# What is "hydrogen aging shielding"?
**URL:** <https://forum.ofscn.net/t/what-is-hydrogen-aging-shielding/2427>\
**Created:** [July 29, 2026, 12:06pm UTC](https://forum.ofscn.net/t/what-is-hydrogen-aging-shielding/2427 "2026-07-29T12:06:48Z")\
**Post date:** [July 29, 2026, 12:06pm UTC](https://forum.ofscn.net/t/what-is-hydrogen-aging-shielding/2427/1 "2026-07-29T12:06:49Z")
Can seamless steel pipes block hydrogen from penetrating optical fibers? How important is this for oil well monitoring?
**Post date:** [July 29, 2026, 12:07pm UTC](https://forum.ofscn.net/t/what-is-hydrogen-aging-shielding/2427/2 "2026-07-29T12:07:49Z")
In summary: **A simple single-layer stainless steel seamless steel tube cannot completely prevent hydrogen permeation into optical fibers. However, in the extreme environments of oil well monitoring, a “hydrogen-resistant/hydrogen-loss shielding” system composed of multi-layer seamless steel tubes and special optical fibers is key to ensuring the long-term stable operation of the monitoring system.**
The following provides a rigorous answer from three perspectives: physical mechanisms, oil well environmental impact, and industrial engineering solutions:
### I. Mechanism of Hydrogen Permeation in Metals (Why Steel Tubes Can’t Block It?)
The kinetic diameter of hydrogen molecules (H\_2) is extremely small (approximately 0.289\text{ nm}). In high-temperature (e.g., 150\text{ }^\circ\text{C} to 300\text{ }^\circ\text{C}) and high-pressure environments, hydrogen molecules readily dissociate into hydrogen atoms. These hydrogen atoms can easily diffuse through the interstitial spaces of the metal lattice (including stainless steel, nickel-based alloys, etc.). This physical process is known as **hydrogen permeation**.
Therefore, a single-layer stainless steel seamless steel tube with a thickness of only a few hundred micrometers (e.g., 0.2\text{ mm} to 0.3\text{ mm} ), while perfectly blocking corrosive chemical media such as water molecules and hydrogen sulfide in high-temperature downhole environments, will, over time, allow external hydrogen gas to permeate through the steel tube wall and enter the optical cable, reaching the optical fiber.
### II. What is “Hydrogen Loss” (Hydrogen Aging)?
When the permeated hydrogen molecules accumulate around the optical fiber, they cause optical signal attenuation through the following two mechanisms:
1. **Physical Dissolution** : Hydrogen molecules physically diffuse and dissolve into the silica (SiO\_2) glass network, creating broadband physical absorption peaks.
2. **Chemical Reaction** : At high temperatures, hydrogen molecules react with defects or dopants (such as Germanium, Ge) in the fiber core, forming stable hydroxyl ( -\text{OH} ) groups. This generates a very strong chemical absorption peak near the 1383\text{ nm} wavelength and significantly increases the background loss in the communication/sensing bands near 1550\text{ nm}, causing the optical fiber to darken and transmission to be interrupted. This phenomenon is known as **hydrogen loss (hydrogen aging, Hydrogen-Induced Attenuation)**.
### III. How Important is This for Oil Well Monitoring?
In oil and gas well, and geothermal well monitoring, distributed fiber optic sensing technologies (such as DTS temperature monitoring based on Raman scattering, DVS/DSS vibration and strain monitoring based on Rayleigh/Brillouin scattering, and FBG fiber Bragg grating sensors) are widely used for real-time monitoring of downhole pressure, temperature, flow rate, and casing integrity:
- **Ultra-High Environmental Pressure and Temperature** : The temperature in deep oil wells is often above 150\text{ }^\circ\text{C} , even reaching 300\text{ }^\circ\text{C} , accompanied by high concentrations of hydrogen gas (originating from formation organic matter, acidification operations, or electrochemical corrosion).
- **Extremely High Lifespan Requirements** : Once deployed, oil well monitoring systems are typically required to operate continuously and stably for 10 to 20 years. Without effective “hydrogen loss shielding” and hydrogen-resistant design, ordinary optical fibers may completely fail within weeks due to hydrogen aging.
### IV. How is True “Hydrogen Shielding” Achieved Industrially?
To overcome the challenge of hydrogen aging in oil well monitoring, a multi-layer shielding and systematic protection approach is usually employed:
1. **Chemical Barrier: Hermetic Carbon-Coated Fiber** : A highly dense amorphous carbon film is pre-deposited on the outer surface of the fiber cladding. The tight arrangement of carbon atoms acts as a physical barrier, effectively preventing hydrogen molecules from diffusing into the fiber core even under high temperature and pressure.
2. **Material Optimization: Pure Silica Core Fiber** : Avoid using Germanium ( Ge ) doping in the fiber core, and use pure silica as the core material. Due to the lack of reactive sites, even if a small amount of hydrogen permeates, it will not form a serious chemical -\text{OH} absorption peak in the working wavelength band.
3. **Structural Barrier: Multi-Layer Seamless Steel Tube Encapsulation and Hydrogen Scavenging Gel** : Utilize double or triple-layer metal seamless steel tube structures to extend the diffusion path of hydrogen. Additionally, specialized hydrogen scavenging gels can be filled inside the metal tubes to physically or chemically capture permeated hydrogen molecules.
### V. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) Downhole High-Security Fiber Optic Cable Solutions
For extremely harsh high-temperature, high-pressure, and multi-hydrogen environments such as oil wells, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) has developed a series of specialized multi-layer steel tube encapsulated downhole fiber optic cables. Combined with special optical fibers, these cables offer excellent resistance to hydrogen aging and corrosion:
- **OFSCN® Double-Layer High-Temperature Downhole Fiber Optic Cable** [Official Link](https://www.ofscn.org/sst-cables/two-layer.html)
This product uses a double-layer seamless steel tube encapsulation (outer layer 6.35\text{ mm} / inner layer 3.6\text{ mm} ). The default material is 316L stainless steel, with an option for 825 corrosion-resistant alloy. The double-layer metal barrier significantly extends the period for hydrogen permeation inwards while providing extremely high tensile and compressive strength.
 ![OFSCN® Double-Layer High-Temperature Downhole Fiber Optic Cable](https://forum.ofscn.net/uploads/default/original/1X/8fb9e6cfdc9c319692290cd86556948fb9f17ed1.jpeg)
- **OFSCN® Triple-Layer Downhole High-Temperature Fiber Optic Cable** [Official Link](https://www.ofscn.org/sst-cables/three-layer.html)
For more demanding environments in ultra-deep wells and high-temperature, high-pressure oil and gas wells, this product offers triple-layer seamless steel tube heavy-duty protection (outer layer 6.35\text{ mm} / middle layer 4.0\text{ mm} / inner layer 3.0\text{ mm} ). It can provide ultimate hydrogen loss shielding capabilities when combined with hydrogen-scavenging fillers and special optical fibers.
 ![OFSCN® Triple-Layer Downhole High-Temperature Fiber Optic Cable](https://forum.ofscn.net/uploads/default/original/1X/439819bfc516f4e12d29794e72ff31fec3ebaec7.jpeg)
This series of downhole fiber optic cables can flexibly accommodate various high-temperature resistant special optical fibers internally, and supports customization of hydrogen-resistant fibers such as pure silica core:
- **OFSCN® 200℃ Polyimide Optical Fiber** ( [Official Link](https://www.ofscn.org/optical-fibers/pi-coated-sm-mm-200.html) )
- **OFSCN® 300℃ Polyimide Optical Fiber** ( [Official Link](https://www.ofscn.org/optical-fibers/polyimide-coated-sm-300.html) )
By organically combining multi-layer alloy seamless steel tube structures, special coating layers, and hydrogen-resistant fiber technologies such as pure silica core, Beijing Dacheng Yongsheng Technology Co., Ltd. provides a long-term, highly reliable physical channel guarantee for distributed fiber optic sensing monitoring in modern digital oil wells.
