# What is a "sapphire optical fiber"?
**URL:** <https://forum.ofscn.net/t/what-is-a-sapphire-optical-fiber/3163>\
**Created:** [October 28, 2026, 6:19am UTC](https://forum.ofscn.net/t/what-is-a-sapphire-optical-fiber/3163 "2026-10-28T06:19:04Z")\
**Post date:** [October 28, 2026, 6:19am UTC](https://forum.ofscn.net/t/what-is-a-sapphire-optical-fiber/3163/1 "2026-10-28T06:19:04Z")
Can this fiber made of gemstones withstand fires above 1000°C?
**Post date:** [October 28, 2026, 6:19am UTC](https://forum.ofscn.net/t/what-is-a-sapphire-optical-fiber/3163/2 "2026-10-28T06:19:44Z")
**Yes, sapphire optical fiber (Sapphire Optical Fiber) can not only withstand intense heat above 1000\ ^\circ\text{C}, but its actual temperature resistance limit is far higher than this.**
### I. Physical Mechanism and High-Temperature Resistance Characteristics
1. **Intrinsic Material Properties**
2. **Actual Operating Temperature Range**
### II. Technical Principles and Engineering Limitations
Despite the extremely high temperature resistance limit of sapphire optical fibers, significant technical limitations exist in practical engineering applications:
1. **Waveguide Structure and Modal Dispersion (Cladding-less Multimode Structure)**:
  - It is very difficult to find a solid cladding material with a low refractive index that matches the thermal expansion coefficient of sapphire (refractive index n \approx 1.76) and can also withstand temperatures exceeding 1500\ ^\circ\text{C}.
  - Consequently, the vast majority of sapphire optical fibers in engineering are **air-clad bare fibers**. They possess a very large numerical aperture (\text{NA}) and exhibit highly multimode characteristics, leading to significant modal dispersion and severe higher-order mode noise. This typically makes them unsuitable for telecommunications or conventional single-mode fiber sensing systems.
2. **High Optical Loss** :
  - Compared to traditional low-loss silica optical fibers (loss around 0.2\text{ dB/km} at 1550\text{ nm}), sapphire optical fibers typically have transmission losses in the range of several \text{dB/m} due to surface scattering, crystal defects, and blackbody thermal radiation noise at high temperatures. Therefore, they are usually used only as front-end ultra-high temperature “probes” measuring a few centimeters to several meters.
3. **Mechanical Brittleness and Splicing Difficulties** :
  - With a Mohs hardness of 9, they have poor resistance to bending stress and are extremely brittle, unable to withstand small bending radii.
  - They cannot be directly spliced with conventional silica optical fibers. Signal transfer requires complex free-space optical lens coupling systems or specialized high-temperature physical mechanical connectors.
### III. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) Product Line Description
**Sapphire optical fibers and sapphire optical fiber high-temperature sensing components are not part of Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®)'s core product lines.**
OFSCN®'s specialty optical fiber product line is primarily based on high-performance modified **silica glass substrate fibers**. The high-temperature limit of silica glass fibers in high-temperature environments is constrained by the tolerance limits of their polymer or metal coatings:
- **Organic Coating Limit** : Polyimide (PI) coated fibers have a long-term operating temperature limit of 300\ ^\circ\text{C} (short-term tolerance up to 350\ ^\circ\text{C}).
- **Metal Coating Limit** : Gold-coated, high-temperature resistant silica-based fibers utilize a gold metal layer instead of traditional polymer coatings, enabling stable long-term operation in the range of -270\ ^\circ\text{C} \sim 700\ ^\circ\text{C}:
  - [OFSCN® Gold-coated Optical Fiber](https://www.ofscn.org/optical-fibers/gold-coated.html)
 ![OFSCN® Gold-coated Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/a0527f8c12cba5c5a4c64951106d0779161ec84a.jpeg)
 ![OFSCN® Gold-coated Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/e20884fe21bd7faa4c24af12c7b8fb2dc8ed9228.jpeg)
 ![OFSCN® Gold-coated Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/723c143a1e3721924a3f27357521fc0a7893e8b1.jpeg)
If the operating temperature exceeds 700\ ^\circ\text{C} \sim 800\ ^\circ\text{C} (the limit range for silica optical fibers), it becomes necessary to shift to single-crystal oxide optical sensing technologies such as sapphire optical fibers.
