# What is a "factory inspection report"?
**URL:** <https://forum.ofscn.net/t/what-is-a-factory-inspection-report/2656>\
**Created:** [August 27, 2026, 1:48pm UTC](https://forum.ofscn.net/t/what-is-a-factory-inspection-report/2656 "2026-08-27T13:48:27Z")\
**Post date:** [August 27, 2026, 1:48pm UTC](https://forum.ofscn.net/t/what-is-a-factory-inspection-report/2656/1 "2026-08-27T13:48:27Z")
What rigorous tests does each sensor undergo?
**Post date:** [August 27, 2026, 1:48pm UTC](https://forum.ofscn.net/t/what-is-a-factory-inspection-report/2656/2 "2026-08-27T13:48:56Z")
Prior to the official “Factory Inspection Report” being generated, each Fiber Bragg Grating (FBG) and specialty optical fiber sensor undergoes a series of rigorous optical, mechanical, and thermal tests, along with high-precision calibration procedures. This ensures their long-term stability and measurement accuracy in extreme industrial or experimental environments.
The primary testing and quality assurance stages encompass the following core aspects:
### 1. Optical Characteristics and Spectral Integrity Testing (Optical Spectrum Testing)
Utilizing a high-resolution Optical Spectrum Analyzer (OSA) or a high-precision FBG interrogator, a comprehensive scan of the sensor’s microscopic optical parameters is performed:
- **Center Reflection Wavelength (\\lambda\_B) Verification**: Checks if the initial wavelength falls within the designed tolerance range (e.g., standard room temperature wavelength deviation controlled within \pm 0.2\text{ nm} to \pm 0.3\text{ nm}).
- **Reflectivity and Spectral Profile** : Tests the peak reflection power to ensure the reflectivity (e.g., \ge 70\% or specific low reflectivity custom values) meets design requirements, and that the peak shape is symmetrical without double peaks or abnormal broadening.
- **3\text{ dB} Bandwidth (3\text{ dB} Bandwidth)**: Confirms that the Full Width at Half Maximum (FWHM) is within the standard tolerance range (e.g., around 0.4\text{ nm}).
- **Side Mode Suppression Ratio (SMSR)**: Verifies the ratio of the main peak to side peaks in the reflection spectrum (typically requiring \text{SMSR} \ge 15\text{ dB}) to eliminate the risk of interrogation mode hopping caused by multi-peak interference.
- **Fiber Connector End-Face and Return Loss** : Inspects the topography and cleanliness of the ferrule end-face for connectors like FC/APC, and tests Insertion Loss (IL) and Return Loss (RL).
### 2. High and Low Temperature Treatment, Annealing, and Thermal Cycling Stability Testing (Thermal Annealing & Cycling)
To eliminate residual stress from manufacturing and packaging processes and to verify sensor reliability at extreme temperatures:
- **High-Temperature Annealing Stabilization Treatment (Thermal Annealing)**: For mid-to-high temperature sensors (e.g., 300\ ^\circ\text{C}, 500\ ^\circ\text{C}, or 800\ ^\circ\text{C} grades), pre-annealing in a high-temperature furnace for an extended period is essential. This accelerates the release of microscopic internal stresses between the packaging material and the optical fiber, eliminating initial thermal decay of the photoinduced refractive index modulation and preventing zero-point wavelength drift during initial customer use.
- **Thermal Cycling** : Multiple cycles of heating and cooling within the extreme operating temperature range (e.g., -40\ ^\circ\text{C} to 300\ ^\circ\text{C}) are performed to test the thermal expansion compatibility and fatigue resistance of the metal protective casing (seamless steel pipe/special alloy pipe) and the fiber interface.
### 3. Mechanical and Packaging Reliability Testing (Mechanical & Environmental Testing)
Rigorous verification of the sensor’s physical protection structure and mechanical force transmission characteristics:
- **Mechanical Tensile and Preload Testing** : Strain sensors undergo full-range cyclic loading tests (e.g., \ge 3000\ \mu\varepsilon, \ge 6000\ \mu\varepsilon, or large deformation range tests) to verify the hysteresis and zero-point repeatability of the sensing element during linear loading and unloading.
- **Mechanical Tensile/Compressive Strength Testing** : Verifies the tensile strength (e.g., \gt 150\text{ N}) and side pressure resistance of fiber patch cords and armored structures.
- **Hermeticity and Seal Pressure Testing** : Leak detection or pressure testing is performed on fully metal-sealed or vacuum-sealed connectors to ensure sealing integrity under high water pressure, high temperature and humidity, or high vacuum environments.
### 4. Sensing Coefficient Metrology and Factory Calibration (Calibration & Coefficient Calculation)
For every qualified sensor, a mapping relationship between wavelength and physical quantity must be established under controlled standard test conditions:
- **Temperature Calibration** : In a standard constant temperature metrology bath or a multi-point temperature-controlled furnace, discrete points of wavelength change with temperature are recorded. The temperature-wavelength response curve is then fitted (typically a linear or quadratic polynomial, in units of ^\circ\text{C}/\text{pm}).
- **Strain Calibration** : Known strains are applied on a standard micro-displacement strain calibration rig to calibrate the strain sensitivity coefficient (in units of \mu\varepsilon/\text{pm}).
### Summary
The **initial wavelength, reflectivity, side mode suppression ratio, calibration formulas, and sensitivity coefficients** listed in the Factory Inspection Report are the final stable data measured after all the aforementioned optical, thermal, and mechanical tests are completed. Only sensors that pass all rigorous tests and have undergone multi-polynomial calibration are issued an independently numbered inspection report and delivered for use.
