# What are the "geometric tolerances" of an optical fiber?
**URL:** <https://forum.ofscn.net/t/what-are-the-geometric-tolerances-of-an-optical-fiber/2774>\
**Created:** [September 9, 2026, 3:35am UTC](https://forum.ofscn.net/t/what-are-the-geometric-tolerances-of-an-optical-fiber/2774 "2026-09-09T03:35:31Z")\
**Post date:** [September 9, 2026, 3:35am UTC](https://forum.ofscn.net/t/what-are-the-geometric-tolerances-of-an-optical-fiber/2774/1 "2026-09-09T03:35:31Z")
Does uneven glass fiber thickness affect its tensile strength?
**Post date:** [September 9, 2026, 3:38am UTC](https://forum.ofscn.net/t/what-are-the-geometric-tolerances-of-an-optical-fiber/2774/2 "2026-09-09T03:38:03Z")
**Yes, non-uniformity in the glass fiber (quartz glass cladding/core) diameter significantly impacts the tensile strength and long-term mechanical reliability of optical fibers.**
Analyzing from the perspectives of material mechanics, brittle fracture mechanics, and manufacturing tolerances, the impact mechanisms are mainly reflected in the following aspects:
### 1. Cross-sectional Area Variation and Local Stress Concentration
According to the basic formula for tensile normal stress:
\sigma = \frac{F}{A} = \frac{4F}{\pi d^2}
- Where F is the axial tensile force applied to the fiber, d is the effective diameter of the glass fiber, and A is the cross-sectional area.
- **Weakest Link Effect** : When the fiber exhibits non-uniform thickness along its axis (e.g., local thinning or necking), the thinnest cross-section has the minimum cross-sectional area A. Under the same tensile force F applied to the entire fiber, the local tensile stress \sigma in the thinned area will rise sharply, reaching the critical fracture value for silica glass first.
### 2. Geometric Transition Abruptness and Stress Concentration Factor
When the fiber diameter fluctuates longitudinally, the transition regions between thicker and thinner sections form micro-geometric discontinuities (similar to steps or constrictions), leading to local stress concentration. The peak stress in the stress concentration region will be significantly higher than the average stress calculated based on the nominal diameter, greatly reducing the maximum dynamic tensile load the fiber can withstand.
### 3. Griffith Brittle Fracture and Microcrack Propagation
Quartz glass is a typical brittle material, and its fracture behavior follows the Griffith criterion for brittle fracture of microcracks:
\sigma\_f \propto \frac{K\_{IC}}{\sqrt{a}}
- Where K\_{IC} is the fracture toughness of the material, and a is the size of surface microcracks.
- In the fiber drawing process, diameter fluctuations (non-uniform thickness) are usually caused by unstable drawing tension, minor temperature field perturbations, or fluctuations in drawing speed. This unstable process can easily induce deeper microcrack defects or residual thermal stresses on the glass surface in thinner or transitional areas, directly reducing the fiber’s intrinsic fracture strength (Proof Test screening strength).
### 4. Non-uniform Coating Thickness and Protection Failure
The glass fiber is typically coated with acrylate, polyimide, or metallic coatings. If the glass fiber itself has non-uniform thickness:
- It will directly lead to deviations in the coaxiality and coating thickness of the coating layer along the axis.
- The coating layer cannot uniformly dissipate lateral pressure and longitudinal tensile strain, reducing the fiber’s fatigue life against mechanical stress (decreasing the stress corrosion susceptibility parameter n value) during cabling, installation, and bending operations.
### 5. Industry Standards and Geometric Tolerance Control
Precisely because geometric uniformity has a decisive impact on mechanical strength and splicing loss, International Telecommunication Union standards (e.g., ITU-T G.652, G.657) impose extremely stringent geometric tolerance requirements on standard single-mode optical fibers:
- **Cladding Nominal Outer Diameter** : Standard is 125\ \mu\text{m};
- **Cladding Diameter Tolerance** : Typically strictly controlled within \pm 0.7\ \mu\text{m} or better (e.g., \pm 0.5\ \mu\text{m});
- **Cladding Non-circularity** : Usually controlled within \le 0.7\%.
Strict control of geometric tolerances is not only to ensure low connection loss but also a fundamental prerequisite for ensuring that the entire reel of optical fiber does not break under a proof test of 100\ \text{kpsi} (approximately 0.7\ \text{GPa}) or higher.
### Reference to Standard Optical Fiber Products Involved
Standard communication optical fibers and specialty high-temperature optical fibers provided by Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) all adhere to strict geometric tolerance control specifications:
- [OFSCN® G.652D Optical Fiber](https://www.ofscn.org/optical-fibers/g-652-d.html)
- [OFSCN® 300℃ SM Polyimide Optical Fiber](https://www.ofscn.org/optical-fibers/polyimide-coated-sm-300.html)
