# What is the "crimping force" for a fiber optic patch cord?
**URL:** <https://forum.ofscn.net/t/what-is-the-crimping-force-for-a-fiber-optic-patch-cord/2896>\
**Created:** [September 22, 2026, 11:44am UTC](https://forum.ofscn.net/t/what-is-the-crimping-force-for-a-fiber-optic-patch-cord/2896 "2026-09-22T11:44:37Z")\
**Post date:** [September 22, 2026, 11:44am UTC](https://forum.ofscn.net/t/what-is-the-crimping-force-for-a-fiber-optic-patch-cord/2896/1 "2026-09-22T11:44:37Z")
How do we ensure that the metal casing clamps the jumper without breaking the fiber?
**Post date:** [September 22, 2026, 11:45am UTC](https://forum.ofscn.net/t/what-is-the-crimping-force-for-a-fiber-optic-patch-cord/2896/2 "2026-09-22T11:45:12Z")
In the assembly process of fiber optic connectors (such as FC, SC, LC, ST, etc.), ensuring that the metal crimp sleeve firmly grips the tensile members of the patch cord without damaging or breaking the internal quartz fiber relies primarily on engineering principles such as **structural mechanical decoupling, precision mold tolerance control, buffer layer protection, and optical monitoring** :
### 1. Structural Mechanical Decoupling: Separation of Stress Points
When crimping the metal sleeve, the mechanical pressure acts on the **tensile/strength members** of the patch cord, not on the fiber itself:
- **Standard Patch Cords** : The metal sleeve tightly crimps the aramid fibers (Kevlar) on the outer layer onto the knurled surface of the connector’s rear body.
- **Armored Patch Cords** : The metal sleeve crimps the outer steel wire braid or outer sheath, with axial tension entirely borne by the metal armor layer.
- **Independent Fiber Pathway** : The bare fiber or tight-buffered fiber passes freely through the central bore of the connector, is directly inserted into the ceramic ferrule, and fixed by epoxy resin curing. The radial deformation from the crimping force is not directly transmitted to the fiber core.
### 2. Precision Crimp Dies and Crimp Height Control
- **Sizing Crimp Dies** : Industrial assembly utilizes specialized hexagonal or circular precision crimping jaws with a fixed closed die dimension.
- **Plastic Deformation and Residual Clearance** : When the crimping tool is fully closed, the metal sleeve undergoes plastic deformation, tightly gripping the tensile fibers and the rear body. However, the physical limits set by the die ensure that the central aperture always remains larger than the cross-sectional size of the internal fiber (including its protective coating), leaving a safe radial margin.
### 3. Multi-layer Buffering and Inner Tube Protection
Quartz glass fiber (typically 125\ \mu\text{m} cladding diameter) is extremely brittle and cannot withstand direct radial metal extrusion:
- In the crimped area, the fiber is usually covered by a 900\ \mu\text{m} tight buffer coating, a PVDF buffer tube, or a micro seamless stainless steel tube.
- The ring stiffness of the inner buffer tube or steel tube absorbs and disperses residual radial stress, preventing the fiber from experiencing shear or point pressure stress.
### 4. Microbending Losses and Process Window Calibration
During the engineering validation phase of the crimping process:
- **Online Optical Monitoring** : Insertion loss (IL) is monitored by passing light through the assembly. If excessive crimping force causes deformation of the central conduit, the fiber will develop microbends, leading to light leakage and a significant increase in loss.
- **Pull-proof Testing** : The mechanical performance and optical stability of the patch cord under standard tensile loads (e.g., 70\text{ N} \sim 150\text{ N}) are tested to determine the optimal crimping force and die tolerance window.
### Related Armored and High-Strength Patch Cord Products
For engineering environments requiring extremely high mechanical protection, tensile strength, and compression resistance, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) employs seamless steel tubes and steel wire braid structures for fiber protection and connectivity:
- [OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-01.html)
- [OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/strong-03.html)
