# What is the fiber fatigue factor?
**URL:** <https://forum.ofscn.net/t/what-is-the-fiber-fatigue-factor/2420>\
**Created:** [July 29, 2026, 12:00pm UTC](https://forum.ofscn.net/t/what-is-the-fiber-fatigue-factor/2420 "2026-07-29T12:00:27Z")\
**Post date:** [July 29, 2026, 12:00pm UTC](https://forum.ofscn.net/t/what-is-the-fiber-fatigue-factor/2420/1 "2026-07-29T12:00:27Z")
What does the “n value” related to the durability of fiber optic materials mean?
**Post date:** [July 29, 2026, 12:01pm UTC](https://forum.ofscn.net/t/what-is-the-fiber-fatigue-factor/2420/2 "2026-07-29T12:01:07Z")
In fiber optics and material physics, the value \*\* n \*\* that describes the “durability” (i.e., fatigue resistance, aging resistance, and long-term lifespan) of an optical fiber refers to the **fiber’s fatigue parameter** (or **Stress Corrosion Susceptibility Parameter** ).
It is a core physical indicator for evaluating whether a fiber will fracture under long-term mechanical stress and exposure to environmental moisture/chemical agents. Below is a detailed explanation of its general technical principles and physical processes:
### I. Physical Meaning and Mathematical Formula of the n Value
The primary component of optical fibers is high-purity silicon dioxide ( SiO\_2 ). During fiber drawing and manufacturing, the glass surface inevitably has extremely tiny, nanometer-scale cracks (known as subcritical cracks).
When the fiber is subjected to external tension (tensile stress) and exposed to an environment containing moisture (even atmospheric humidity), water molecules react chemically with the siloxane bonds ( Si-O-Si ) at the crack tips (hydrolysis reaction), causing the cracks to gradually expand inward. This phenomenon is known as **Stress Corrosion** or **static/dynamic fatigue**.
The crack propagation velocity v can be represented by the famous physical formula:
v = A K\_I^n
Where:
- v is the crack propagation velocity;
- A is a constant related to the material and environmental medium;
- K\_I is the stress intensity factor (its magnitude is proportional to the square root of the applied tensile stress \sigma and crack depth a , i.e., K\_I = Y \sigma \sqrt{a} , where Y is a crack geometry correction factor);
- \*\* n \*\* is the fatigue parameter ( n value).
### II. How the n Value Determines the “Lifespan” of an Optical Fiber?
The fatigue parameter n is an exponential relationship. It reflects the **sensitivity of microcrack propagation velocity to external stress variations** :
1. **When the n value is large** (e.g., $ n
vert 20 $ ):
This indicates that the crack propagation velocity is less sensitive to increases in external stress. Even under long-term rated tensile force, the growth of microcracks is extremely slow, and the fiber possesses **excellent fatigue resistance and an ultra-long mechanical lifespan**.
2. **When the n value is small** (e.g., $ n
vert 15 $ ):
This indicates that crack propagation is extremely sensitive to external stress. Even slight mechanical tension or bending force can cause microcracks to propagate inward at an exponentially increasing rate, leading to rapid, sudden brittle fracture of the fiber, resulting in **poor durability**.
For standard silica single-mode fibers (equipped with standard acrylate coatings) used in normal atmospheric environments, their typical n values are usually between \*\* 18 \*\* and \*\* 22 \*\*.
### III. How to Improve n Value and Durability Through Material Design?
To prevent the synergistic erosion of the glass surface by moisture and stress, thereby extending the working life of the fiber under harsh conditions, specialty fibers significantly improve the n value by optimizing the physical and chemical properties of their **coatings** :
#### 1. Polyimide Coating
Traditional organic coatings (like polyacrylates) can degrade and lose their protective function under high temperatures or humidity. Polyimide offers excellent high-temperature stability, mechanical strength, and chemical inertness, which better delays the diffusion of water molecules to the glass surface, allowing the fiber to maintain high fatigue resistance under a wider range of temperatures and high bending stresses.
- Typical Product: [OFSCN® 300℃ SM Polyimide Optical Fiber](https://www.ofscn.org/optical-fibers/polyimide-coated-sm-300.html)
 ![OFSCN® 300℃ SM Polyimide Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/ce90be3e4b9bb517d521f23c595dfb4d1985b218.jpeg)
#### 2. Hermetic Metal Coating (Gold Coating)
To achieve extremely high durability, true **hermetic sealing** is essential. By directly plating a dense layer of gold onto the outer cladding, the hydrolysis reaction between moisture/oxygen and silicon dioxide is completely blocked. In an anhydrous environment, the stress corrosion mechanism cannot take effect. In this case, the fatigue parameter of the fiber theoretically approaches infinity (actual tests show $ n
vert 100 $ or even up to several orders of magnitude), allowing the fiber to withstand extremely high mechanical strain with virtually no fatigue aging.
- Typical Product: [OFSCN® Gold-coated Optical Fiber](https://www.ofscn.org/optical-fibers/gold-coated.html)
 ![OFSCN® Gold-coated Optical Fiber](https://forum.ofscn.net/uploads/default/original/1X/a0527f8c12cba5c5a4c64951106d0779161ec84a.jpeg)
