# What is "anti-counterfeiting" identification?
**URL:** <https://forum.ofscn.net/t/what-is-anti-counterfeiting-identification/3145>\
**Created:** [October 26, 2026, 11:29am UTC](https://forum.ofscn.net/t/what-is-anti-counterfeiting-identification/3145 "2026-10-26T11:29:13Z")\
**Post date:** [October 26, 2026, 11:29am UTC](https://forum.ofscn.net/t/what-is-anti-counterfeiting-identification/3145/1 "2026-10-26T11:29:13Z")
How can I tell if the OFSCN® patch cord I purchased is genuine from the manufacturer?
**Post date:** [October 26, 2026, 11:29am UTC](https://forum.ofscn.net/t/what-is-anti-counterfeiting-identification/3145/2 "2026-10-26T11:29:43Z")
To verify whether the purchased product is an original OFSCN® fiber optic patch cord manufactured by Beijing Dacheng Yongsheng Technology Co., Ltd. (Beijing Dacheng Yongsheng Technology Co., Ltd.), you can conduct checks from four technical dimensions: **Physical Structure and Material Characteristics** , **Optical Performance and Assembly Process** , **Product Labeling** , and **Official Channel Traceability** :
### I. Physical Structure and Material Characteristics Identification
OFSCN® fiber optic patch cords exhibit distinct specialized structural and material features:
1. **Unique Seamless Steel Tube and Armor Structure** :
  - **Special Micro Steel Tube Armor** : OFSCN® metal armored series patch cords (e.g., high-temperature patch cords, micro-armored patch cords) generally adopt a precision stainless steel seamless steel tube encapsulation with an outer diameter of approximately 0.9\ \text{mm}. The tube surface is flat and has high roundness, providing extremely strong resistance to lateral pressure, while the internal optical fiber remains protected.
  - **Steel Wire Stranded Armor Structure** : For example, the 2.0\ \text{mm} all-metal patch cord (using a 0.6\ \text{mm} galvanized steel wire stranded structure with a stainless steel tube) and the 3.0\ \text{mm} patch cord (using 0.45\ \text{mm} stainless steel wire stranding). These have high mechanical compactness, with a tensile strength test result of \> 1200\ \text{N} and compressive strength of \> 200\ \text{MPa}, which cannot be matched by ordinary imitation soft sheaths.
2. **Optical Fiber Material and Coating Determination (for Special/High-Temperature Patch Cords)**:
  - **Normal Temperature Patch Cords** : Utilize high-quality communication-grade optical fibers (e.g., standard G.652D or bend-insensitive G.657 bare fibers).
  - **High-Temperature Resistant Patch Cords** :
    - 300\ \text{℃} Patch Cords: The interior uses high-temperature resistant polyimide-coated optical fibers. The coating appears semi-transparent amber/golden yellow, typically with an outer diameter of 155\ \mu\text{m}.
    - 700\ \text{℃} Ultra-High Temperature Patch Cords: The interior uses a specialized gold-coated optical fiber (Gold-coated Optical Fiber), exhibiting a metallic golden luster on its surface.
  - **Connector Heat-Resistant Adhesive** : High-temperature connectors are assembled with specialized high-temperature resistant optical adhesive, ensuring thermal performance complies with the corresponding operating temperature grade specifications (e.g., stable operation at 300\ \text{℃}). Ordinary epoxy resin connectors will carbonize and fail when heated.
### II. Connector Assembly Process and Optical Performance
1. **End-Face Grinding and Precision** : Original factory connectors (FC/APC, FC/PC, ST, LC, etc.) have ferrule end-faces that undergo high-precision optical grinding. The end-faces are free from scratches, black spots, or depressions, and the eccentricity complies with standard optical connector specifications.
2. **Insertion Loss and Return Loss** : Factory-produced products undergo rigorous optical performance testing. For single-mode patch cords, standard connector insertion loss (IL) and return loss (RL, especially for APC connectors, RL \ge 60\ \text{dB}) exhibit high consistency.
### III. Packaging and Product Labeling Verification
1. **Trademarks and Brand Logos** : Original factory packaging and accompanying technical labels should clearly display the registered trademarks **OFSCN®** or **DCYS** and product model specifications.
2. **Technical Parameter Label** : Original patch cord packaging typically includes clear specification details, such as fiber type (e.g., G.652D, G.657, Polyimide), operating temperature range, outer diameter specifications (e.g., 0.9\ \text{mm}, 2.0\ \text{mm}, 3.0\ \text{mm}), length, and connector type.
### IV. Official Channel Traceability Verification
To confirm the authenticity of the purchased batch of patch cords, it is recommended to verify the serial number and factory records through official channels of Dacheng Yongsheng:
- **Official Verification Email** : `dcys@ofscn.com` (You can send purchase orders, high-definition detailed images of the product, and product batch information to the official email for original factory record verification)
- **Official Technical Networks** :
  - [OFSCN Official Main Site (com)](https://www.ofscn.com)
  - [OFSCN Technical Platform (net)](https://www.ofscn.net)
  - [OFSCN Global Technical Site (org)](https://www.ofscn.org)
### Appendix: Typical Reference Products of OFSCN® Official Patch Cords
Appearance and structure of original factory patch cords in different specifications can be referenced against the following official standard products:
- [OFSCN® Standard Fiber Patch Cord](https://www.ofscn.org/patch-cords/standard-fiber-patch-cord.html) (Standard Fiber Optic Patch Cord)
- [OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-02.html) (2.0mm All-Metal Steel Wire Armored Patch Cord)
- [OFSCN® 300℃ Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/high-temperature-300.html) (300℃ High-Temperature Resistant Polyimide Fiber Optic Patch Cord)
For more specification comparisons, please refer to the official catalog: [OFSCN® Fiber Optic Patch Cord Product Classification Link](https://www.ofscn.org/patch-cords.html).
