What is "digitalization in fiber optic sensing"?
How is an optical signal converted into the digital data and curves you see on your phone?
The conversion of optical signals into digital data and real-time dynamic curves displayed on mobile phones or terminal screens essentially involves a complete technical chain: “Optical Physics Modulation \rightarrow Optoelectronic Detection \rightarrow Analog-to-Digital Conversion (ADC) & Digital Signal Processing (DSP) \rightarrow Physical Calibration & Solvability \rightarrow Network Protocol Transmission & Front-end Rendering”.
Taking the Fiber Bragg Grating (FBG) sensing system, commonly used in industry and research, as an example, its complete digitization process can be broken down into the following five stages:
1. Optical Modulation (Physical Sensing Layer)
Light emitted from a broadband light source is transmitted through optical fiber to the FBG sensing element. The FBG satisfies the Bragg reflection condition:
When external physical quantities (temperature T, strain \varepsilon, pressure, etc.) change, the thermo-optic effect, elasto-optic effect of the fiber material, and changes in geometric dimensions due to stretching alter the effective refractive index n_{\text{eff}} or the grating period \Lambda. This causes a drift \Delta \lambda_B in the center wavelength of the reflection spectrum. At this point, physical quantities like temperature or strain are modulated and encoded into the wavelength variation of the reflected light.
2. Spectral Demodulation and Optoelectronic Conversion (Physical to Analog Electrical Signal)
The reflected wavelength optical signal returns to the interior of the FBG demodulator:
  • Optical Filtering/Spectra Division: Utilizing tunable Fabry-Pérot (F-P) filters, miniature spectrometers, or Arrayed Waveguide Gratings (AWG) to scan and discretely split the reflected light wavelengths in the optical domain, either temporally or spatially.
  • Photodetection (PD / Photodetector): Photodiodes convert the scanned and filtered light power variations into corresponding weak analog electrical signals (photocurrent or voltage signals).
3. Analog-to-Digital Conversion and Digital Signal Processing (Analog Electrical Signal to Discrete Digital Spectrum)
  • Analog-to-Digital Conversion (ADC): High-speed ADC chips perform high-precision quantization and digitization of the analog voltage signal at a fixed sampling clock (e.g., 10\text{ Hz}, 50\text{ Hz}, or higher sampling rates), outputting a discrete digital array.
  • Digital Spectrum Peak-Finding Algorithm (DSP / FPGA): On-board embedded processors (such as FPGAs or DSPs) apply algorithms like the centroid method, Gaussian fitting, or higher-order polynomial fitting to the sampled digital spectral shape to precisely calculate the current reflection peak’s center wavelength value \lambda_B (industrial-grade systems typically achieve resolutions of 1\text{ pm} or even 0.1\text{ pm}). At this stage, the continuous optical wave has been thoroughly “digitized”.
4. Physical Quantity Mapping and Calibration (Digital Wavelength to Engineering Physical Quantity)
After obtaining the precise wavelength drift \Delta \lambda_B, the system performs mapping calculations based on the factory calibration formulas. For example:
  • Temperature Solvability: T = T_0 + K_T \cdot \Delta \lambda_B ( K_T in units of {}^\circ\text{C}/\text{pm} )
  • Strain Solvability: \varepsilon = K_\varepsilon \cdot \Delta \lambda_B ( K_\varepsilon in units of \mu\varepsilon/\text{pm} )
After temperature compensation and calibration matrix operations, the abstract picometer (\text{pm}) level wavelength digits are converted into concrete engineering physical values (e.g., 25.4\ {}^\circ\text{C}, 320\ \mu\varepsilon).
5. Network Transmission and Client Graphical Rendering (Data to Screen Curve)
  • Protocol Encapsulation and Transmission: The demodulator host packages the calculated timestamp, channel number, wavelength value, and engineering data using protocols like TCP/IP, UDP, Modbus, or WebSocket, and pushes it via LAN, Wi-Fi, or 4G/5G cellular networks to cloud or edge servers.
  • Terminal Interface Presentation: Mobile browsers or mobile apps, based on B/S or C/S architecture, receive data packets, parse them into structured data streams (e.g., in JSON format), and utilize graphics rendering engines (such as Canvas, SVG, or mobile charting libraries) to continuously plot points and connect them with Bezier smooth lines in a 2D coordinate system, forming the real-time fluctuation curves and numerical readings that users ultimately see.
Related Products and Hardware Support
In this entire chain, the core central device responsible for “optoelectronic conversion, analog-to-digital conversion, and wavelength demodulation” is the Fiber Bragg Grating Demodulator:
  • Official Product Details: OFSCN® Fiber Bragg Grating Interrogator
  • Core Specification Parameters:
    • Wavelength Range: 1525\sim 1565\text{ nm} or 1528\sim 1568\text{ nm} (customizable)
    • Wavelength Resolution: Default 1\text{ pm}, customizable to 0.1\text{ pm}
    • Sampling Frequency: 10\text{ Hz}, 50\text{ Hz}, 100\text{ Hz}, etc. (software adjustable down to 1\text{ Hz})
    • Network Architecture and Integration: Natively supports B/S architecture software, supports communication protocols like TCP, UDP, Modbus, etc., facilitating direct data stream pushes to mobile terminals, web consoles, or industrial SCADA systems.
