# What is the "robustness of wavelength peak searching"?
**URL:** <https://forum.ofscn.net/t/what-is-the-robustness-of-wavelength-peak-searching/3062>\
**Created:** [October 18, 2026, 12:44pm UTC](https://forum.ofscn.net/t/what-is-the-robustness-of-wavelength-peak-searching/3062 "2026-10-18T12:44:57Z")\
**Post date:** [October 18, 2026, 12:44pm UTC](https://forum.ofscn.net/t/what-is-the-robustness-of-wavelength-peak-searching/3062/1 "2026-10-18T12:44:57Z")
Under extremely harsh spectral conditions, can algorithms still “tough it out” and produce the correct result?
**Post date:** [October 18, 2026, 12:45pm UTC](https://forum.ofscn.net/t/what-is-the-robustness-of-wavelength-peak-searching/3062/2 "2026-10-18T12:45:31Z")
In Fiber Bragg Grating (FBG) sensing demodulation systems, the **“Robustness of Wavelength Peak Searching”** refers to the capability of the demodulation algorithm to accurately, stably, and with high repeatability, lock onto the true physical center wavelength (Bragg Wavelength, \lambda\_B) while suppressing various noise and deformation interferences, even when faced with non-ideal, distorted, or severely degraded spectral signals, without experiencing “peak hopping,” “false peak misjudgment,” or “algorithm divergence and loss of lock.”
### I. Physical Causes of Extremely Harsh Spectra
In an ideal laboratory environment, the reflection spectrum of an FBG closely approximates a standard Gaussian or single-peak Lorentzian line shape, with high signal-to-noise ratio and a flat background. However, in actual industrial or harsh physical fields, spectra often encounter the following severe degradations:
1. **Broadening and Splitting of Spectral Peaks due to Non-uniform Strain Fields (Chirping & Peak Splitting)**
When the grating region is subjected to shear stress, gradient temperature fields, or non-uniform curing stress, the grating period \Lambda becomes non-uniformly distributed along the axis. A single peak may undergo severe asymmetric broadening, top flattening, or even split into multiple peaks.
2. **Birefringence-induced Splitting of Peaks (Birefringence-induced Splitting)**
Lateral pressure or micro-bending on the optical fiber can cause anisotropy in the fiber core’s cross-section, destroying polarization degeneracy and splitting the reflection peak into two orthogonal polarization reflection sub-peaks corresponding to the fast and slow axes.
3. **Extremely Low Signal-to-Noise Ratio (Low SNR) and High-Frequency Noise**
Attenuation in long-distance transmission fibers, loss from multiple connector transitions, aging and decay of the light source, or dark current noise from the detector can lead to extremely low amplitude of the reflection peak, with the peak value even approaching the system’s noise floor.
4. **Baseline Tilt and Interference Ripple (Baseline Tilt & Interference Ripple)**
Unstable output spectra from broadband light sources, Fabry-Perot (FP) cavity effects, return loss at fusion splices, or Fresnel reflections from end faces can cause the reflection peak to be superimposed on a tilted, undulating, or periodically rippled baseline noise.
5. **Dense Wavelength Division Multiplexing (WDM) Overlap and Crosstalk**
When the wavelength of serially connected gratings shifts excessively due to temperature drop or strain, causing partial overlap of the reflection spectra of two adjacent gratings, mutual pull and peak shape distortion may occur.
### II. How Algorithms Cope with Harsh Spectra
Regarding the question of “whether algorithms can still extract correct results under duress,” an analysis is required from two perspectives: the peak searching mechanism and the physical boundaries:
#### 1. Degradation and Limitations of Basic Algorithms
- **Direct Maximum Value Detection (Peak Detection)**: Only finds the maximum value among discrete sampled points. In low SNR or flat-top spectra, it is extremely susceptible to tens to hundreds of picometers ( \text{pm} ) of jitter due to random noise fluctuations, exhibiting the worst robustness.
- **Centroid Detection Algorithm** : Uses spectral integration to calculate the center of energy. Fast computation, but extremely sensitive to truncation thresholds and tilted baselines, leading to systematic drift caused by background fluctuations.
- **Standard Least Squares Gaussian Fitting (Gaussian Fitting)**: Assumes a perfectly symmetrical peak shape. When the spectrum becomes severely asymmetric or split due to non-uniform stress, the iteration can easily get stuck in a local minimum or result in fitting divergence.
#### 2. Core Processing Flow of High-Robustness Peak Searching Algorithms
Modern high-robustness demodulation engines typically employ a cascaded, adaptive processing strategy:
- **Adaptive Baseline Stripping and Denoising** : Utilizes morphological filtering or asymmetric truncated polynomial fitting to accurately remove tilted baselines and low-frequency light source fluctuations; employs wavelet transform to eliminate high-frequency Gaussian white noise while preserving edge steepness.
- **Dynamic Threshold and Search Window Tracking** : Dynamically calculates truncation thresholds based on the instantaneous signal-to-noise ratio (e.g., adaptively selecting the truncation interval based on the Half-Width at Half-Maximum (FWHM) range) to exclude the influence of baseline energy on the centroid.
- **Multi-Model Fusion and Asymmetric Fitting** : Incorporates asymmetric Gaussian, generalized Voigt models, or adaptive weighted fitting algorithms; for birefringence split peaks, introduces deconvolution mechanisms for double peaks, tracking the energy-weighted center or the main polarization peak.
- **Temporal State Constraint (Kalman Tracking)**: In dynamic monitoring, by combining the continuity of physical strain/temperature changes, Kalman filtering is constructed using temporal prior information to reasonably validate potential wavelength jump locations, eliminating sudden erroneous points.
#### 3. Physical Boundaries of Algorithms
Robustness is not infinite. When the non-uniform strain in the grating region is extremely severe, causing the reflection spectrum to completely diffuse and the peak to be submerged in noise (SNR below the algorithm’s detection threshold), the lost optical physical information cannot be reconstructed from scratch. The core value of high-robustness algorithms in such critical states is: **to minimize errors within the permissible physical distortion range, and when the signal is completely distorted, to accurately report a quality factor or a loss-of-lock alarm, preventing the output of pseudo-random erroneous data.**
### III. Related Fiber Grating Demodulation Systems
High-robustness wavelength demodulation relies on the combination of optical hardware with high sampling linearity and low system noise, and peak searching algorithms.
Beijing Dacheng Yongsheng Technology Co., Ltd.'s related demodulation equipment provides a stable hardware foundation and flexible signal acquisition support:
- [OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html)
Offers custom configurations such as 4-channel, 8-channel, 16-channel, 32-channel, etc.; default wavelength measurement range is 1525\ \text{nm} \sim 1565\ \text{nm} or 1528\ \text{nm} \sim 1568\ \text{nm} ; default wavelength resolution is 1\ \text{pm} (customizable to 0.1\ \text{pm} ); supports sampling frequency adjustment of 10\ \text{Hz}, 50\ \text{Hz}, 100\ \text{Hz}, and data acquisition via TCP, UDP, Modbus, and other protocols.
 ![OFSCN® Fiber Bragg Grating Interrogator 8CH](https://forum.ofscn.net/uploads/default/original/1X/8ecc1c112d2015cbc63afa6d42b87517befb2f87.jpeg)
 ![OFSCN® Fiber Bragg Grating Interrogator 32CH](https://forum.ofscn.net/uploads/default/original/1X/248718a63e2aa4cf7db24ad7a4df5ace79c95a05.jpeg)
