What is the group refractive index of an optical fiber?
When accounting for the time it takes for light to travel, why do we use this specific refractive index?
When calculating the propagation time of optical signals in optical fibers (such as for OTDR localization, Time-of-Flight (ToF) measurements of optical pulses, or TDM fiber Bragg grating sensing), it is imperative to use the Group Refractive Index (denoted as n_g) rather than the ordinary Phase Refractive Index (denoted as n or n_p).
The core physical reason is that: in practical transmission, it is the “optical pulse (wave packet)” that carries information and energy, and its envelope’s propagation speed is determined by the group velocity, not the phase velocity of monochromatic light.
I. Essential Difference Between Phase Velocity and Group Velocity
  1. Phase Velocity (v_p) and Phase Refractive Index (n)
    • Phase velocity describes the speed at which the “constant phase front” of an ideal monochromatic sinusoidal plane wave propagates:
      v_p = \frac{c}{n}
    • A strictly monochromatic wave is infinitely long in time and constant in amplitude. It carries no detectable start or end time information.
  2. Group Velocity (v_g) and Group Refractive Index (n_g)
    • Signals used in real-world measurements to determine “how long it took” are optical pulses with finite duration. According to Fourier Transform, an optical pulse is formed by the superposition of monochromatic light waves with many different frequency components, creating a wave packet (envelope).
    • The speed at which the overall envelope of an optical pulse (i.e., the center of optical energy concentration and signal information) advances is called the group velocity:
      v_g = \frac{c}{n_g}
    • When calculating the propagation time or reflection localization of a pulse in an optical fiber, what is actually tracked is the propagation path of the optical pulse envelope. Therefore, the corresponding propagation speed must be v_g, and the corresponding refractive index must be n_g.
II. Why is n_g \neq n in Optical Fibers? (Dispersion Effect)
The primary material of optical fibers is fused silica glass (\text{SiO}_2), whose refractive index is not a constant but a function of wavelength \lambda (or angular frequency \omega). This physical phenomenon is known as Material Dispersion.
The group velocity of a wave packet is given by the dispersion relation of the medium:
v_g = \frac{d\omega}{dk}
Expanding and deriving based on the wave number k = \frac{\omega \cdot n(\omega)}{c}, we can obtain the mathematical relationship between the group refractive index n_g and the phase refractive index n:
n_g = n - \lambda \frac{dn}{d\lambda}
In the near-infrared sensing and communication bands (e.g., around 1550\text{ nm}):
  • The fused silica medium is in the normal dispersion region. As the wavelength increases, the refractive index decreases, so the dispersion slope \frac{dn}{d\lambda} < 0 .
  • From the formula, it can be seen that the negative times negative becomes positive, causing n_g to be significantly greater than n.
  • Taking the standard communication and sensing single-mode fiber OFSCN® G.652D Optical Fiber as an example:
    • At \lambda = 1550\text{ nm}, the phase refractive index (effective refractive index n_{\text{eff}} ) of the single-mode fiber core is approximately 1.445.
    • However, the group refractive index n_g used for pulse delay calculations is approximately 1.467 \sim 1.468.
III. How Much Engineering Error is Caused by Mixing Refractive Indices?
In optical fiber reflection localization measurements, the two-way time t for an optical pulse to travel from the source to the target point and return, and the physical one-way length L, are calculated as follows:
L = \frac{c \cdot t}{2 \cdot n_g}
If the phase refractive index n \approx 1.445 is mistakenly used instead of the group refractive index n_g \approx 1.468:
  • The relative deviation is:
    \frac{\Delta L}{L} = \frac{n_g - n}{n_g} \approx \frac{1.468 - 1.445}{1.468} \approx 1.57\%
  • For a fiber measurement of 1\text{ km}, this would introduce an absolute ranging error of approximately 15.7\text{ m}.
  • For long-distance pipeline monitoring or array grating demodulation of 10\text{ km}, the error would accumulate to nearly 160\text{ m}.
Therefore, in all engineering measurements involving optical fiber pulse time-of-flight (ToF), OTDR addressing, and OFDR frequency-domain delay conversions, the group refractive index n_g calibrated at the time of fiber factory production must be strictly used.
