Besides yellow and orange, what other colors represent special performance?
In fiber optic communication and fiber optic sensing engineering, the color codes for fiber optic outer jackets and coatings primarily follow the TIA-598-C/D and international IEC 60304 standards.
The standard typically uses Yellow to identify standard single-mode fibers (e.g., OS1/OS2, ITU-T G.652.D / G.657), and Orange for traditional multimode fibers (e.g., OM1 with a core diameter of 62.5/125\ \mu\text{m} or OM2 with a core diameter of 50/125\ \mu\text{m}). In addition to these two basic colors, industrial standards and special engineering applications define the following colors to characterize specific physical properties and transmission performance:
I. Communication Cable Outer Jacket Standard Color Codes
- Aqua
- Corresponding Fiber : OM3 and OM4 (50/125\ \mu\text{m} laser-optimized multimode fibers).
- Performance Characteristics : Features a graded-index core optimized for 850\ \text{nm} Vertical-Cavity Surface-Emitting Lasers (VCSELs), supporting high-speed Ethernet short-reach data center interconnects at 10\ \text{Gbps}, 40\ \text{Gbps}, and 100\ \text{Gbps}.
- Erika Violet / Heather Violet
- Corresponding Fiber : OM4 multimode fiber specifically designated by European standards and ISO/IEC.
- Performance Characteristics : Achieves a Modal Effective Bandwidth (EMB) of \ge 4700\ \text{MHz}\cdot\text{km} (at 850\ \text{nm}), used for clear visual distinction from OM3 (Aqua) in engineering applications.
- Lime Green
- Corresponding Fiber : OM5 Wideband Multimode Fiber (WBMMF).
- Performance Characteristics : Designed for Short Wavelength Division Multiplexing (SWDM) technology, offering optimized dispersion and bandwidth performance across the 850\ \text{nm} \sim 953\ \text{nm} wavelength range. It enables multiplexed transmission from 100\ \text{Gbps} to 400\ \text{Gbps} over a single pair of multimode fibers.
- Blue
- Engineering Meaning : In special fiber optic patch cords, blue jackets are conventionally used to identify Polarization-Maintaining (PM) Fiber. In the 12-color sequence for indoor multifiber cables, blue corresponds to the 1st fiber.
- Black
- Performance Characteristics : Typically indicates outdoor, weather-resistant jacketing (e.g., High-Density Polyethylene (HDPE) or Cross-linked Polyolefin). The material is compounded with a high proportion of carbon black, providing excellent resistance to ultraviolet (UV) aging and weathering, making it widely used in direct burial, conduit, and aerial installations.
- Red
- Engineering Meaning : In building integrated cabling and industrial monitoring, red is usually used to identify fire alarm systems, emergency circuits, nuclear-grade or military special high-risk communication links, and special high-power industrial laser transmission patch cords.
