Will steel pipes shrink faster than optical fibers in liquid nitrogen? Will it break the optical fibers?
From the perspectives of optical physics and material mechanics, the answer to this question can be analyzed from two levels: thermal expansion coefficient difference and structural stress mechanisms:
I. Steel Tube Contraction is Indeed Much Faster Than Optical Fiber (Linear Expansion Coefficient Difference)
During the process of cooling from room temperature (approx. 20\ ^\circ\text{C} / 293\ \text{K}) to liquid nitrogen temperature (approx. -196\ ^\circ\text{C} / 77\ \text{K}):
- Stainless Steel Tube (e.g., 304 / 316L):
- The room temperature linear thermal expansion coefficient (CTE) of stainless steel is approximately 16 \times 10^{-6}\ /\text{K} to 17 \times 10^{-6}\ /\text{K}.
- When cooled to -196\ ^\circ\text{C}, the metal lattice contracts sharply, and its cumulative linear contraction rate is typically around $0.28% \sim 0.30% (equivalent to a physical shrinkage of about 2800 \sim 3000\ \mu\varepsilon).
- Quartz Glass Fiber (Fused Silica):
- Quartz glass has an extremely low thermal expansion coefficient, only about 0.5 \times 10^{-6}\ /\text{K}.
- When cooled to the liquid nitrogen temperature range, the cumulative contraction rate of the quartz fiber itself is less than $0.02%, almost maintaining its original size.
Physical Conclusion: The rate and cumulative amount of contraction of the steel tube are far greater than that of the quartz fiber, with the difference in cold contraction deformation being nearly an order of magnitude.
II. Will the Steel Tube “Crush” the Optical Fiber?
The conclusion is: under standard industrial packaging design, the steel tube will not crush the optical fiber; however, if the packaging or material selection is improper, the secondary stress induced by extreme low temperatures does pose a risk of fiber breakage.
Specific mechanical analysis is as follows:
1. Radial (Cross-sectional Direction) Clearance
Taking commonly used seamless steel tubes (e.g., outer diameter 0.9\ \text{mm} or 2.0\ \text{mm}) as an example, the theoretical radial inner diameter contraction is only on the order of a few micrometers. The outer diameter of optical fibers is typically 125\ \mu\text{m} \sim 250\ \mu\text{m}, leaving ample free inner space within the steel tube. The steel tube wall will not tightly contact and “crush” the fiber radially.
2. Axial (Length Direction) Strain Accommodation
Due to the significant shortening of the steel tube while the fiber hardly shrinks:
- Loose Tube Structure: The optical fiber has free floating margin inside the steel tube. As the steel tube shortens axially, the excess fiber length is converted into slight sinusoidal bending within the tube (i.e., micro-bending / buckling). As long as the inner diameter is appropriately matched and the excess length is controlled, the fiber will not bear destructive stress. If the inner diameter is too confined, excessive micro-bending may increase optical loss (attenuation), but mechanical fracture usually does not occur.
- Tight Buffer / End-Fixed Structure: When the optical fiber is firmly anchored to the steel tube at both ends, the contraction of the steel tube will exert extremely strong axial compressive stress on the optical fiber. Since the compressive strength of silica glass itself is extremely high (generally greater than 1000\ \text{MPa}, far exceeding its tensile strength), pure axial compressive stress alone is unlikely to crush the quartz body. The real culprit for fiber breakage usually stems from stress concentration at the shear point of the end anchor or brittle fracture due to bending.
3. True Fiber Breakage Risks at Extreme Low Temperatures
In actual liquid nitrogen tests or engineering applications, the cause of fiber breakage is typically not the steel tube itself, but the following secondary factors:
- Vitrification and Cold Shrinkage Stress of Fiber Coating: Conventional optical fibers use UV-cured acrylate coatings, whose glass transition temperatures are mostly above -40\ ^\circ\text{C}. Upon entering liquid nitrogen, the coating rapidly hardens, becomes brittle, and exhibits significant shrinkage and delamination, easily inducing micro-cracks that lead to brittle fracture. Therefore, in liquid nitrogen or cryogenic environments, it is usually necessary to use polyimide-coated fibers or metal-coated fibers (temperature resistance up to -200\ ^\circ\text{C} to -270\ ^\circ\text{C}).
- Ice Formation from Residual Moisture Inside the Tube: If the seamless steel tube is not adequately dried or poorly sealed, residual moisture may freeze and expand during cooling. The sharp, hard points generated by ice crystals can then break the optical fiber.
- Brittle Fracture of Encapsulant at Low Temperatures: If ordinary epoxy resin is used for end sealing, the resin will shrink drastically and lose elasticity at low temperatures, generating immense and uneven stresses that cause fiber breakage.
III. Relevant Products and Process References
When dealing with cryogenic and ultra-low temperature impacts, low-temperature-resistant polyimide-coated fibers are typically used in conjunction with stainless steel tube structures. This ensures structural integrity by eliminating internal moisture and providing strain margins.
- OFSCN® 300°C Fiber Optic Patch Cord: Composed of fiber optic connectors, 0.9\ \text{mm} seamless stainless steel tubes, and polyimide-coated fibers, with a nominal operating temperature range covering -270\ ^\circ\text{C} to 300\ ^\circ\text{C}. It maintains structural and light transmission stability in liquid nitrogen and even liquid helium temperature ranges.
- OFSCN® 300°C Seamless Steel Tube Fiber Cable: Utilizes a single-layer seamless stainless steel tube for structural protection, housing polyimide-coated fibers internally, offering both metal mechanical protection and temperature zone adaptability.
