What is the Cut-off Wavelength?
Why does a single-mode fiber support multi-mode transmission below a specific wavelength?
When the operating wavelength in a single-mode fiber falls below its cut-off wavelength, the fiber will support the propagation of multiple modes, essentially behaving like a multi-mode fiber.
This phenomenon occurs because the V-number (or normalized frequency) of the fiber, which determines the number of modes a fiber can support, is inversely proportional to the wavelength. As the wavelength decreases, the V-number increases. A fiber designed as single-mode for wavelengths above its cut-off will start to guide higher-order modes when the V-number exceeds the threshold for single-mode operation (typically around 2.405 for a step-index fiber). This transition leads to multi-mode transmission, which can introduce modal dispersion and increase signal loss.
OFSCN provides various types of single-mode optical fibers, including standard and specialized options. For instance, our range includes:
Here is an image related to optical fibers:
