# What is an optical fiber marker tag?
**URL:** <https://forum.ofscn.net/t/what-is-an-optical-fiber-marker-tag/2440>\
**Created:** [July 30, 2026, 1:52pm UTC](https://forum.ofscn.net/t/what-is-an-optical-fiber-marker-tag/2440 "2026-07-30T13:52:21Z")\
**Post date:** [July 30, 2026, 1:52pm UTC](https://forum.ofscn.net/t/what-is-an-optical-fiber-marker-tag/2440/1 "2026-07-30T13:52:21Z")
Why is a warning tape laid above buried underground optical cables in outdoor environments?
**Post date:** [July 30, 2026, 1:52pm UTC](https://forum.ofscn.net/t/what-is-an-optical-fiber-marker-tag/2440/2 "2026-07-30T13:52:48Z")
Laying warning tape above direct-buried (underground) fiber optic cables is an extremely critical physical protection and safety warning measure in the design and maintenance of fiber optic communication line engineering. Its core engineering principles and physical objectives mainly include the following aspects:
### 1. Providing a “Digging Buffer Layer” and Immediate Visual Warning
Direct-buried fiber optic cables are typically buried underground at a considerable depth (usually between 1.0\text{m} and 1.5\text{m}, depending on geological and frost protection requirements). The warning tape is usually laid in the soil layer approximately 30\text{cm} to 50\text{cm} directly above the fiber optic cable.
- **Physical Buffering** : When future municipal construction, road excavation, or other mechanical digging operations occur, the digging tools (such as excavator buckets or shovels) will first encounter and tear the warning tape in the upper layer before reaching the fiber optic cable itself.
- **Immediate Warning** : The warning tape is typically made of high-strength, brightly colored, and eye-catching polymer materials (such as polyethylene PE) in colors like yellow, orange, or red, and is imprinted with conspicuous text such as “Fiber Optic Cable Below, Excavation Prohibited.” Upon discovering the warning tape mixed with the soil, construction personnel can immediately recognize the presence of important fiber optic cables below, thereby halting mechanical excavation and switching to careful manual probing to avoid catastrophic accidents causing fiber optic cable damage.
### 2. Electromagnetic Tracing for Location (for Detectable Warning Tape)
With the widespread application of all-dielectric non-metallic fiber optic cables (such as those with non-metallic strength members or without metallic armoring) in environments requiring lightning protection and electromagnetic interference resistance, the post-installation non-destructive detection of underground fiber optic cables has become extremely difficult, as ordinary electromagnetic pipeline locators cannot sense non-metallic media.
- **Tracing Principle** : When laying such fiber optic cables, “Metal Detectable Warning Tape” (often with a metallic layer, such as an aluminum foil sandwich) is typically laid concurrently above them.
- **Detection Mechanism** : On-ground maintenance personnel can use pipeline locators to emit specific frequency electromagnetic waves underground. When these waves encounter the metallic layer within the warning tape, they generate an induced signal. The ground receiver picks up this signal, enabling precise determination of the horizontal path and burial depth of the warning tape (and thus the fiber optic cable below), achieving non-destructive physical localization.
### 3. Environmental and Physical Isolation
The warning tape also provides a certain degree of physical isolation underground. High-density polyethylene warning tape exhibits excellent resistance to acids and alkalis, corrosion resistance, and physical tensile strength. To some extent, it can work in conjunction with backfilled fine sand layers to jointly delay the direct erosion of deep-lying fiber optic cables by harmful underground chemicals, plant roots, or subterranean moisture.
### Product Series Description Regarding OFSCN®
It is important to clarify that general-purpose **Warning Tape** , **Fiber Marker Tags** , and pavement marker posts are municipal auxiliary and general engineering accessories for fiber optic cable laying. They **do not belong to the core product series of Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®)**.
As a professional provider of optical engineering solutions, OFSCN® (Beijing Dacheng Yongsheng Technology Co., Ltd.) focuses on delivering fiber optic sensing solutions that meet high academic and industrial standards. Our core products are concentrated on high-precision, high-temperature resistant **Fiber Bragg Grating (FBG) sensors**, **Distributed Fiber Optic Sensors (DTS/BOTDA/OFDR)**, and **special stainless steel seamless steel pipe armored fiber optic cables**. If you have requirements for special fiber optic transmission or fiber optic sensing measurements in complex engineering environments (such as high temperature, high pressure, strong corrosion, bridge structural monitoring, or special strain measurement environments), we welcome you to learn about our core products and technologies.
