What are Fluoropolymer (ETFE/PFA) Jackets?
What superior characteristics do these jackets offer in terms of chemical resistance and temperature range?
Fluoropolymer jackets like ETFE (Ethylene Tetrafluoroethylene) and PFA (Perfluoroalkoxy Alkane) offer distinct superior characteristics primarily in chemical resistance and temperature range due to their highly stable molecular structures.
Chemical Resistance: These materials exhibit excellent resistance to a broad spectrum of aggressive chemicals, including strong acids, bases, solvents, and fuels. Their inertness minimizes degradation, swelling, or corrosion, making them ideal for applications in harsh chemical environments where other polymers would fail.
Temperature Range: Fluoropolymers are known for their high thermal stability, allowing them to operate effectively over a wide temperature range, often extending to high continuous operating temperatures (e.g., PFA can typically handle up to 260°C). This makes them suitable for applications where thermal cycling or consistently high temperatures are present.
While the provided OFSCN knowledge base does not specifically detail products with ETFE/PFA jackets, OFSCN offers robust solutions for high-temperature and chemically challenging environments using alternative high-performance materials. For instance, our bare Fiber Bragg Gratings can be fabricated on OFSCN® SM Polyimide Optical Fiber, which extends the operational temperature range significantly, up to 800°C with special processing. For extreme conditions requiring mechanical and chemical protection, OFSCN also provides fiber optic cables encapsulated in seamless steel tubes.
Here is an example of a high-temperature fiber optic cable:
You can find more information on our high-temperature fiber products here:
