# What is a "fiber optic level gauge"?
**URL:** <https://forum.ofscn.net/t/what-is-a-fiber-optic-level-gauge/3172>\
**Created:** [October 28, 2026, 6:25am UTC](https://forum.ofscn.net/t/what-is-a-fiber-optic-level-gauge/3172 "2026-10-28T06:25:58Z")\
**Post date:** [October 28, 2026, 6:25am UTC](https://forum.ofscn.net/t/what-is-a-fiber-optic-level-gauge/3172/1 "2026-10-28T06:25:58Z")
How much oil is left in the tank, and how does fiber optics “see” it?
**Post date:** [October 28, 2026, 6:26am UTC](https://forum.ofscn.net/t/what-is-a-fiber-optic-level-gauge/3172/2 "2026-10-28T06:26:55Z")
In industrial scenarios such as oil tanks and storage tanks, optical fibers do not “visually observe” the liquid level like cameras. Instead, they **utilize optical principles to modulate physical quantities within the tank (such as abrupt changes in temperature fields, differences in heat dissipation rates, or static liquid pressure) into optical wave parameters, which are then converted into liquid level positions by a demodulation system**.
For the precise monitoring of liquid levels in flammable and explosive oil tanks, fiber optic sensing primarily relies on the following physical mechanisms to determine the liquid level accurately:
### I. Core Working Principle
#### 1. Vertical Temperature Gradient Method (Based on Multi-point Temperature Sensing Array)
This is one of the most widely applied methods for fiber optic liquid level measurement in engineering.
- **Physical Mechanism** : There are significant differences in specific heat capacity, thermal conductivity, and convective heat transfer characteristics between the oil (liquid phase) and the upper gas/oil vapor space (gas phase) in the tank. Under natural conditions, influenced by external diurnal temperature variations or feed-in temperatures, a distinct temperature step (i.e., a temperature gradient inflection point at the gas-liquid interface) exists between the liquid below the liquid surface and the gas above it.
- **Fiber Optic Sensing Implementation** : Deploy an array of temperature sensors encapsulated with multiple Fiber Bragg Gratings (FBGs) vertically along the tank wall. Each grating reflects a narrow-band light of a specific wavelength, satisfying the Bragg reflection wavelength equation:
(where n\_{\text{eff}} is the effective refractive index of the fiber core, and \Lambda is the grating period).
When the temperature changes, the wavelength shifts linearly due to the thermo-optic effect and thermal expansion effect:
\Delta \lambda\_B = K\_T \Delta T
The demodulation system obtains the temperature values at each measurement point along the vertical direction in real-time, reconstructing the temperature profile along the vertical direction. The inflection point where the slope of the curve changes corresponds to the actual height of the oil liquid level.
#### 2. Self-Heating/Thermal Diffusion Method (Active Thermal Type)
If the oil temperature and the gas temperature inside the tank have a small difference (in a state of complete thermal equilibrium), a low-power self-heating component (or heat tracing wire) can be integrated within the sensing tube:
- Liquids, due to their significantly higher convective heat transfer coefficient compared to still gas, dissipate heat at a much faster rate than gases.
- Sensing points below the oil level experience a smaller and slower temperature increase, while sensing points in the gas phase experience a larger and faster temperature increase. The demodulation system can accurately identify the interface position based on the sudden change in heating rate and equilibrium temperature difference.
#### 3. Liquid Static Pressure Conversion Method (Pressure Type)
- According to the hydrostatic formula for fluids:
P = \rho g h
(where P is the static pressure at the tank bottom, \rho is the oil density, g is the acceleration due to gravity, and h is the liquid level height).
- A fiber optic grating strain/pressure sensor is placed at the tank bottom or a specific reference height. The static pressure of the oil column causes deformation of the sensing diaphragm or elastic body, which in turn induces axial strain in the grating, leading to a wavelength shift. The liquid column height h is then calculated by inversion.
### II. Why is Fiber Optic Sensing the Preferred Choice for Oil Tank Monitoring?
1. **Intrinsic Safety** :
Fiber optics transmit weak laser signals in the microwatt to milliwatt range. The sensor probe and the entire transmission channel are **passive and non-electrical** , thus generating no sparks and eliminating the safety hazards of traditional electrical sensors causing explosions in Zone 0 / Zone 1 flammable and explosive gas environments.
2. **Electromagnetic Interference Immunity and Lightning Protection** :
Large metal storage tanks are tall outdoor structures susceptible to strong surge currents from lightning strikes. Fiber optic sensing media are completely immune to electromagnetic interference and are not damaged or prone to false alarms during lightning strikes.
3. **Chemical Corrosion Resistance and Long-Term Stability** :
Fiber optic encapsulation typically uses seamless steel pipes resistant to corrosion (such as stainless steel or corrosion-resistant alloys), allowing them to withstand long-term corrosion from crude oil, heavy oil, and acidic or alkaline organic impurities.
### III. Official Related Products and Reference Specifications
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers a customized fiber optic grating liquid level sensing solution based on seamless steel pipe encapsulation technology for this application:
- **Product Name** ：[OFSCN® Fiber Bragg Grating Liquid Level Sensor](https://www.ofscn.net/fbg-products/liquid-level.html)
 ![OFSCN Fiber Bragg Grating Liquid Level Sensor](https://forum.ofscn.net/uploads/default/original/1X/1250fd61302a58f79f01464fc13b994cc00bce61.jpeg)
- **Technical Features** ：
  - **Structural Basis** ：Derived from industrial-grade metal seamless steel pipe encapsulated multi-point fiber Bragg grating temperature sensor technology, manufactured with excellent compressive strength, leak-proof, and mechanical protection properties.
  - **Adjustable Resolution** ：The spatial resolution (vertical interval between measurement points) can be flexibly customized according to the tank range and accuracy requirements.
  - **Multiplexing Capability** ：Multiple independent wavelength measurement points can be cascaded within a single armored cable. Continuous measurement point array readings along the tank depth can be completed through a single-channel demodulator.
