# What is "repeatability"?
**URL:** <https://forum.ofscn.net/t/what-is-repeatability/3292>\
**Created:** [November 11, 2026, 11:18am UTC](https://forum.ofscn.net/t/what-is-repeatability/3292 "2026-11-11T11:18:57Z")\
**Post date:** [November 11, 2026, 11:18am UTC](https://forum.ofscn.net/t/what-is-repeatability/3292/1 "2026-11-11T11:18:57Z")
Why do the readings on the power meter vary each time the same connector is plugged and unplugged 10 times?
**Post date:** [November 11, 2026, 11:19am UTC](https://forum.ofscn.net/t/what-is-repeatability/3292/2 "2026-11-11T11:19:55Z")
In optical engineering and fiber optic sensing testing, this is a very classic and inevitable physical phenomenon.
### I. What is “Repeatability”?
In metrology and fiber optics, **Repeatability** refers to: **the degree of agreement among individual test results obtained from the same measurement under the same conditions of measurement (same operator, same measuring instrument, same test item, same environment, and short interval of time) when the same physical quantity is measured repeatedly and independently.**
For fiber optic connectors, this metric is commonly referred to as **Mating Repeatability / Re-mating Reproducibility**. It is used to characterize the maximum difference (or standard deviation) in insertion loss (IL) or transmitted optical power fluctuations introduced after repeated mating and unmating of the connector.
In industrial and communication standards, the mating repeatability of high-quality single-mode fiber optic connectors is typically required to be within \le 0.1\ \text{dB} to \le 0.2\ \text{dB} .
### II. Why are the readings different each time when the same connector is mated 10 times?
On a macroscopic level, mating the same connector into the same adapter seems to result in a “complete reset”; however, at the microscopic geometric and wave optics scale, **the microscopic mechanical contact state differs at the sub-micrometer level with each mating cycle.** The main physical mechanisms are as follows:
#### 1. Sub-micrometer Core Lateral Misalignment
- The mode field diameter (MFD) of standard single-mode fibers (e.g., G.652D) is only about 9\ \mu\text{m} \sim 10.4\ \mu\text{m} .
- The outer diameter of the ceramic ferrule in fiber optic connectors is typically 2.5\ \text{mm} (e.g., FC, SC, ST) or 1.25\ \text{mm} (e.g., LC). There is a sub-micrometer mechanical clearance (usually in the range of 0.5\ \mu\text{m} \sim 1.0\ \mu\text{m} ) between the ferrule and the split ceramic sleeve inside the adapter.
- Each time the ferrule is inserted and tightened/locked, the relative lateral offset between the cores changes minutely. According to Gaussian beam coupling theory, a lateral eccentricity of just 0.5\ \mu\text{m} can cause a loss fluctuation of approximately 0.05\ \text{dB} \sim 0.1\ \text{dB} .
#### 2. End-face Physical Contact Morphology and Micro-pressure Distribution (Apex Offset)
- Optical connectors (PC/UPC/APC) use physical contact with a spherical end face. The internal spring in the connector provides mechanical pre-tension, causing elastic deformation of the fiber region at the end face to eliminate air gaps.
- There is a tiny “Apex Offset” between the center of curvature of the ground sphere and the core center. Each time the connector is mated, rotated, or the locking nut is tightened, the contact stress distribution at the mating interface varies subtly, leading to minor fluctuations in Fresnel reflections.
#### 3. Dynamic Displacement of Sub-micrometer Dust and Particles
- Micron-sized/sub-micron-sized dust particles floating in the air migrate, fragment, or rearrange during each unplugging and insertion. Even a tiny particle entering the edge of the fiber’s mode field can cause light scattering and a slight step change in loss.
#### 4. Jumper Cable Micro-bending Stress and Polarization-Dependent Loss (PDL)
- During manual mating operations, the tail fiber of the jumper cable inevitably experiences varying degrees of bending, twisting, or slight pulling, leading to fluctuations in micro-bending loss.
- As light waves pass through stressed fibers, their polarization states change. If the test link contains passive components or a power meter probe with Polarization-Dependent Loss (PDL), this can also translate into small variations in optical power readings.
#### 5. Instrumentation System Noise Floor Drift
- The short-term power stability of the laser source (typically \pm 0.005\ \text{dB} \sim \pm 0.02\ \text{dB} ) and the thermal noise and minor non-linearity of the power meter’s photodetector inherently add to the readings.
### III. Result Judgment and Normal Engineering Thresholds
| Measurement Range of Fluctuation | Physical State Assessment | Recommended Action |
| \Delta P \le 0.1\ \text{dB} | **Excellent** (Within the mechanical repeatability limits of high-precision ceramic ferrules) | Normal system characteristic, no intervention required |
| 0.1\ \text{dB} \< \Delta P \le 0.2\ \text{dB} | **Normal** (Complies with industrial standards for single-mode fiber optic connectors) | Within normal tolerance range |
| 0.2\ \text{dB} \< \Delta P \le 0.5\ \text{dB} | **Slightly High** (Potential mild contamination or loose mechanical sleeve) | Clean the connector and the internal ceramic sleeve of the adapter |
| \Delta P \> 0.5\ \text{dB} | **Abnormal** (Severe contamination, scratched or pitted end-face, or cracked ceramic sleeve) | Inspect end-face with a microscope, replace adapter, or re-polish |
### IV. Related Product Specifications and Precision Optical Hardware
In precision fiber optic sensing and testing engineering, to minimize repeatability errors, it is typically required to use connector components with high coaxiality ferrules, high-hardness ceramic sleeves, and high-reliability metal structures. For example, the connector and adapter components provided by Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®):
- [OFSCN® High Temperature Resistant Fiber Optic Adapter](https://www.ofscn.org/connectors/fiber-optic-adapter.html)
 ![OFSCN® High Temperature Resistant Fiber Optic Adapter](https://www.ofscn.org/images/36/20201103-360/BNTX-36-FC-FC-falan-02.jpg)
- [OFSCN® 120℃ Fiber Optic Connector](https://www.ofscn.org/connectors/high-temperature-120.html)
 ![OFSCN® 120℃ Fiber Optic Connector](https://www.ofscn.org/images/51/190221-360/BNCG-MX-51-HT-FC.jpg)
