# What is "remote diagnostics"?
**URL:** <https://forum.ofscn.net/t/what-is-remote-diagnostics/3280>\
**Created:** [November 9, 2026, 11:18am UTC](https://forum.ofscn.net/t/what-is-remote-diagnostics/3280 "2026-11-09T11:18:59Z")\
**Post date:** [November 9, 2026, 11:18am UTC](https://forum.ofscn.net/t/what-is-remote-diagnostics/3280/1 "2026-11-09T11:18:59Z")
If there are strange signal fluctuations, can OFSCN® experts view the data remotely?
**Post date:** [November 9, 2026, 11:19am UTC](https://forum.ofscn.net/t/what-is-remote-diagnostics/3280/2 "2026-11-09T11:19:25Z")
In the engineering application of Fiber Bragg Grating (FBG) sensing, **remote data diagnostics and collaborative analysis via network are supported and fully enabled**.
### I. General Technical Principles and System Architecture for Remote Diagnostics
The OFSCN® Fiber Bragg Grating Interrogation System provides native support for networked remote access and integration in its underlying architecture design:
1. **B/S (Browser/Server) Software Architecture**:
The OFSCN® Fiber Bragg Grating Interrogator adopts B/S architecture software by default. The interrogator integrates a service management program internally. Any computer, industrial PC, or terminal connected to the same network (or accessible via an authorized VPN/port forwarding) can directly access the control interface, real-time wavelength monitoring panel, and spectral plots without needing to install dedicated local software. Access is achieved by simply entering the interrogator’s IP address through a standard web browser.
2. **Standard Network Protocol Integration** :
The system supports forwarding real-time spectral data, calculated wavelength values, or alarm signals to remote locations via industrial and general network transmission protocols such as TCP, UDP, and Modbus, facilitating remote engineering teams’ access to the interrogator’s underlying data streams.
### II. Physical and Signal Characteristics Analyzable via Remote Diagnostics
When “abnormal signal fluctuations” occur at the sensor or system site, technicians can perform real-time troubleshooting of the following key optical and physical parameters through remote access:
1. **Reflection Spectrum Shape (Reflection Spectrum & Peak Profile)**:
  - **Double Peaks/Spectral Peak Broadening** : Indicates whether the Fiber Bragg Grating sensing point is subjected to non-uniform stress fields or transverse shear forces.
  - **Sudden Drop in Optical Power and Signal-to-Noise Ratio (SNR)**: To investigate potential contamination or loosening of fiber optic connectors, or micro-bending losses or fiber breaks in the cable’s transmission path.
2. **Peak Locking and Wavelength Jumps** :
  - Under specific sampling frequencies (e.g., 10\ \text{Hz} , 50\ \text{Hz} , or 100\ \text{Hz} ), check whether wavelength drift exhibits continuous physical change (such as transient mechanical strain or temperature shock) or presents as discontinuous jumps caused by improperly set algorithm peak-finding thresholds.
3. **Environmental and Mechanical Decoupling** :
  - Distinguish whether signal fluctuations are due to the inherent high-frequency vibration or acoustic waves of the structure under test, or physical displacement caused by loose mounting fixtures.
### III. Related Products and Hardware Support
This remote functionality is directly supported by the **OFSCN® Fiber Bragg Grating Interrogator** at both the hardware and software levels.
[OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html)
- **Core Specifications** :
  - Default Wavelength Range: 1525 \sim 1565\ \text{nm} or 1528 \sim 1568\ \text{nm} (Customizable)
  - Wavelength Resolution: Default 1\ \text{pm} (Customizable to 0.1\ \text{pm})
  - Data Sampling Frequency: 10\ \text{Hz} , 50\ \text{Hz} , 100\ \text{Hz} selectable (Tunable down to 1\ \text{Hz} in software)
  - Channel Configuration: 4-channel, 8-channel, 16-channel, 32-channel customizable
  - Network Support: B/S architecture control, supports C/S architecture expansion, and TCP/UDP/Modbus protocol communication
![OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/images/95/20200522-768/FBG-Interrogator-8CH.jpg)
![OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/images/95/20200522-768/FBG-Interrogator-32CH.jpg)
### IV. Operational Approaches for Implementing Remote Diagnostics
If indeterminate signal anomalies are encountered on-site, the following two technical approaches can typically be employed for expert diagnosis:
1. **Online Remote Joint Debugging** :
Connect the local area network where the interrogator is located to a controlled network environment (via authorized remote assistance tools, VPN, or LAN penetration within the enterprise network). OFSCN® technical personnel can directly access the system via the browser interface to observe the real-time full spectrum dynamics and peak optimization status.
2. **Offline Raw Data Diagnosis** :
Export the historical wavelength time-domain curve data (CSV format) from the abnormal period via the interrogator’s software interface, along with corresponding reflection spectrum data slices. Send these to the official technical support email: `dcys@ofscn.com`. The technical team can then identify the cause of fluctuations through data playback and spectral reconstruction.
