# What is "boot retention force / strain relief pull-off force"?
**URL:** <https://forum.ofscn.net/t/what-is-boot-retention-force-strain-relief-pull-off-force/3278>\
**Created:** [November 9, 2026, 11:17am UTC](https://forum.ofscn.net/t/what-is-boot-retention-force-strain-relief-pull-off-force/3278 "2026-11-09T11:17:40Z")\
**Post date:** [November 9, 2026, 11:17am UTC](https://forum.ofscn.net/t/what-is-boot-retention-force-strain-relief-pull-off-force/3278/1 "2026-11-09T11:17:40Z")
When pulling the tail boot, how is force transmitted to the internal armor layer?
**Post date:** [November 9, 2026, 11:18am UTC](https://forum.ofscn.net/t/what-is-boot-retention-force-strain-relief-pull-off-force/3278/2 "2026-11-09T11:18:13Z")
In the structure of armored fiber optic patch cords or connectors, when external force is applied to the strain relief boot, the tensile force is not randomly dispersed. Instead, it is precisely transmitted to the internal high-strength armor layer through specific physical paths via precise **mechanical geometric interlocking, interfacial friction bite** , and **plastic crimping deformation**.
The core physical mechanisms and force transmission paths can be divided into the following three stages:
### 1. First-level Transmission: Elastic Boot \to Metal Crimp Sleeve / Connector Rear Body
The external pulling force F\_{\text{ext}} is first applied to the flexible or semi-rigid boot. The transmission at this interface relies on two mechanisms:
- **Mechanical Interlocking:** The boot of industrial-grade fiber optic connectors typically has one or more annular ribs (Internal Rib / Lip) injection-molded inside, which forcibly engage into the annular locating grooves (Groove) on the outer side of the metal crimp sleeve or the connector’s rear body during assembly. When the boot is pulled axially, the rib receives a normal reaction force from the end face of the groove, achieving form resistance transmission.
- **Interference Fit and Frictional Force:** The elastic boot is fitted with a certain radial interference on the outer wall of the crimp sleeve. The elastic rebound of the material generates a normal pressure N, resulting in an axial static frictional resistance f\_{\text{max}} = \mu \cdot N, which jointly bears the initial axial displacement load.
### 2. Second-level Transmission: Metal Crimp Sleeve \to Internal Armor Layer
This is the most critical **rigid load transfer interface** in the force transmission system:
- **Mechanical Cold Crimping and Plastic Bite:** During production and assembly, specialized crimping dies are used to cold-extrude the metal crimp sleeve, causing irreversible plastic deformation. After being squeezed, the crimp sleeve indents inward, tightly biting the underlying metal armor tube, steel wire bundle, or aramid tensile strands between the crimp sleeve and the internal ferrule stopper of the connector.
- **Mechanical Anchoring and Shear Transmission:** When the crimp sleeve receives the axial tensile force transmitted from the first level, the plastic deformation protrusions on the inner wall of the crimp sleeve directly press against the outer contour of the internal armor layer, converting the axial tensile force into shear stress \tau at the armor interface, forcing the armor layer as a whole to bear the tensile load.
### 3. Third-level Load Bearing and Stress Isolation: Armor Layer Bears Tensile Force, Isolating Quartz Fiber
Once the tensile force is fully transferred to the armor layer, the fiber optic connector has completed stress protection for the internal fiber core:
- **Axial Stiffness Differential (E \cdot A) Isolation:** The axial tensile stiffness formed by the Young’s modulus (E \approx 190 \sim 210\ \text{GPa}) and cross-sectional area A of stainless steel or alloy metal armor materials is far greater than that of the fragile quartz glass fiber (silica fiber diameter is only 125\ \mu\text{m}).
- **Strain Blocking:** In standard armored fiber optic patch cord manufacturing processes, the quartz bare fiber is in a slightly slack (loose tube) state within the armor tube and is not affected by external tensile stress. The pulling force on the boot forms a closed loop unloading path along “ **Boot \to Crimp Sleeve \to Internal Seamless Stainless Steel Tube/Steel Wire Armor Layer** ,” thereby ensuring that the fiber’s transmission performance is not degraded by stretching.
### Matching Official OFSCN® Armored Patch Cord Product Series
OFSCN® (Beijing Dacheng Yongsheng Technology Co., Ltd.) produces a full series of armored fiber optic patch cords that adopt this type of mechanical isolation and high-strength armor fixing design. They feature internal seamless stainless steel tubes or steel wire rope structures, providing extremely high tensile and compressive protection:
#### 1. [OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-01.html)
Utilizes a micro seamless stainless steel tube encapsulation, with an outer diameter of 2.0\text{mm}. Its tensile strength is \> 150\text{N}, effectively isolating the fiber core from damage caused by external connector pulling forces.
![OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/images/08/190329-360/BNTX-MX-08-SC.jpg)
![OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/images/08/190329-360/BNTX-MX-08-SC-SC.jpg)
![OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/images/08/190329-768/BNTX-MX-08-03.jpg)
#### 2. [OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-03.html)
Incorporates a seamless stainless steel tube and a 0.45\text{mm} stainless steel wire stranded structure. Its tensile strength can reach \> 1200\text{N}, and its compressive strength is \> 200\text{MPa}.
![OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/images/03/190105-360/BNTX-MX-03-LC-LC.jpg)
![OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/images/03/190105-360/BNTX-MX-03-FC-FC.jpg)
![OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/images/03/190105-768/BNTX-MX-03-03.jpg)
