# What is the "vibration resistance" of a demodulator?
**URL:** <https://forum.ofscn.net/t/what-is-the-vibration-resistance-of-a-demodulator/3060>\
**Created:** [October 18, 2026, 12:44pm UTC](https://forum.ofscn.net/t/what-is-the-vibration-resistance-of-a-demodulator/3060 "2026-10-18T12:44:12Z")\
**Post date:** [October 18, 2026, 12:44pm UTC](https://forum.ofscn.net/t/what-is-the-vibration-resistance-of-a-demodulator/3060/1 "2026-10-18T12:44:12Z")
If mounted on a vehicle-mounted monitoring car, will the bumps affect the measurement accuracy?
**Post date:** [October 18, 2026, 12:45pm UTC](https://forum.ofscn.net/t/what-is-the-vibration-resistance-of-a-demodulator/3060/2 "2026-10-18T12:45:09Z")
The influence of vehicular dynamics or bumpy environments on the measurement accuracy of Fiber Bragg Grating (FBG) interrogators primarily depends on the **optical spectral / tuning architecture** , **wavelength self-calibration mechanism** , and **mechanical shock resistance level** employed within the interrogator.
### I. Physical Mechanisms of Bump and Vibration Impact on Accuracy
1. **Optical Path Coupling and Micro-Mechanical Perturbation**
The core of an FBG interrogator lies in precisely resolving wavelength shifts of reflected light (with resolutions typically reaching the 1\text{ pm} or 0.1\text{ pm} level). If the interrogator incorporates free-space optical lenses, precision piezoelectric drivers (PZT), or micro-mechanical tuning components (such as some mechanical F-P tunable filters), the random accelerations and impact forces generated during vehicular travel can induce minute transient changes in the optical cavity length or the grating’s relative position. This, in turn, manifests as jitter in wavelength readings, increased noise floor, or instantaneous jumps.
2. **Internal Wavelength Reference Locking (Real-time Self-Calibration)**
Industrial-grade vehicular interrogators typically require hardware-level real-time wavelength calibration modules (e.g., incorporating acetylene or hydrogen cyanide gas absorption cells, or highly stable unbalanced interferometers). Within each scanning cycle, the instrument uses the gas’s characteristic absorption spectral lines as a physical absolute reference for real-time dynamic fitting and correction. If a real-time wavelength calibration loop with high shock resistance is present, system zero-point drift caused by external mechanical vibrations can be effectively canceled out by the real-time algorithm.
3. **Response Differences Between Dynamic and Static Measurements**
### II. Engineering Recommendations for Vehicular Deployment
To minimize the impact of vehicular bumps on fiber optic sensing measurements, engineering practices often involve the following protective measures:
1. **Installation in Shock-Absorbing Cabinets / Platforms** : Avoid rigidly fixing the interrogator to the metal baseplate of the vehicle frame. Instead, use standard automotive shock-absorbing racks or polyurethane/rubber anti-vibration feet to attenuate large vertical impacts.
2. **Securing Fiber Optic Connectors** : Vehicular vibrations can easily loosen movable flanges. It is recommended to use threaded locking connectors (e.g., FC/APC) and to mark them after tightening to prevent step-wise fluctuations in optical power loss caused by micro-displacements.
3. **Selection of Solid-State / High Shock Resistance Architectures** : Prioritize interrogator devices that have no moving parts in the free-space optical path and feature fully fiber-optic encapsulated light paths.
### III. Relevant Official Products and Specifications
Within the Beijing Dacheng Yongsheng Technology Co., Ltd. ecosystem, the [OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html) adopts an industrial-grade solid-state design and an interference-resistant optical path, supporting deployment in complex industrial and dynamic monitoring scenarios:
- **Wavelength Range** : Default 1525\sim 1565\text{ nm} or 1528\sim 1568\text{ nm} (customizable)
- **Wavelength Resolution** : Default 1\text{ pm}, or customizable to 0.1\text{ pm}
- **Sampling Frequency** : 10\text{ Hz}, 50\text{ Hz}, 100\text{ Hz} selectable (supports self-frequency adjustment via interrogator software, down to 1\text{ Hz})
- **Channel Count** : 4, 8, 16, 32 channels customizable
- **System Interface** : Default B/S architecture software, supports C/S architecture and integration protocols like TCP, UDP, Modbus, etc.
 ![OFSCN® Fiber Bragg Grating Interrogator 8 Channel](https://forum.ofscn.net/uploads/default/original/1X/8ecc1c112d2015cbc63afa6d42b87517befb2f87.jpeg)
 ![OFSCN® Fiber Bragg Grating Interrogator 32 Channel](https://forum.ofscn.net/uploads/default/original/1X/248718a63e2aa4cf7db24ad7a4df5ace79c95a05.jpeg)
