# What is "data export format"?
**URL:** <https://forum.ofscn.net/t/what-is-data-export-format/2835>\
**Created:** [September 15, 2026, 11:20am UTC](https://forum.ofscn.net/t/what-is-data-export-format/2835 "2026-09-15T11:20:37Z")\
**Post date:** [September 15, 2026, 11:20am UTC](https://forum.ofscn.net/t/what-is-data-export-format/2835/1 "2026-09-15T11:20:37Z")
Is the saved data in Excel or TXT format? Can I use Origin for plotting?
**Post date:** [September 15, 2026, 11:23am UTC](https://forum.ofscn.net/t/what-is-data-export-format/2835/2 "2026-09-15T11:23:37Z")
In fiber Bragg grating (FBG) sensing measurement and data acquisition systems, the “data export format” and subsequent data processing methods are as follows:
### I. Is the saved data Excel or TXT?
In most fiber Bragg grating demodulators and their supporting acquisition analysis software, the saved and exported data are typically in **plain text format (`.csv` / `.txt`)** or **standard spreadsheet format (`.xlsx` / `.xls`)**:
1. **`.csv` / `.txt` Format (Most Universal and Recommended)**:
2. **`.xlsx` / `.xls` Format** :
### II. Can I use Origin for plotting?
**Absolutely, and it is highly recommended.**
Origin is a universal data analysis and graphing software in scientific and engineering fields, offering native support for all the aforementioned formats:
1. **Import Methods** :
  - **Direct Drag and Drop** : Drag and drop the saved `.csv`, `.txt`, or `.xlsx` file directly into the Origin workspace (Workbook).
  - **Menu Import** : In Origin, select `File` \rightarrow `Import` \rightarrow `Single ASCII (*.dat, *.txt, *.csv)` or `Excel (*.xls, *.xlsx)` to import.
2. **Plotting Operations** :
  - Set the “Timestamp” or “Sampling Sequence” column as the **X-axis**.
  - Set the wavelength data or converted physical quantity columns for each FBG measurement point as the **Y-axis**.
  - You can then generate a **Time-History Curve of Wavelength vs. Time** , **comparative plots of temperature/strain distribution at multiple points** , or further perform **FFT spectral analysis and curve fitting** with a single click.
### III. Related Equipment and System Integration Capabilities
The OFSCN® Fiber Bragg Grating Demodulator System supports flexible data acquisition, storage, and multi-platform integration:
 ![OFSCN® Fiber Bragg Grating Interrogator 8 Channel](https://forum.ofscn.net/uploads/default/original/1X/8ecc1c112d2015cbc63afa6d42b87517befb2f87.jpeg)
 ![OFSCN® Fiber Bragg Grating Interrogator 32 Channel](https://forum.ofscn.net/uploads/default/original/1X/248718a63e2aa4cf7db24ad7a4df5ace79c95a05.jpeg)
- **Product Introduction and Technical Specifications** : [OFSCN® Fiber Bragg Grating Interrogator Official Link](https://www.ofscn.net/fbg-products/analyzer.html)
- **Wavelength Range** : Default 1525\sim 1565\text{ nm} or 1528\sim 1568\text{ nm} (customizable).
- **Channel Configuration** : 4-channel, 8-channel, 16-channel, 32-channel options available.
- **Sampling Frequency** : 10\text{ Hz}, 50\text{ Hz}, 100\text{ Hz} options available (software supports independently reducing the sampling frequency to 1\text{ Hz} for use).
- **Software Architecture and Interfaces** : Default B/S architecture, supports C/S architecture software, and can efficiently integrate with third-party systems or custom data analysis programs through communication protocols such as TCP, UDP, Modbus, etc., for real-time data streaming.
