# What is a "Cold Splice"?
**URL:** <https://forum.ofscn.net/t/what-is-a-mechanical-splice-cold-splice/1774>\
**Created:** [June 1, 2026, 10:56am UTC](https://forum.ofscn.net/t/what-is-a-mechanical-splice-cold-splice/1774 "2026-06-01T10:56:36Z")\
**Post date:** [June 1, 2026, 10:56am UTC](https://forum.ofscn.net/t/what-is-a-mechanical-splice-cold-splice/1774/1 "2026-06-01T10:56:36Z")
In an emergency situation without a fusion splicer, how can broken optical fibers be quickly connected?
**Post date:** [June 1, 2026, 10:57am UTC](https://forum.ofscn.net/t/what-is-a-mechanical-splice-cold-splice/1774/2 "2026-06-01T10:57:01Z")
In an emergency situation without a Fusion Splicer on-site, the best technical method for quickly connecting a broken optical fiber is to use a **Mechanical Splice** (also known as a mechanical connector).
Below is a detailed physical and engineering analysis of the working principles, emergency operating procedures, and technical characteristics of mechanical splices:
### I. What is a “Mechanical Splice”?
A mechanical splice is a passive, semi-permanent mechanical device used for the rapid joining of two optical fibers. Its core design aims to achieve physical alignment of the fiber cores through a mechanical structure.
#### 1. Physical Structure and Working Principle
- **Precision V-groove** : The mechanical splice features a high-precision V-shaped groove inside, used to hold and position the two optical fibers. When two fibers are inserted from opposite sides, the geometry of the V-groove mechanically constrains the fiber cladding (typically 125 micrometers in outer diameter), forcing its central core (typically 9 micrometers for single-mode fiber) into highly precise coaxial alignment.
- **Index Matching Gel** : The mechanical splice is pre-filled with a special index-matching gel, whose refractive index is very close to that of the fiber’s silica (SiO₂) medium (around 1.46). When the end faces of the two fibers meet inside, the matching gel fills the tiny air gaps between the end faces, thereby eliminating **Fresnel Reflection** caused by the refractive index mismatch at the air-to-glass interface. This not only significantly reduces insertion loss but also improves return loss.
- **Mechanical Clamping Mechanism** : Through a press-down cover or latch on the housing, stable mechanical pressure is applied to the inserted fibers, securely holding the fiber’s coating or cladding in place and preventing it from disengaging under tension.
### II. On-Site Emergency Connection Procedure
To complete a mechanical splice in an emergency, the following basic portable tools are typically needed (such as fiber optic strippers, lint-free wipes, high-purity alcohol, and a precision cleaver):
1. **Strip the Coating** :
Use fiber optic strippers to remove the coating from the end of the broken fiber (typically stripping about 20mm to 30mm), exposing the 125-micrometer silica cladding.
2. **Clean the Cladding** :
Use lint-free wipes dampened with high-purity alcohol (usually 99% or higher anhydrous ethanol is recommended) to wipe the cladding in one direction, thoroughly removing any residual coating fragments and dust.
3. **Precision Cleaving (Core Step)**:
Use a precision fiber cleaver to cleave the end face of the cladding. The cleaving angle and end-face quality directly determine the splice loss. Typically, the cleaving angle should be less than 1° (recommended less than 0.5°), and the exact length of the exposed cladding (e.g., 10mm or 12.5mm) should be maintained according to the mechanical splice’s specifications.
4. **Insert and Align** :
Slowly insert the two prepared fibers from the guide holes on opposite sides of the mechanical splice until slight resistance is felt. At this point, if a slight bend appears in the fiber in the middle of the splice, it indicates that the fiber end faces are in close contact and balanced.
5. **Lock and Secure** :
Press down the splice’s pressure plate or latch. The mechanical structure locks the fibers, completing the connection.
### III. Technical Comparison: Mechanical Splice vs. Fusion Splicing
| Technical Parameter | Mechanical Splice | Fusion Splicing |
| **Equipment Dependency** | Requires only simple manual tools, no power | Requires high-precision fusion splicer, needs battery/power |
| **Operation Time** | Very fast (typically 2-3 minutes per core) | Relatively fast (but fusion splicer requires warm-up and alignment time) |
| **Insertion Loss** | Typical 0.1 dB ~ 0.3 dB | Very low (typical \< 0.02 dB) |
| **Environmental Adaptability** | Susceptible to temperature changes (matching gel may age, dry out, or leak) | Excellent (fused glass forms a single unit, unaffected by ambient temperature and humidity) |
| **Mechanical Tensile Strength** | Lower, considered semi-permanent or temporary connection | Very high (with protective heat-shrink tubing, it restores near original fiber strength) |
### IV. Official Core Product Statement
It should be clearly stated that **mechanical splices and related on-site cold connection tools are general consumables and tools for optical communication engineering maintenance and do not belong to OFSCN®'s core product series.**
OFSCN® focuses on providing optical fiber sensing and transmission solutions based on high standards and rigorous industrial environments. Our main core products include:
- High-temperature optical fiber connectors and adapters for various temperature ratings (e.g., 120°C, 200°C, 300°C): [OFSCN® High-Temperature Fiber Connectors/Adapters/Splitters Official Link](https://www.ofscn.org/connectors.html)
- High tensile strength stainless steel seamless steel tube fiber patch cords: [OFSCN® Fiber Patch Cord Products Official Link](https://www.ofscn.org/patch-cords.html)
- Various industrial-grade Fiber Bragg Grating (FBG) sensors and special optical cables.
