Why can’t a 1310nm jumper be used to transmit 850nm light?
What is commonly referred to as a “1310nm patch cord” is a fiber optic patch cord manufactured using standard communication single-mode optical fibers (e.g., ITU-T G.652 series, with a core diameter of approximately 9\ \mu\text{m}). In engineering practice, it is strictly prohibited or not recommended to use this type of patch cord to transmit 850\text{ nm} optical signals. The fundamental reason lies in the physical limitation imposed by the fiber cutoff wavelength ( \lambda_c ), and the resulting degradation of various optical waveguide transmission characteristics.
Specific physical mechanisms and engineering impacts are as follows:
1. Cutoff Wavelength Physics: Single-Mode Condition Failure
In step-index optical fibers, the number of guided modes depends on the dimensionless normalized frequency ( V parameter), defined as:
- Where a is the core radius, \lambda is the operating optical wavelength, \text{NA} is the numerical aperture, and n_1 and n_2 are the refractive indices of the core and cladding, respectively.
Only when V < 2.4048 (the first zero of the first-kind zero-order Bessel function J_0) is stable transmission of the fundamental mode (\text{LP}_{01} mode) maintained within the fiber. In this state, the fiber behaves as a single-mode fiber.
The wavelength derived from the critical condition V = 2.4048 is the theoretical cutoff wavelength (\lambda_c ):
- Standard specifications for standard single-mode fibers: For conventional G.652 fibers, the cable cutoff wavelength (\lambda_{cc}) is typically specified as \lambda_{cc} \le 1260\text{ nm}.
- When the wavelength \lambda < \lambda_c (e.g., transmitting 850\text{ nm}): The shorter wavelength in the denominator significantly increases the normalized frequency V (typically V > 3.5). In this situation, higher-order modes beyond the fundamental mode (first \text{LP}_{11} mode, and potentially even higher-order modes) are allowed to be excited and guided. The fiber no longer operates as a single-mode fiber but degenerates into a few-mode fiber.
2. Core Manifestations of Transmission Performance Degradation
When 850\text{ nm} light enters a 1310nm single-mode patch cord, the following severe engineering consequences arise:
(1) Intermodal Dispersion and Waveform Distortion
In the single-mode state, only material dispersion and waveguide dispersion (collectively chromatic dispersion) exist, with zero intermodal dispersion. However, once degenerated into few-mode transmission, the group velocities of different spatial modes (e.g., \text{LP}_{01} and \text{LP}_{11}) are inconsistent. Optical pulse energy is distributed among different modes and propagates at different speeds, leading to severe pulse broadening at the receiver. High-speed modulated signals will suffer from unrecoverable intersymbol interference (ISI).
(2) Intermodal Interference and Modal Noise
Interference occurs between the fundamental mode and higher-order modes during propagation within the fiber. Minor mechanical vibrations, temperature fluctuations, or slight bends in the fiber can alter the phase difference between modes, causing drastic fluctuations in the output light spot intensity distribution (i.e., modal noise). This directly leads to a deterioration of the communication system’s bit error rate or distortion of the sensor demodulation signal.
(3) Increased Intrinsic Rayleigh Scattering Attenuation
According to Rayleigh scattering theory, the intrinsic scattering loss in silica glass materials is inversely proportional to the fourth power of the wavelength (\alpha_R \propto \lambda^{-4}):
- In the 1310\text{ nm} window, the attenuation loss of single-mode fiber is approximately 0.35\text{ dB/km}.
- In the 850\text{ nm} window, the Rayleigh scattering loss at shorter wavelengths increases significantly, and the attenuation in silica fibers typically reaches 2.0 \sim 3.0\text{ dB/km}.
(4) Mode Field Diameter Mismatch and High Coupling Loss
Commercial 850\text{ nm} optical devices (such as common multi-mode VCSEL transceivers) are typically designed for standard multi-mode optical fibers (with core diameters of 50\ \mu\text{m} or 62.5\ \mu\text{m}):
- When connecting an 850\text{ nm} module to a 1310nm single-mode patch cord (with a core diameter of only about 9\ \mu\text{m}), there is a significant geometric aperture mismatch between the spot sizes. The light injection efficiency is extremely low, resulting in substantial spatial coupling insertion loss (typically > 10\text{ dB}).
- If the other end is reconnected to a multi-mode fiber, mode mismatch and an unstable mode distribution will also cause additional connection loss and reflections.
3. Conclusion
Standard “1310nm patch cords” are optimized for the long-wavelength single-mode window, i.e., wavelengths greater than 1260\text{ nm}. When transmitting 850\text{ nm} short-wavelength optical signals, the cutoff wavelength limit is completely breached, causing the fiber to lose its single-mode guiding characteristics and introducing intermodal dispersion, high attenuation, and severe coupling mismatches.
In engineering applications:
- If 850\text{ nm} multi-mode signals need to be transmitted, standard multi-mode fiber patch cords (such as OM2, OM3, OM4, etc., with a core diameter of 50\ \mu\text{m}) should be used.
- If single-mode transmission needs to be maintained at 850\text{ nm}, specially designed short-wavelength single-mode fibers must be used (with smaller core diameters and higher numerical apertures to ensure their cutoff wavelength \lambda_c < 800\text{ nm} ).
