What is the nonlinear threshold of an optical fiber?
How much light do you need to send into an optical fiber before it starts to produce interference signals?
In optical fiber optics and fiber optic sensing systems, the so-called “generation of interference signals” essentially refers to the fiber optic material exceeding its linear response region under the influence of a strong optical field, triggering Optical Nonlinear Effects. This leads to signal waveform distortion, introduction of background noise, or generation of new spurious frequency components.
For conventional quartz single-mode fibers (such as the standard G.652 series single-mode fibers with a mode field diameter of approximately 9\ \mu\text{m} \sim 10\ \mu\text{m}, operating in the 1550\ \text{nm} window), the specific optical power that causes interference depends on which nonlinear physical effect is excited and the spectral characteristics of the light source.
I. Trigger Thresholds of Key Nonlinear Effects
When common continuous light (CW) or quasi-continuous light is injected into long-haul optical fibers (several kilometers to tens of kilometers), the order of appearance and typical power thresholds for various nonlinear interference are as follows:
1. Stimulated Brillouin Scattering (SBS) — Lowest and Most Easily Triggered Threshold
  • Threshold Range: Approximately 5\ \text{mW} \sim 10\ \text{mW} (i.e., +7\ \text{dBm} \sim +10\ \text{dBm} )
  • Interference Manifestation: SBS is the first nonlinear effect to be excited by narrow linewidth light sources in long optical fibers. When the input power exceeds the SBS threshold, strong inelastic scattering occurs between light and acoustic phonons in the medium. Most of the forward-propagating optical power becomes nonlinearly saturated, and a large portion of the newly injected optical power is forcibly reflected back to the transmitter. This is accompanied by a backward Brillouin frequency-shifted signal with a frequency shift of approximately 11\ \text{GHz} (about 0.088\ \text{nm} at 1550\ \text{nm}), causing severe noise and backward optical interference to the forward transmission and the light source.
  • Note: SBS is extremely sensitive to the light source linewidth. The threshold is extremely low only for narrow linewidth lasers (linewidth < 10\ \text{MHz}). If a broadband light source (such as ASE or SLED) is used, the SBS threshold increases by several orders of magnitude.
2. Self-Phase Modulation (SPM) & Cross-Phase Modulation (XPM) — Pulse Broadening and Phase Jitter
  • Threshold Range: Approximately 10\ \text{mW} \sim 50\ \text{mW} for continuous light; tens of milliwatts to several watts peak power for pulsed light
  • Interference Manifestation: Originates from the third-order nonlinear polarization (Kerr effect) in quartz glass. When the light intensity is very high, the refractive index of the optical fiber changes dynamically with the light intensity:
    n(I) = n_0 + n_2 I
    This causes different parts of the optical pulse itself (SPM) or other wavelength signals in the same fiber (XPM) to experience time-varying nonlinear phase shifts \phi_{\text{NL}}. When the accumulated phase shift reaches approximately 1\ \text{rad}, the spectrum broadens significantly, leading to modulation instability and severe dispersion degradation.
3. Four-Wave Mixing (FWM) — Generation of Entirely New Interference Wavelengths
  • Threshold Range: Tens of milliwatts for single channels ( > 20\ \text{mW} ); tens of milliwatts total power for multi-wavelength systems
  • Interference Manifestation: In dense wavelength-division multiplexing (DWDM) or multi-wavelength fiber optic sensing systems, photons of different frequencies interact in the Kerr medium to generate new combination frequencies:
    f_{\text{new}} = f_1 + f_2 - f_3
    If the newly generated spurious signal happens to fall within the receiving bandwidth of a sensing or communication channel, it constitutes inter-channel crosstalk (Ghost Channels) that cannot be filtered out. FWM is more likely to occur when the dispersion is close to zero (e.g., G.653 fiber).
4. Stimulated Raman Scattering (SRS) — Energy Transfer Towards Longer Wavelengths
  • Threshold Range: Approximately 500\ \text{mW} \sim 1\ \text{W} (about +27\ \text{dBm} \sim +30\ \text{dBm} )
  • Interference Manifestation: Photons interact with optical vibration phonons in quartz molecules. SRS has an extremely wide gain bandwidth (approximately 40\ \text{THz}). When the input power in a single-mode fiber approaches or exceeds 1 W, high-energy photons nonlinearly transfer energy to the Stokes Wave, which is redshifted by approximately 13.2\ \text{THz} (about 100\ \text{nm} towards longer wavelengths at 1550\ \text{nm}, i.e., around 1650\ \text{nm}). This causes severe attenuation of the original signal and generates strong background optical noise over a wide frequency range.
II. Physical Models Determining Nonlinear Thresholds
The occurrence of nonlinear effects is determined not only by the absolute injected power but also by the power density and the effective interaction length:
  1. Effective Mode Field Area (A_{\text{eff}}):
    The core of a single-mode fiber is extremely thin, with an effective area of only about 80\ \mu\text{m}^2. Millwatt-level optical power concentrated on this cross-section corresponds to optical power densities as high as tens of megawatts per square meter (\text{MW/m}^2). A smaller mode field area leads to a lower nonlinear threshold.
  2. Effective Interaction Length (L_{\text{eff}}):
    Limited by the fiber’s own attenuation coefficient \alpha, the optical power decays exponentially with distance. The effective length for nonlinear interaction is:
    L_{\text{eff}} = \frac{1 - e^{-\alpha L}}{\alpha}
    For single-mode fibers of tens of kilometers (\alpha \approx 0.2\ \text{dB/km}), the asymptotic limit of L_{\text{eff}} is about 20\ \text{km} to 22\ \text{km}. If the fiber length is very short (e.g., a few meters to tens of meters patch cord), insufficient nonlinear accumulation will occur, and the actual nonlinear power threshold the fiber can withstand will increase proportionally by several to tens of times.
III. Engineering Summary and Reference Guidelines
In practical optical systems (such as Fiber Bragg Grating (FBG) sensing systems, fiber optic interferometry, and optical communication systems):
  • If the system uses a narrow linewidth continuous laser (e.g., DFB laser), the safe upper limit for injected power during long-haul fiber transmission is generally recommended to be controlled within +5\ \text{dBm} (about 3.2\ \text{mW} ) to strictly prevent SBS-induced signal saturation and backward scattering interference.
  • If the system uses a broadband light source (e.g., ASE light source, SLED) or a short fiber link (tens of meters), SBS is not easily excited. The optical fiber can maintain excellent linearity in the range of tens of milliwatts to hundreds of milliwatts until it approaches the limit of thermal damage or fiber end-face ablation (typically in the watt range or above).
