If the jumper cable is pinched by the cabinet door, will the optical fiber inside crack?
1. Physical Mechanism Analysis: Changes in Internal Fiber When Ordinary Patch Cords Are Pinched
Standard ordinary fiber optic patch cords (such as common PVC or LSZH sheathed cables) typically consist of an outer jacket, aramid (Kevlar) filler, and a tight-buffered fiber.
- Stress Concentration Effect: Aramid primarily provides tensile strength (longitudinal pulling force) and offers virtually no protection against lateral or side pressure (crush resistance). When a cabinet door pinches such a patch cord, the steel edge or corner of the cabinet door exerts a massive lateral load directly onto the surface of the patch cord.
- Microbending and Fracture Mechanism: The glass core (approximately 9\ \mu\text{m} in diameter) and cladding (125 \mu\text{m} in diameter) of the optical fiber are made of brittle silica (\text{SiO}_2) glass. Localized severe compression can lead to:
- Macro/Microbending Loss: The optical fiber axis undergoes micron-level mechanical deformation, causing severe light leakage of the optical signal, thus dramatically increasing optical attenuation.
- Microcrack Generation and Propagation: Under extremely high localized stress concentration, the silica molecular bonds on the fiber surface fracture, creating sub-surface microcracks.
- Delayed Fracture: If the compressive force is significant, the microcracks will instantly penetrate the entire cross-section, causing the fiber to break directly. Even if it doesn’t break immediately, residual microcracks, under subsequent environmental vibration or stress corrosion, will gradually grow over time, eventually leading to sudden fracture of the patch cord without any external force (i.e., delayed fracture).
2. Engineering Solution: Introducing “Crush Resistance” Protection
To prevent fiber breakage or cracking caused by accidental pinching by cabinet doors, stepping on by heavy objects, or rodent damage, it is necessary to use armored fiber optic patch cords with extremely high crush resistance.
OFSCN® Armored Fiber Optic Patch Cords, with their unique metal armor layer, completely isolate external compressive force from the inner structure, thereby achieving 100% mechanical protection for the brittle internal fiber:
① OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord
This patch cord utilizes a highly precise, miniature seamless stainless steel tube for internal encapsulation. While maintaining an outer diameter of only 2.0\text{ mm}, it possesses extremely high crush resistance.
- Physical Protection Performance: Its tensile strength is \ge 1500\text{ N}, and its compressive strength is \ge 150\text{ MPa}.
- Anti-Pinch Principle: When a cabinet door pinches this patch cord, all lateral shear forces and side pressures are entirely borne and dissipated by the 0.6\text{ mm} seamless stainless steel tube. The fiber inside the steel tube remains in a completely stress-free state, thus absolutely no microcracks or additional loss will occur.
Standard Product Images:
② OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord
If the cabinet doors are extremely heavy, or if facing higher levels of physical threats such as vehicle crushing or harsh industrial environments, this model of patch cord can be used.
- Multi-Layer Steel Wire Rope Structure: It features a layer of 0.45\text{ mm} stainless steel wire rope braid wrapped around the 0.9\text{ mm} seamless stainless steel tube, finally covered by a PE protective jacket.
- Ultra-High Mechanical Strength: Tensile strength reaches \ge 1200\text{ N}, and compressive (crush) strength is as high as \ge 200\text{ MPa}. Even under sudden impacts of extremely high energy or repeated violent pinching by heavy cabinet doors, it can achieve zero damage to the internal fiber.
Summary Recommendation
If you are using ordinary non-armored PVC soft sheath patch cords, after being pinched by a cabinet door, the internal fiber is highly likely to develop microcracks (or even break directly), accompanied by an abnormal increase in optical attenuation.
To completely avoid such hardware risks, it is recommended to upgrade to OFSCN® armored fiber optic patch cords with stainless steel tube protection at critical cabling points and in areas prone to pinching or stepping. This will eliminate the environmental conditions for microcrack formation from a physical structural perspective.
