# What are "installation space constraints"?
**URL:** <https://forum.ofscn.net/t/what-are-installation-space-constraints/3110>\
**Created:** [October 22, 2026, 8:12am UTC](https://forum.ofscn.net/t/what-are-installation-space-constraints/3110 "2026-10-22T08:12:34Z")\
**Post date:** [October 22, 2026, 8:12am UTC](https://forum.ofscn.net/t/what-are-installation-space-constraints/3110/1 "2026-10-22T08:12:34Z")
How can a jumper be passed through a gap that is only 5 mm wide?
**Post date:** [October 22, 2026, 8:13am UTC](https://forum.ofscn.net/t/what-are-installation-space-constraints/3110/2 "2026-10-22T08:13:14Z")
In fiber optic sensing and fiber optic communication engineering, encountering a slit with a width of 5\text{ mm} falls under the typical issue of **Installation Space Constraints**.
The key to resolving this problem lies in understanding that: **the spatial bottleneck is usually not the “cable body” of the patch cord, but the “fiber optic connectors (Connectors)” pre-installed at both ends of the patch cord**.
### I. Geometric Dimension Bottleneck Analysis
| Component / Connector Type | Typical Outer Diameter / Dimension | Can it Directly Pass Through a 5\text{ mm} Slit? |
| **Standard Patch Cord Cable** | Outer Diameter \Phi 2.0\text{ mm} \sim 3.0\text{ mm} | **Yes** |
| **Micro-Armored Cable** | Outer Diameter \Phi 0.9\text{ mm} \sim 2.0\text{ mm} | **Absolutely Yes** |
| **FC / ST Connector** | Outer Diameter Approx. \Phi 9.5\text{ mm} \sim 10.0\text{ mm} | **Cannot Pass** (Dimension Severely Exceeds Limit) |
| **SC Connector** | Section Approx. 9.0\text{ mm} \times 7.5\text{ mm} | **Cannot Pass** |
| **Simplex LC Connector** | Main Body Approx. 4.5\text{ mm} \times 4.5\text{ mm} | **Barely / Extremely High Risk** (Including clips, dust caps, and the entry angle, it is highly likely to get stuck and abrade the ceramic ferrule end face) |
### II. Standard Engineering Solutions
When faced with a 5\text{ mm} gap, standard engineering methods typically include:
#### 1. “Pull Cable First, Weld Later” Solution (Most Recommended in Engineering)
- **Principle** : Instead of using pre-fabricated patch cords with connectors at both ends, use “pigtails with a pre-fabricated connector at one end” or “custom armored fiber optic cables without connectors at either end.”
- **Implementation Steps** :
  1. Pass the end of the fiber optic cable without a connector (the non-connectorized end) through the 5\text{ mm} slit;
  2. After passing through to an open area, use fiber optic stripping pliers to remove the protective sheath, and then use a fiber optic fusion splicer to splice a standard fiber optic connector (pigtail) on-site;
  3. Protect the splice point with a heat-shrinkable tube and arrange it within a protection box.
- **Advantages** : Provides the highest connector optical performance (insertion loss, return loss), and the end face is not subject to contamination or scratches during passage through the slit.
#### 2. On-Site Field Assembly Kit Solution (Fusion Splicing Free)
- **Principle** : Purchase field-assemblable fiber optic connector kits (loose parts).
  1. Only pass the fiber optic cable with the protective tube;
  2. After passing through the 5\text{ mm} slit, assemble the loose connector body, ferrule, and housing on-site using crimping tools (e.g., field-embedded fiber fast connectors or field-crimp connectors).
- **Note** : Field fast connectors typically have lower optical insertion loss and long-term environmental resistance compared to factory-fused/thermoset-ground connectors.
#### 3. Physical Protection Requirements During Slit Passage
- The edges of the slit often have sharp edges (e.g., sheet metal burrs, concrete sharp corners), which can easily cause:
  1. **Fiber Micro-bending Loss** : Extreme increase in optical attenuation due to squeezing;
  2. **Jacket Severance and Fiber Breakage** : Ordinary PVC/LSZH jacketed patch cords are prone to having their internal glass fiber cores cut during pulling.
- When pulling cables, install split protective corrugated tubes, Teflon sleeves, or use micro-armored fiber optic cables with high compressive and shear resistance at the slit.
### III. Micro-Structure Fiber Optic Cables for Small Spaces
For scenarios involving narrow slits, high-temperature resistance, and demanding mechanical protection, opt for fiber optic cables/patch cords with a seamless stainless steel tube micro-armored structure for the “pull first, connect later” operation:
- **[OFSCN® 300℃ Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/high-temperature-300.html)**: Default outer diameter is only **0.9\text{ mm}** , utilizing a single layer of seamless stainless steel tube encapsulation with built-in high-temperature resistant polyimide fiber. The outer diameter is far less than the 5\text{ mm} slit, offering extremely high resistance to side pressure and abrasion. It can be customized for delivery without connectors or with a single-end connector, specifically for post-passage splicing.
 ![OFSCN® 300℃ Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/0d3d3e9df6438484a2bf68af9c1f4d177cac5ec4.jpeg)
 ![OFSCN® 300℃ Fiber Optic Patch Cord Detail](https://forum.ofscn.net/uploads/default/original/1X/eff745ff12f8cc8cb270e0bc4603804754e47cf0.jpeg)
- **[OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-01.html)**: Outer diameter is **2.0\text{ mm}** , with a 0.6\text{ mm} seamless stainless steel micro-armor inside. While maintaining an extremely small outer diameter, it provides tensile and compressive mechanical protection.
 ![OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord Dual Ends](https://forum.ofscn.net/uploads/default/original/1X/c4f5c7c42f73224dc1b2375d81d32de5801427d6.jpeg)
To view more specifications, models, and connector options, please visit **[OFSCN® Fiber Optic Patch Cord Product Categories](https://www.ofscn.org/patch-cords.html)**.
