# What is "system latency"?
**URL:** <https://forum.ofscn.net/t/what-is-system-latency/2877>\
**Created:** [September 18, 2026, 5:02am UTC](https://forum.ofscn.net/t/what-is-system-latency/2877 "2026-09-18T05:02:47Z")\
**Post date:** [September 18, 2026, 5:02am UTC](https://forum.ofscn.net/t/what-is-system-latency/2877/1 "2026-09-18T05:02:47Z")
How many milliseconds does it take from the sensor being stressed to the computer displaying data?
**Post date:** [September 18, 2026, 5:03am UTC](https://forum.ofscn.net/t/what-is-system-latency/2877/2 "2026-09-18T05:03:00Z")
In a Fiber Bragg Grating (FBG) sensing system, “system latency” (End-to-End Latency) refers to the **total time from when the sensor undergoes external force causing physical deformation to when the numerical calculation is completed and the value is refreshed on the PC host interface**.
This latency is composed of five physical and engineering stages, with their respective time scales as follows:
### 1. Physical Deformation and Mechanical Transfer Latency ( \sim 1\ \mu\text{s} - 10\ \mu\text{s} )
- **Mechanism** : When the structure under test is subjected to force, strain waves propagate through the encapsulation matrix at the speed of sound (approximately 3000\ \text{m/s} \sim 5000\ \text{m/s} in solid media) to the fiber core, causing changes in the grating period \Lambda and effective refractive index n\_{\text{eff}}.
- **Time Consumption** : For fiber strain/stress sensors on the centimeter scale, this physical process completes within microseconds and is generally negligible on a millisecond scale.
### 2. Optical Signal Transmission Latency ( \sim 5\ \mu\text{s/km} )
- **Mechanism** : The speed of light propagation in the quartz fiber core is approximately v = \frac{c}{n} \approx \frac{3 \times 10^8\ \text{m/s}}{1.468} \approx 2 \times 10^8\ \text{m/s}.
- **Time Consumption** : One-way transmission latency is approximately 5\ \mu\text{s/km}. For a transmission cable length of 1\ \text{km}, the round-trip optical path latency is about 10\ \mu\text{s} (i.e., 0.01\ \text{ms}).
### 3. Demodulator Sampling and Spectral Calculation Latency (Primary determining factor, 10\ \text{ms} - 100\ \text{ms} )
The demodulator’s data update cycle is the largest source of latency in the entire link, depending on the hardware-set sampling frequency (f\_s):
- **Sampling Period ( T = \frac{1}{f\_s} )**:
  - **100\ \text{Hz} Sampling Frequency** : Single frame data acquisition period is **10\ \text{ms}**.
  - **50\ \text{Hz} Sampling Frequency** : Single frame data acquisition period is **20\ \text{ms}**.
  - **10\ \text{Hz} Sampling Frequency** : Single frame data acquisition period is **100\ \text{ms}**.
- **Hardware Processing Time** : The demodulator’s internal DSP/FPGA executes algorithms for peak finding, wavelength calibration, and filtering, typically taking about 1\ \text{ms} \sim 3\ \text{ms}.
### 4. Data Communication Transmission Latency ( \sim 1\ \text{ms} - 5\ \text{ms} )
- **Mechanism** : The demodulator pushes wavelength or strain data packets to the host computer via an industrial Ethernet interface (using protocols like TCP/IP, UDP, or Modbus).
- **Time Consumption** : In conventional LAN or direct connection configurations, network stack latency is usually in the range of 1\ \text{ms} \sim 5\ \text{ms}.
### 5. PC-side Data Processing and UI Display Rendering Latency ( \sim 15\ \text{ms} - 30\ \text{ms} )
- **Mechanism** : The host software receives data packets, executes physical quantity conversion formulas (e.g., calculating stress values based on \sigma = E \cdot \varepsilon), and submits them to the operating system’s graphics engine for rendering.
- **Time Consumption** : The refresh cycle of conventional displays is typically 16.7\ \text{ms} ( 60\ \text{Hz} refresh rate). Combined with software buffer queue processing, display latency is generally between 15\ \text{ms} \sim 30\ \text{ms}.
### Summary: Overall End-to-End Latency Scale
| Configuration Condition | Demodulator Sampling Period | Communication & Processing Latency | PC Rendering Latency | **Total System Latency** |
| **Standard Dynamic Measurement (100 Hz)** | 10\ \text{ms} | 2 \sim 5\ \text{ms} | \sim 16.7\ \text{ms} | **Approximately 25\ \text{ms} \sim 35\ \text{ms}** |
| **Standard Static Measurement (10 Hz)** | 100\ \text{ms} | 2 \sim 5\ \text{ms} | \sim 16.7\ \text{ms} | **Approximately 115\ \text{ms} \sim 130\ \text{ms}** |
### Related Product References
In practical engineering systems, sensing terminals typically employ alloy tube encapsulation structures to ensure strain transfer efficiency and are paired with multi-channel demodulators for high-speed wavelength acquisition and network communication:
- Acquisition Device: [OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html) (Supports 10Hz / 50Hz / 100Hz sampling frequency configuration, supports TCP/UDP/Modbus data communication)
- Strain Sensor: [OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor](https://www.ofscn.net/fbg-products/strain-sensor.html)
- Stress Sensor: [OFSCN® Fiber Bragg Grating Stress Sensor](https://www.ofscn.net/fbg-products/stress-sensor.html)
