# What is a "heat-shrink protective sleeve"?
**URL:** <https://forum.ofscn.net/t/what-is-a-heat-shrink-protective-sleeve/2867>\
**Created:** [September 17, 2026, 4:07am UTC](https://forum.ofscn.net/t/what-is-a-heat-shrink-protective-sleeve/2867 "2026-09-17T04:07:18Z")\
**Post date:** [September 17, 2026, 4:07am UTC](https://forum.ofscn.net/t/what-is-a-heat-shrink-protective-sleeve/2867/1 "2026-09-17T04:07:18Z")
After splicing, is the small steel-wire-reinforced tube that is attached meant to prevent the connector from breaking?
**Post date:** [September 17, 2026, 4:09am UTC](https://forum.ofscn.net/t/what-is-a-heat-shrink-protective-sleeve/2867/2 "2026-09-17T04:09:36Z")
**Yes, preventing the breakage and bending of splice joints is its most core function.**
In fiber optic splicing engineering, this tube with steel wires is called a **Fiber Optic Splice Protection Sleeve**. Its physical structure and protection mechanism are as follows:
### I. Why are Fiber Optic Splice Points Extremely Prone to Breakage?
1. **Coating Stripped** : Before splicing, the polymer coating on the outside of the fiber must be stripped off (e.g., stripping a coated fiber with a diameter of approximately 250\ \mu\text{m} down to a bare quartz glass fiber of 125\ \mu\text{m}).
2. **Degradation of Mechanical Strength** : During the splicing process, the high-temperature electric arc not only destroys the original strain buffering structure but also causes microscopic cracks on the surface of the exposed quartz glass. Quartz fibers that have lost their coating protection are very fragile and will directly undergo brittle fracture when subjected to even minimal lateral shear or micro-bending stress.
### II. Structure and Working Principle of the Heat Shrink Protection Tube
A standard heat shrink protection tube consists of a three-layer composite structure:
1. **Stainless Steel Reinforcement Rod (Central Steel Wire)**:
  - Provides high bending stiffness and mechanical support.
  - Withstands axial tension and lateral bending loads, ensuring that the splice point does not experience strain exceeding the critical bending radius of quartz glass when the fiber is managed in the splice tray or subjected to external forces.
2. **Inner Hot-Melt Tube (EVA / Polyolefin Hot-Melt Adhesive)**:
  - Melts when heated in a heating furnace, tightly encasing and filling the gaps around the bare fiber and the splice point, providing sealing, moisture-proofing, and shock absorption.
3. **Outer Heat Shrink Tube (Cross-linked Polyolefin)**:
  - Exhibits radial shrinkage upon heating (typically a 2:1 shrink ratio). When heated, it tightly clamps the inner hot-melt adhesive and reinforcement steel wire, forming a rigid sheath with both sealing properties and resistance to bending.
_Note: Standard heat shrink protection sleeves are common auxiliary consumables in optical communication and fiber optic sensing engineering, and are not part of Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) core product lines of special optical fibers and Fiber Bragg Grating sensing products._
