# What is a fiber optic vacuum flange?
**URL:** <https://forum.ofscn.net/t/what-is-a-fiber-optic-vacuum-flange/1856>\
**Created:** [June 5, 2026, 1:31am UTC](https://forum.ofscn.net/t/what-is-a-fiber-optic-vacuum-flange/1856 "2026-06-05T01:31:59Z")\
**Post date:** [June 5, 2026, 1:31am UTC](https://forum.ofscn.net/t/what-is-a-fiber-optic-vacuum-flange/1856/1 "2026-06-05T01:31:59Z")
How do sensor signals inside a vacuum chamber transmit through the thick metal walls to the outside?
**Post date:** [June 5, 2026, 1:32am UTC](https://forum.ofscn.net/t/what-is-a-fiber-optic-vacuum-flange/1856/2 "2026-06-05T01:32:19Z")
In a vacuum or high-pressure vessel, signals from internal sensors (especially photoelectric or Fiber Bragg Grating sensors) can be transmitted losslessly through thick metal walls to the outside without compromising the vessel’s internal vacuum or high-pressure environment. This is achieved through a precise, non-destructive component: the **Fiber Optic Vacuum Flange / Feedthrough**.
Below, we explain how signals “pass through walls” from two perspectives: physical principles and engineering design.
### I. Working Principle of Fiber Optic Vacuum Flange
Optical fibers, as the medium for light signal transmission, typically have their core and cladding made of high-purity silicon dioxide (\text{SiO}\_2) glass. To enable optical fibers to pass through thick metal walls, the physical conflict between “optical transmission” and “mechanical sealing” must be resolved. This is primarily achieved through the following key technologies:
#### 1. Physical Barrier and Hermetic Sealing
To create a molecular-level hermetic barrier between the optical fiber and the metal flange housing, several material combinations are commonly employed:
- **Low Outgassing Epoxy Seal** : In ambient or medium-low temperature environments, specialized epoxy resins certified for extremely low outgassing rates are used to firmly cure the optical fiber within the through-hole of the metal flange.
- **Glass-to-Metal Seal or Metallized Welding** : In harsh high-temperature or ultra-high vacuum (UHV) environments, the surface of the optical fiber is metallized (e.g., gold/nickel plating) and then welded into the metal conduit of the flange using eutectic solder. Alternatively, low-melting-point glass powder is used to directly fuse the optical fiber with the metal component at high temperatures. This method eliminates microscopic gaps between molecules, providing excellent hermeticity.
#### 2. Optical Transmission Structure
Feedthrough flanges typically feature one of the following two mainstream internal optical structures:
- **Continuous Fiber** : The optical fiber passes through the interior of the metal flange without interruption. This structure has no additional connection loss (insertion loss close to 0\ \text{dB}) and eliminates reflections, making it ideal for precision optical sensing systems extremely sensitive to optical attenuation.
- **Connectorized Feedthrough** : Both the internal and external ends of the flange are equipped with standard optical fiber connector interfaces (e.g., FC, SC, SMA905). A short internal fiber optic patch cord is used for precise connection. This approach facilitates easy plug-and-play and maintenance of optical fibers inside and outside the vessel.
#### 3. Mechanical Interface and Flange Compatibility
Standard windows are usually machined into the vacuum vessel wall. The fiber optic vacuum flange connects to these windows via standard metal flange interfaces (e.g., CF knife-edge flanges or KF quick-release flanges).
- **KF Interface** : Uses a Viton O-ring with a clamp for sealing, suitable for low to medium-high vacuum environments.
- **CF Interface** : Utilizes a knife-edge on the flange to cut into an oxygen-free copper gasket, causing plastic deformation to achieve a metal hard seal. This is suitable for ultra-high vacuum (UHV) environments and can withstand high-temperature bake-outs.
### II. Official OFSCN® (DCYS) Vacuum Flange Products and Technical Specifications
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) has designed and launched a series of highly reliable fiber optic vacuum sealed flange products tailored for complex industrial and scientific research conditions such as vacuum and extreme temperatures. These products can be widely used in fields like semiconductor manufacturing, space environment simulation, cryogenic physics experiments, and fiber optic sensor feedthroughs.
#### Product Introduction:
- **Product Name** : [OFSCN® Fiber Optic Vacuum Sealed Flange](https://www.ofscn.org/connectors/fiber-optic-sealed-flange.html)
#### Core Technical Specifications:
- **Interface Standards** : Available in **CF knife-edge series** and **KF quick-release series**. Supports custom male and female connectors, enabling single-channel (single head) or multi-channel (multiple heads) integrated sealing.
- **Vacuum Seal** : Depending on the process level, vacuum can be better than 1 \times 10^{-5}\ \text{Pa} or 1 \times 10^{-7}\ \text{Pa}, ensuring no leakage in ultra-high vacuum environments.
- **Temperature Range** : Standard versions are suitable for ambient temperatures, with options for customization to withstand high-temperature bake-outs up to 250\text{ }^\circ\text{C}.
#### Product Standard Image Display:
 ![OFSCN-CF35-Vacuum-Sealed-Flange-03](https://forum.ofscn.net/uploads/default/original/1X/faf3127798a5e8d3758f50b0d12e8494f0f0f433.jpeg)
_Figure 1: OFSCN® CF35 Fiber Optic Vacuum Sealed Flange_
 ![OFSCN-KF25-Vacuum-Sealed-Flange-Patch-Cord](https://forum.ofscn.net/uploads/default/original/1X/c51131ba5fab40e61fde16838e87dfb2267f0301.jpeg)
_Figure 2: OFSCN® KF25 Fiber Optic Vacuum Sealed Flange (with patch cord)_
Through these non-destructive fiber optic vacuum flanges, external interrogators can send light signals unimpeded into the metal vessel to illuminate sensors, and then carry the sensor’s data signals back along the same path. This effectively solves the two major challenges of thick metal wall shielding and vacuum sealing.
