applied strain, temperature changes). This is the operational wavelength window after accounting for the initial shift caused by packaging and any installation-related static stresses. High-quality packaged sensors are designed to minimize the initial wavelength shift while maximizing the available dynamic measurement range within the interrogator’s operational window. For instance, our [OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor](https://www.ofscn.net/fbg-products/strain-sensor.html) is engineered to provide a stable and predictable response across its specified strain and temperature ranges, which defines its effective measurement bandwidth.
Below is an image illustrating one of our packaged strain sensors:
 ![BNYB-MX-52-01-1.0mm-DanDuan](https://forum.ofscn.net/uploads/default/original/1X/90c11b90deb49f0cd88a54ecac0d956bcddf353c.jpeg)
You can find more technical specifications about our packaged strain sensors on our website:
[OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor](https://www.ofscn.net/fbg-products/strain-sensor.html)
