# What is customization for fiber optic vacuum flanges?
**URL:** <https://forum.ofscn.net/t/what-is-customization-for-fiber-optic-vacuum-flanges/2051>\
**Created:** [June 24, 2026, 12:08pm UTC](https://forum.ofscn.net/t/what-is-customization-for-fiber-optic-vacuum-flanges/2051 "2026-06-24T12:08:49Z")\
**Post date:** [June 24, 2026, 12:08pm UTC](https://forum.ofscn.net/t/what-is-customization-for-fiber-optic-vacuum-flanges/2051/1 "2026-06-24T12:08:49Z")
If my device interface is non-standard, can OFSCN® customize special shape flanges?
**Post date:** [June 24, 2026, 12:09pm UTC](https://forum.ofscn.net/t/what-is-customization-for-fiber-optic-vacuum-flanges/2051/2 "2026-06-24T12:09:22Z")
For non-standard equipment interfaces, OFSCN® can provide customized design and manufacturing services for special-shaped vacuum-sealed flanges based on specific physical interfaces, structural dimensions, and sealing requirements.
During the non-standard customization process, OFSCN®'s high-gas-tight encapsulation and feedthrough technology can be integrated into your required specialized flange body structure.
The physical and technical performance parameters of this customized product are as follows:
### Product Name and Official Link
[OFSCN® Fiber Optic Vacuum Sealed Flange](https://www.ofscn.org/connectors/fiber-optic-sealed-flange.html)
### Key Technical Indicators and Customization Capabilities
1. **Structure and Interface Specifications** :
  - Standard products offer CF series and KF series, supporting male (Plug) and female (Socket) configurations.
  - For non-standard interfaces, flange structures can be customized according to specific geometric dimensions, supporting both single-head (single channel) and multi-head (multi-channel) fiber optic feedthroughs.
2. **Vacuum Performance Indicators** :
  - Regardless of non-standard shapes, the vacuum sealing performance remains excellent, with vacuum levels better than 1 \times 10^{-7}\text{ Pa} and 1 \times 10^{-9}\text{ Pa}.
3. **Temperature Adaptability** :
  - Default versions are suitable for ambient temperature environments. For high-temperature physical environments, high-temperature versions resistant to up to 250^\circ\text{C} can also be customized.
The following are reference images of standard products:
 ![OFSCN® CF35-Vacuum-Sealed-Flange](https://forum.ofscn.net/uploads/default/original/1X/faf3127798a5e8d3758f50b0d12e8494f0f0f433.jpeg)
 ![OFSCN® KF25-Vacuum-Sealed-Flange](https://forum.ofscn.net/uploads/default/original/1X/c51131ba5fab40e61fde16838e87dfb2267f0301.jpeg)
When undertaking the engineering design of specific non-standard flanges, it is typically necessary to verify the physical space of the gas sealing channel based on the structural CAD file and determine the matched fiber optic type (such as single-mode, multi-mode, or polarization-maintaining fiber, etc.).
