What is a "fiber optic coupler"?
If two jumper wires aren’t long enough, what can be used to connect them?
If two fiber optic patch cords are not long enough, a Fiber Optic Coupler can be used to connect them. In practical engineering and academic exchange, it is also often referred to as a Fiber Optic Adapter or Flange.
1. General Connection Principles and Methods
The core function of a fiber optic coupler is to achieve a temporary (detachable) connection between optical fibers.
  • Precision Alignment Principle: The fiber optic coupler contains a high-precision ceramic (zirconia) or metal micro-hole alignment sleeve. When two patch cords (such as common FC, SC, LC, ST connectors) are inserted into the coupler, the sleeve precisely aligns the fiber cores (the core diameter of standard single-mode fiber is only about 9\ \mu\text{m} ) at both ends to within micrometers ( \mu\text{m} ), allowing optical signals to be coupled from one fiber to another with extremely low loss.
  • End-face Matching (Crucial): When using a coupler to connect patch cords, it is essential to ensure that the end-face grinding types of the connectors at both ends are consistent. For example, an \text{FC/APC} connector (usually green, with an 8^{\circ} angled physical contact surface) must be connected to another \text{FC/APC} physical connector via an \text{FC/APC} coupler. Forcing a connection between an \text{APC} and a \text{PC/UPC} (usually blue, with a spherical physical contact end-face) will result in significant insertion loss (possibly greater than 3\ \text{dB} ) and high return loss.
  • Physical Specifications: The insertion loss (IL) of a high-quality single-mode fiber optic coupler is typically required to be \le 0.2\ \text{dB} , while the return loss (RL) depends on the connector end-face type (e.g., APC end-face mating typically has \ge 60\ \text{dB} ).
2. Industrial-Grade Solutions for Harsh Environments
In laboratories or regular indoor environments (below 65\ ^{\circ}\text{C} ), commercially available ordinary plastic or general-purpose metal fiber optic adapters are sufficient. However, in special industrial and extreme experimental scenarios such as high temperatures, vacuum, or high pressure, ordinary adapters may fail due to plastic aging, mismatch in material thermal expansion coefficients, or outgassing in a high vacuum.
For these demanding applications, OFSCN® has designed and manufactured passive connection devices that meet high technical specifications:
OFSCN® High Temperature Resistant Fiber Optic Adapter
Main Parameters and Technical Advantages:
  • High-Temperature Resistant Design: Utilizes special metal and high-temperature ceramic materials, supporting extreme operating temperatures up to 300\ ^{\circ}\text{C} .
  • High-Precision Mating: Offers various standard fiber interfaces such as \text{FC/APC-FC/APC} , ensuring exceptionally high axial and radial alignment accuracy even under thermal deformation, thus guaranteeing ultra-low additional loss.
If you need to view more related devices for high-temperature environments (such as high-temperature connectors, vacuum-sealed flanges, or optical splitters), please refer to their official categories:
