# What is "dynamic range"?
**URL:** <https://forum.ofscn.net/t/what-is-dynamic-range/2117>\
**Created:** [June 30, 2026, 2:47pm UTC](https://forum.ofscn.net/t/what-is-dynamic-range/2117 "2026-06-30T14:47:35Z")\
**Post date:** [June 30, 2026, 2:47pm UTC](https://forum.ofscn.net/t/what-is-dynamic-range/2117/1 "2026-06-30T14:47:35Z")
What is the maximum difference in signal strength that a demodulator can tolerate between the strongest and weakest signals?
**Post date:** [June 30, 2026, 2:48pm UTC](https://forum.ofscn.net/t/what-is-dynamic-range/2117/2 "2026-06-30T14:48:10Z")
In fiber optic sensor and Fiber Bragg Grating (FBG) demodulation technology, the “maximum difference between the strongest and weakest signals that the demodulator can tolerate” you described is precisely defined in physics and engineering as **Dynamic Range**.
### 1. Physical Definition of Dynamic Range
The dynamic range of a Fiber Bragg Grating demodulator refers to the difference between the maximum and minimum optical reflection power that the demodulator can receive and process, while ensuring wavelength measurement accuracy and resolution. It is usually expressed in logarithmic units of decibels (dB):
\text{Dynamic Range (dB)} = P\_{\text{max (dBm)}} - P\_{\text{min (dBm)}}
- **Upper Limit of Strongest Signal (P\_{\text{max}})**: Limited by the saturation power of the internal photodetector or spectrometer of the demodulator. If the input reflected optical signal is too strong, the detector will saturate or “clip,” causing distortion of the spectral waveform, and the demodulator will be unable to accurately identify the reflected peak wavelength.
- **Lower Limit of Weakest Signal (P\_{\text{min}})**: Limited by the system’s noise floor. If the returned reflected optical signal is too weak, it will be submerged in system thermal noise and shot noise, making it impossible for the demodulator to extract a valid reflection peak from the spectrum (peak finding failure).
### 2. How Much Difference Can a Demodulator Tolerate? (Typical Specifications)
For common high-precision Fiber Bragg Grating demodulators on the market, the dynamic range is typically between **30 dB and 50 dB**. Some high-sensitivity industrial or scientific-grade demodulators can even reach **above 50 dB**.
**Example:**
If a demodulator has a dynamic range of 40 dB, it means that on the same channel:
- Assuming the optical power of the strongest signal is -10 dBm;
- The weakest signal that can be identified on this channel can be as low as -50 dBm;
- The difference between these two is 10,000 times the optical power, and the demodulator can still simultaneously and accurately demodulate their wavelengths.
### 3. Importance of Dynamic Range in Practical Engineering
In practical engineering applications, the greater the dynamic range of the demodulator, the stronger the system’s fault tolerance and adaptability:
- **Handling Fiber Link Loss** : If FBG sensors are deployed several kilometers away, or if the optical path contains multiple fiber splicing points and patch panel connectors (like FC/APC), the optical signal will experience loss during transmission. A demodulator with a large dynamic range can tolerate these significant insertion losses, ensuring that remote sensors can still be accurately demodulated.
- **Tolerating Inconsistent Multi-Point Reflectivity** : When multiple FBG sensors are connected in series on a single channel (i.e., a Fiber Bragg Grating string), the reflectivity of each grating section may not be entirely consistent, or the cumulative loss of different locations along the path may vary. A large dynamic range allows the demodulator to simultaneously read the wavelengths of both a very strongly reflecting FBG and a very weakly reflecting FBG within the same channel.
### Related OFSCN® (DCYS) Official Product Introduction
Beijing Dacheng Yongsheng Technology Co., Ltd. offers high-precision [OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html), which features excellent signal processing design and can effectively handle the large dynamic range and signal attenuation requirements in complex engineering tests.
**Key Parameter Specifications:**
- **Default Wavelength Range** : 1525 to 1565 nm, or 1528 to 1568 nm (customizable);
- **Number of Channels** : 4, 8, 16, 32 channels customizable;
- **Data Sampling Frequency** : 10 Hz, 50 Hz, 100 Hz optional (supports independent adjustment to a minimum of 1 Hz via demodulator software);
- **Wavelength Resolution** : 1 pm by default, or 0.1 pm (customizable).
 ![OFSCN® Fiber Bragg Grating Interrogator](https://forum.ofscn.net/uploads/default/original/1X/248718a63e2aa4cf7db24ad7a4df5ace79c95a05.jpeg)
The product adopts B/S architecture software, supports C/S architecture, and can be integrated with user systems through standard protocols such as TCP, UDP, and Modbus.
