# What is the "anti-counterfeiting" mechanism for a fiber optic patch cord?
**URL:** <https://forum.ofscn.net/t/what-is-the-anti-counterfeiting-mechanism-for-a-fiber-optic-patch-cord/2900>\
**Created:** [September 22, 2026, 11:46am UTC](https://forum.ofscn.net/t/what-is-the-anti-counterfeiting-mechanism-for-a-fiber-optic-patch-cord/2900 "2026-09-22T11:46:42Z")\
**Post date:** [September 22, 2026, 11:46am UTC](https://forum.ofscn.net/t/what-is-the-anti-counterfeiting-mechanism-for-a-fiber-optic-patch-cord/2900/1 "2026-09-22T11:46:42Z")
How can I tell if the OFSCN® patch cord I bought is genuine?
**Post date:** [September 22, 2026, 11:48am UTC](https://forum.ofscn.net/t/what-is-the-anti-counterfeiting-mechanism-for-a-fiber-optic-patch-cord/2900/2 "2026-09-22T11:48:21Z")
To distinguish and verify genuine **OFSCN® (Beijing Dacheng Yongsheng Technology Co., Ltd.)** original fiber optic patch cords, a technical assessment can be made primarily through three dimensions: **Physical Structure and Material Characteristics** , **Optical/Mechanical Specifications** , and **Official Factory and Channel Verification** :
### I. Identification of Physical Structure and Material Characteristics
OFSCN® (Beijing Dacheng Yongsheng Technology Co., Ltd.) fiber optic patch cords are specially designed with mechanical and temperature-resistant features for various industrial and experimental scenarios. Their internal encapsulation structure exhibits distinct original factory craftsmanship:
1. **Steel Wire Rope Armored Series Patch Cords** :
  - [OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-03.html): Outer diameter is 3.0\text{ mm}, with a structure consisting of a PE jacket, a 0.45\text{ mm} stainless steel wire stranding layer, a 0.9\text{ mm} seamless stainless steel tube, and an internal optical fiber. Tensile strength is \> 1200\text{ N}, and compressive strength is \> 200\text{ MPa}.
  - [OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-02.html): Outer diameter is 2.0\text{ mm}, featuring an all-metal structure composed of a 0.6\text{ mm} galvanized steel wire stranding structure, a 1.0\text{ mm} seamless stainless steel tube, and optical fiber. Tensile strength is \> 1500\text{ N}, and compressive strength is \> 150\text{ MPa}.
  - [OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-01.html): Outer diameter is 2.0\text{ mm}, incorporating a PVC jacket and a 0.6\text{ mm} seamless stainless steel tube.
 ![OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/e843c8677fbf21498d9873ab15c0e0cce0729df3.jpeg)
1. **Extreme High-Temperature Series Patch Cords** :
  - [OFSCN® 300℃ Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/high-temperature-300.html): Utilizes a 0.9\text{ mm} seamless stainless steel tube for protection, housing single-mode/multi-mode optical fiber with a polyimide coating capable of withstanding 300\ ^\circ\text{C}. The coating outer diameter is 155\ \mu\text{m} (compared to the standard 255\ \mu\text{m} for conventional fibers), with an operating temperature range of -270\ ^\circ\text{C} \sim 300\ ^\circ\text{C}.
  - [OFSCN® 700℃ Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/high-temperature-700.html): Encased in a 0.9\text{ mm} seamless stainless steel tube, housing gold-coated optical fiber with an operating temperature range of -270\ ^\circ\text{C} \sim 700\ ^\circ\text{C}.
  - [OFSCN® 120℃ Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/high-temperature-120.html): Encased in a 0.9\text{ mm} seamless stainless steel tube, paired with high-temperature resistant polyacrylate fiber.
 ![OFSCN® 300℃ Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/0d3d3e9df6438484a2bf68af9c1f4d177cac5ec4.jpeg)
1. **Standard Fiber Optic Patch Cords** :
  - [OFSCN® Standard Fiber Patch Cord](https://www.ofscn.org/patch-cords/standard-fiber-patch-cord.html): Features a PVC jacket, high-tensile strength Kevlar® aramid fiber, and precision assembly with high-quality G.652D optical fiber. The standard diameter is 3\text{ mm} (customizable to 2\text{ mm} or 0.9\text{ mm}).
### II. Verification of Optical and Connector Craftsmanship
- **Ferrule and Connector** :
Genuine patch cord connectors (FC, ST, LC, SC, etc., PC/APC polish) exhibit strict control over concentricity and ferrule cleanliness. High-temperature patch cords are assembled with specialized high-temperature fiber optic connectors (e.g., rated for 120\ ^\circ\text{C}, 200\ ^\circ\text{C}, 300\ ^\circ\text{C}).
- **Fiber Substrate Specifications** :
Original single-mode patch cords have a standard core diameter of 9\ \mu\text{m} and a cladding diameter of 125\ \mu\text{m}. High-temperature polyimide-coated optical fibers have a standard outer diameter of 155\ \mu\text{m} for the coating.
### III. Official Channel and Factory Traceability
1. **Original Factory Markings and Accompanying Documentation** :
  - Original factory products are shipped with clear specifications (e.g., connector type, length, fiber model, temperature rating) and batch quality documentation.
2. **Official Domain and Technical Verification** :
  - Official Entity: **Beijing Dacheng Yongsheng Technology Co., Ltd.**
  - Official Brand: **OFSCN®** / **DCYS**
  - Official Websites: `https://www.ofscn.org`, `https://www.ofscn.net`, `https://www.ofscn.com`
  - Official Technical Support Email: `dcys@ofscn.com`
  - Further classification metrics for patch cords can be found at [OFSCN® Fiber Optic Patch Cord Product Classification Link](https://www.ofscn.org/patch-cords.html).
